好多盆友问我最新的版本,开个贴,方便大家
因KA7OEI版本有一些BUG,本楼固件是在原版本基础上的修改版。
通过和KA7OEI的交流,KA7OEI的版本已经修复一些主要的BUG,修改之后的版本见本帖3楼。 最新版本:firmware_Target_Flash_219_5_BH3NVN_0419_09.bin
说明:
1、基于KA7OEI最新版本(219.5)修改
2、修正了原版一些BUG,改变了一些实用的功能设置
3、开机版本号下边一行增加“Fixed by BH3NVN XX”XX为bin文件最后两位,方便与原来版本区分
注意:1、SWR代码KA7OEI已经增加,尊重原作者,不做改变(KA7OEI使用二次多项式拟合功率曲线,我之前在219.2版使用的是分段查表方法),但是需要改动部分硬件,如果不改动,低于5瓦驻波会偏大,仅供参考。2、219.5原版相对于219.2原版改变的内容如下:Changes made:
• Additional tweaks done to further speed up the LCD udpates for users with SPI-based LCDs.
• The internal definition of 10 meters is now correct (e.g. 28-29.7 MHz)
• The auto-off backlight timer is disabled while in the menu system.
• The problem in which the on-screen indication of the band may be off by 6 kHz has been fixed.
• While in the “Frequency Calibrate” menu setting, only up to a 1 kHz step size may be selected.
• While in the “XVTR Offset (Hz)” menu setting, a frequency step size of up to 10 MHz may be selected.
• The maximum XVTR Offset is now 999.000 MHz.
• 100 MHz digit now available on the main frequency display.
• Added setting to disable SSB TX “Brick wall” filter.
• Menu item “#271 – FWD/REV ADC Swap” has been added to allow interchanging the forward and
reverse power detectors.
• Menu item “#231 – Freq. Limit Disable” has been added.
3、使用219.5版本固件,建议硬件做如下改动:Additional information regarding hardware modifications related to the SWR/power meter:
With this firmware, additional work has been done on the forward and reverse power detector of the mcHF. At least with my "copy" of have observed the following:
- It appears necessary to apply inductance at R55 and R56 to keep residual RF out of the A/D lines going to the MCU. The 47uH inductors used elsewhere in this unit work nicely, although 4.7uH inductors should work fine.
- I also added some 10nF (0.01uF) capacitors between pins 9 and 6 (ground) and pins 10 and 6 on the RF board to provide additional RF bypassing. The values of these capacitors are not critical and may be 100nF (0.1uF).
- I am having "issues" with reverse isolation on the "Tandem bridge" used for reverse power detection on the transceiver (e.g. L2/L3) in that on higher bands, I'm not getting the isolation that I expect. Experimentally, I cut a trace, removed R27 and added to jumpers to "reverse" the VSWR bridge (e.g. wired it back-to-front) which improved things a bit - hence the addition of menu item #271 that allows the FWD and REV inputs from the sensor to be swapped in software. I would appreciate the comments of others on this topic!
Change Log:
firmware_Target_Flash_219_5_BH3NVN_0420_0A.bin
1、解决开机闪烁CW速度“WPM XX”的BUG;
2、加快关机速度;
*此版本是在最新版219.5的基础上修改,如果以下改动对您来说不需要,请使用原版固件*1、23号菜单,2.6k Center Freq错误,没有2.6k滤波器,改为2.3k Center Freq;
2、关机自动保存数据进EEPROM,原版关机倒计时没有任何意义,已经去掉;
3、解决100k步进调谐破音问题;
4、听取BD1CM意见,微调时关闭静音,调谐时声音连续,不会断;
5、增加驻波保护功能,反射功率大于2瓦,功率自动降为0.5瓦(功率表和功率档位数字),需要按PA键,重新调节功率档位;
6、滤波器随工作模式转换自动改变,默认SSB 2.3KHZ,CW 300HZ;
7、新发现一处原版BUG,接收频率(灰色小字)在10兆以上,最高10兆位数字会消失,已经解决,附件已经重新上传,之前下载过的请重新下载。 ---------------------------
firmware_Target_Flash_219_2_BH3NVN_0419_08.bin
1、修正一处SSB模式出现300Hz滤波器的错误(感谢15楼BG5TLA);
2、滤波器随工作模式转换自动改变,默认SSB 2.3KHZ,CW 300HZ。
firmware_Target_Flash_219_2_BH3NVN_0418_07.bin
1、滤波器随工作模式转换自动改变,默认SSB 2.3KHZ,CW 500HZ。
firmware_Target_Flash_219_2_BH3NVN_0418_06.bin
1、重写SWR标尺,SWR从1开始;
2、改正上一版本SWR偏大的BUG,SWR更加准确;
3、修正驻波保护的BUG,显示"PROT"警告时候,可以看到功率降为0.5瓦(功率表和功率档位数字),需要按PA键,重新调节功率档位。
firmware_Target_Flash_219_2_BH3NVN_0414_05.bin
1、解决100k步进调谐破音问题;
2、听取BD1CM意见,微调时关闭静音,调谐时声音连续,不会断。
firmware_Target_Flash_219_2_BH3NVN_0414_04.bin
1、上一版本返回功率太大时候会有"PROT"警告,但是回复正常之后,警告不会消失,已解决;
2、改进SWR算法,上一版本有时候高驻波swr表没有指示,已经解决;
3、添加支持0.5瓦检测代码,0.5瓦功率在功率表显示一个点;
4、驻波大于3时,指示条变红提示。
firmware_Target_Flash_219_2_BH3NVN_0413_03.bin
1、重新校准了功率条和SWR。
firmware_Target_Flash_219_2_BH3NVN_0413_02.bin
1、原版本SWR条显示从0格开始,改为从1格开始;
2、上一个版本为了调试,会显示正向功率p,反向功率s和swr数值,本版本已经屏蔽;
3、反向功率大于2瓦的时候,会自动降低功率到0.5瓦;
4、56号菜单,56-CW Freq. Offset 默认由USB改为 AUTO SHIFT,收发频率与商品机一致;
5、关机自动保存数据进EEPROM,原版关机倒计时没有任何意义,已经去掉。
firmware_Target_Flash_219_2_BH3NVN_0413_1.bin
BUG修正:
1、23号菜单,2.6k Center Freq错误,没有2.6k滤波器,改为2.3k Center Freq。
帖子编辑麻烦,为了方便,我会把最新的测试版固件丢在我的网盘里,待测试没有问题,再更新到本帖,如果想尝鲜,请移步到到我的博客,谢谢~ 好多朋友担心刷坏,FLASH寿命1万次,每天一次可以刷30年 [ 此帖被BH3NVN在2015-04-26 09:01重新编辑 ]
