To count for IOTA islands need to meet a few simple rules relating to location. They must not lie in rivers, inland lakes or seas, or largely enclosed bays. They must be a minimum distance from the mainland. And they must be either 1 kilometre in length or shown on a 1:1,000,000 scale map. Islands world-wide that meet these requirements are listed in this Directory. They are grouped wherever possible since they are far too numerous to be allowed to count separately. If you cannot immediately find the island you want in the list, look for the officially recognised island group name, e.g. the Canary Islands if you want to find Lanzarote. Where there is no officially recognised group, an IOTA group name is often given to cover a range of islands in a particular geographical sector. Look through these, possibly with an atlas to hand. If the island qualifies for IOTA, it will be covered by a group in the list and will be named.
IOTA岛屿算需要满足一些简单的规则有关的位置。他们不应该躺在内陆河流,湖泊或海洋,或大海湾。他们必须从大陆的最小距离。他们必须是1公里长的或在1:1000000比例尺地图所示。全球范围内的岛屿,满足这些要求都在这个目录中列出。他们将尽可能因为他们太多可以单独的计数。如果你不能马上找到你想要的列表中的岛屿,寻找官方认可的岛群的名字,例如加那利群岛,如果你想找兰萨罗特岛。在没有官方认可的组,组名通常是有一点的覆盖范围在一个特定的地理领域的岛屿。看看这些,可能与阿特拉斯手。如果IOTA岛,它将在列表中一组覆盖和将被命名为。
[ 此帖被BH8BJO在2013-07-29 23:53重新编辑 ]
