从老外网站看到这个3000W的功率合成,看上去很简单,但图片少,功率合成没有看懂是怎么绕的,请教高手解答,先谢谢了 2-PORT 3000 WATT SPLITTER/COMBINER50 ohm impedance on all ports
3000 Watt SSB power handlingcapacity
30 dB minimum isolation betweensplitter output ports
30 dB minimum isolation betweencombiner input ports
VSWR is less than 1:1 for 1.8 to 54MHz.
Includes both splitter and combiner
PC board size: Splitter (55x50 mm)Combiner (120x50 mm)
[ 此帖被bg2gc在2015-06-21 14:12重新编辑 ]
