  • 4944阅读
  • 2回复
求ic-756pro3和电脑连接的办法 [复制链接]
离线李彬
只看楼主 倒序阅读 0楼 发表于: 2014-05-08
搞了好几天了,怎么也连不上,买的线应该没问题,驱动应该也没问题,用的是hamradio5.24版本的软件,用串口精灵监视串口有读写,就是连不上请高手帮忙。
串口精灵监视数据如下:
序号,时间,进程(PID),IO类型,COM口,数据长度,数据,
1,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_CREATE,COM9,0,,
2,23:16:32,HamRadioDeluxe.exe(4424),IOCTL_SET_QUEUE_SIZE   ,COM9,8,
    QueueSize.InSize: 1024, QueueSize.OutSize: 1024,
3,23:16:32,HamRadioDeluxe.exe(4424),IOCTL_SET_BAUD_RATE    ,COM9,4,
    9600,
4,23:16:32,HamRadioDeluxe.exe(4424),IOCTL_CLR_RTS          ,COM9,0,,
5,23:16:32,HamRadioDeluxe.exe(4424),IOCTL_CLR_DTR          ,COM9,0,,
6,23:16:32,HamRadioDeluxe.exe(4424),IOCTL_SET_LINE_CONTROL ,COM9,3,
    WordLength: 8
    StopBits: 1
    Parity:0(None)
7,23:16:32,HamRadioDeluxe.exe(4424),IOCTL_SET_CHARS        ,COM9,6,
    Chars Eof: 0, Error: 63, break: 63, Event: 0, Xon: 17, Xoff: 19,
8,23:16:32,HamRadioDeluxe.exe(4424),IOCTL_SET_HANDFLOW     ,COM9,16,
    DCB.fRtsControl=RTS_CONTROL_DISABLE
    DCB.fDtrControl=DTR_CONTROL_DISABLE
    DCB.fDsrSensitivity=FALSE
    DCB->XonLim: 341
    DCB->XoffLim: 341,
9,23:16:32,HamRadioDeluxe.exe(4424),IOCTL_CLR_DTR          ,COM9,0,,
10,23:16:32,HamRadioDeluxe.exe(4424),IOCTL_CLR_RTS          ,COM9,0,,
11,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,7,
    FE FE 6E E0 19 00 FD  | ttnà\#0y,
12,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
13,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
14,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
15,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
16,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    19  | ,
17,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    00  | \#0,
18,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
19,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
    FE FE 6E E0 03 FD  | ttnà\#3y,
20,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
21,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
22,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
23,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
24,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
25,23:16:32,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
26,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
27,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
28,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
29,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
30,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
31,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
32,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
33,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
34,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
35,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
36,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
37,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
38,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
39,23:16:34,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
40,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
41,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
42,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
43,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
44,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
45,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
46,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
47,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
48,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
49,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
50,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
51,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
52,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
53,23:16:36,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
54,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
55,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
56,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
57,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
58,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
59,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
60,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
61,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
62,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
63,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
64,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
65,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
66,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
67,23:16:38,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
68,23:16:40,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
69,23:16:40,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
70,23:16:40,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
71,23:16:40,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
72,23:16:40,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
73,23:16:40,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
74,23:16:40,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
75,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
76,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
77,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
78,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
79,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
80,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
81,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
82,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
83,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
84,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
85,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
86,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
87,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
88,23:16:42,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
89,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
90,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
91,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
92,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
93,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
94,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
95,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
96,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_WRITE,COM9,6,
97,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
98,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FE  | t,
99,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    6E  | n,
100,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    E0  | à,
101,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    03  | \#3,
102,23:16:44,HamRadioDeluxe.exe(4424),IRP_MJ_READ,COM9,1,
    FD  | y,
103,23:16:46,HamRadioDeluxe.exe(4424),IOCTL_CLR_DTR          ,COM9,0,,
104,23:16:46,HamRadioDeluxe.exe(4424),IOCTL_CLR_RTS          ,COM9,0,,
106,23:16:46,HamRadioDeluxe.exe(4424),IRP_MJ_CLOSE,COM9,0,,
只看该作者 1楼 发表于: 2014-05-09
机器的串口速率设置跟软件的一样吗?
离线李彬
只看该作者 2楼 发表于: 2014-05-09
一样,从1200试到19200
