  • 5501阅读
  • 5回复
My Open Router  固件信息 R8000篇 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-10-07
My Open Router  固件
最新发布如下
http://www.myopenrouter.com/download/list?sort=date
[ 此帖被BG4DRL在2014-10-11 01:51重新编辑 ]
只看该作者 1楼 发表于: 2014-10-10
DD-WRT for R8000 FINAL 09-29-2014
http://www.myopenrouter.com/download/file/56765-416
只看该作者 2楼 发表于: 2014-10-10
Description:
Firmware Upgrade Procedure:-
Always use the following steps to upgrade your firmware.
- Perform reset to factory defaults setting in existing Firmware.
- Perform Firmware Upgrade.
- Perform reset to factory defaults setting in newly upgraded DD-WRT Firmware.
- Use DD-WRT in your router.
29-Sep-2014:-
DDWRT firmware is based on revision 24170.
Features Included :-
- Wireless Basic
- Wireless Security
- Wireless Guest Network
- Wireless Guest Network Security
- USB Storage
- USB auto-mount Support (Single and multiple partition)
- File System (VFAT, Ext2, Ext3, NTFS)
- jffs2
- IPKG
- Firmware Upgrade
- Factory Reset
- Backup Settings
- Reset Button
- Wifi ON/OFF Button
- LED
- WAN Configurable in STATIC, DHCP ,PPPoE and PPTP mode
- Secure Shell (SSH, SCP)
- Telnet
- Remote WebGUI Management
- Remote Telnet Management
- Remote SSH Management
- VLANs
- Iptables
- Firewall
- PPTP VPN Server
- OpenVPN Client
- VPN Passthrough
- PPPoE Server
- SNMP
- epi-ttcp
- iperf
- NTP Client
- Scheduled Reboot
- Boot Wait
- Cron
- Syslog
- WOL
- Port Forrowarding
- Port Range Forrwarding
- Port Triggering
- DMZ
- UPnP
- miniDLNA
- Zabbix Agent Client
- FreeRadius Server
- FTP
- SAMBA3
- Bandwidth Monitoring
- QoS
Issued Fixed:-
- 80+80 Channel Width set for the third interface
- AC-only Mode
- Regulatory Domain
- TxPower for third interface
Known Issues:-
- Wireless Client Bridge
只看该作者 3楼 发表于: 2014-10-11
只看该作者 4楼 发表于: 2014-11-13
Firmware Version 1.0.0.110
New Features
•Supports 'China' wireless region and passed SRRC & CCC certifications.
Firmware Upgrade Instruction
Note: To avoid wireless disconnect issue during the firmware download process, NETGEAR recommends that firmware upgrade be performed on a computer with wired connection.
1.Write down all the settings which you changed from the default values, since you may need to reenter them manually.
2.Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop. The filename after extracting is R8000-V1.0.0.110_1.0.70.chk
Download Link:
http://www.downloads.netgear.com/files/GDC/R8000/R8000-V1.0.0.110_1.0.70.zip
3.Log in to the router using a Web browser. The URL is http://www.routerlogin.net.
4.Click ADVANCED tab > Administration > Firmware Upgrade.
5.Click Browse and find the file you just downloaded.
6.Click Upload. Do not interrupt the upgrade while the router does this step.
Important Note:
1.The upgrade process is completed when the on screen progress bar completes. If power LED light turns amber and blinking, power cycle the router to complete the upgrade.
2.If the upgrade progress bar on web GUI doesn’t display correctly during firmware upgrade, you can still check the status using Power LED. The Power LED should be blinking (amber) during firmware upgrade. After firmware upgrade is done and boots up the system, it changes to steady amber color.
Please DO NOT power off or reboot the device during firmware upgrade, otherwise, it may result to a corrupt firmware and cause the device not to work.
只看该作者 5楼 发表于: 2015-06-08
一句话 折腾 蛋疼 ipv6
