As you can see, instead of using connectors, I pulled the RTL USB connector off, as well as the SMA connectors on the upconvertor board and wired it up directly. Instead of an SMA antenna input, I switched to BNC which matches more of my stuff, and wired a panel mount to the upconverter board.
