  • 9358阅读
  • 28回复
你和飞机上的业余电台做过QSO吗? [复制链接]
离线BG4CZX
只看楼主 正序阅读 0楼 发表于: 2013-02-24
前两天在国外的DX网站上看到了PH9HB写的一篇文章,他是一名民航飞机的飞行员,同时又是一个狂热的DX爱好者,甚至在驾驶民航飞机的途中也不忘用民航专业HF电台在业余波段上出来和地面上的火腿通联。他的文章让我回忆起了2008年夏天我与两位飞行员火腿的通联经历(分别为N4RK-AM和NQ4I-AM),通联的时候,N4RK正驾驶着美联航的一架波音777客机执行日本到泰国的航班任务,而NQ4I则驾驶着一架湾流公务机飞行在蒙古国上空。这两次和机长的QSO是我不可多得的通联经历,不知道大家有没有类似的和特殊的业余电台通联的经历在这里可以一起分享呢?
下面是PH9HB的全文:( 来源:http://www.dxcoffee.com/eng/2012/07/09/ph9hbam-amateur-radio-cloud/ )
Amateur Radio from Cloud Nine (蓝天上的业余电台)
Among the operational suffixes that amateur radio is acquainted with, one is quite rare, but probably the most fascinating. We’re talking about /AM, Areonautical Mobile, which basically refers to a station with wings, and this underscores it’s overall appeal. From Icarus on, mankind has always been attracted to being able to glide through the air, and operating a radio under such circumstances (and therefore working a station under such circumstances for corresponding earthbound stations) provides for a highly emotional and fantasy-filled experience.
Not all Countries allow /AM operation under existing amateur radio regulations. Some, however, do, and that’s how this suffix sometimes happens to be heard on the airwaves. The “flying patrol” of colleagues includes Jerry van der Goot, PH9HB, who is a Boeing 737NG Captain for a Dutch carrier based at Amsterdam-Schipol, and often goes /AM during his flights.
The intrigue surrounding this particular method of operating a ham station is multifaceted, and lends itself to a varied perspective: technical, practical and human, certainly enough to make us want to get in touch with Jerry and ask a few questions which consequently received interesting and thought provoking answers. So, fellow passengers, please fasten your belts and get ready for takeoff. We’re about to climb the /AM world.
How (and when) you did become a ham? And a pilot? And, most of all, when did you decide to put the two together and start operating /AM?
At the age of 12, I was a member of the Boy Scouts. It was back in 1977 when I participated for the first time in the JOTA (=Jamboree On The Air). This was my very first encounter with our great hobby and I got infected immediately. I passed my exam 8 years later on April 1st, 1985 (this is not a joke!). My first call was HB9SJL.
After I finished my education, I realized that working nine to five is not my thing. In 1987 I went to the US and started my flight training to become a commercial pilot.
Due to education, work and other interests, I was an inactive HAM for over 20 years. When our boys (we have twins) needed less attention, I was looking for a hobby that could be done from home…
It was in the summer of 2008 that I applied for a Dutch call sign which was issued on July 21st. Many people ask me about my prefix. Obviously PA is known to most of us, but like in many other countries, the Netherlands has more than that…!
Because PA is not “unique”, I chose PH since all aircraft registered in the Netherlands have this immatriculation. Having lived in Switzerland for over 30 years, HB9 had come at the end, thus PH9HB.
Do you still remember your first QSO from above the clouds? On what band, and from which plane was it?
My first QSO from a Boeing 737 was on  July 25th, 2008 at 21.38Z over Belgrade on 14.173MHz. We were at 11000 meters above sea level, and I spoke with RV9LM, Alex in west Siberia.
You currently pilot passenger flights, and undoubtedly safety comes first. What conditions do you have to comply with to be allowed to operate /AM?
The Netherlands is one of a few countries that does not forbid aeronautical mobile operation. Obviously work/safety come first. Therefore I only operate the HF radio when duties permit. This is usually at cruising level in smooth conditions and only on longer flights.
Can you briefly describe the equipment you use to work from the plane? What are the main differences with a home rig (and the limits, if any)?
The onboard equipment consists of two Collins HFS900D with 400 W PEP and covers 2-30 MHz in 1 kHz steps. The antenna is mounted on the leading edge of the fin/vertical tail, and is of the shunt-fed-slotted type [note: this linkprovide more info on this particular type of aerial]. Normally, we use HF to get in touch with air traffic control (ATC) when there is no VHF coverage, i.e. over the Atlantic or over parts of Africa and Asia. The set comes with AM and USB and that’s it! Filters are not made for HAM use, and therefore when many stations call me at the same time I cannot understand much… In those situations I wish more operators would comply with the “Dx Code of Conduct” but unfortunately that seems to be a big dream!
Propagation-wise, what have you noticed in your /AM experience, compared to working HF from the ground? Is high altitude always an added value?
Propagation seems to be very similar to that on the ground. In theory, from 11 km I should be able to work all stations in a radius of approximately 450 km, but that is not always the case.
How many QSOs do you usually manage to do per flight?
On average about 40 contacts per flight, depending on duties, flight time and last but not least: propagation!
What’s the most distant contact you’ve made so far from a plane? And have you ever worked, while flying, another /AM, or a /MM, station?
Furthest contact from the plane must be VK/ZL. On a regular basis I work with Cyril, DF1CHB/am, when we happen to be in the air and on the air at the same time…
How can any ham wanting to work you, stay current regarding your /AM operations?
Anyone registered to my Twitter account gets updates on my /am activities. There are a few frequencies I operate on a regular basis: 14.325 14.165 18.165 and very seldomly USB channel 7.185 MHz not many operators are aware of these dedicated USB-channels these days…
Usually pilots have many “cockpit tales” to tell. Anyone ham radio related ones for you?
When I had my first QSO with Eddy, YU9XMC, I happened to fly over his house. It was just getting dark and he had difficulties to spot us in the air, so I quickly switched on the landing lights…
Is amateur radio popular in the aeronautical community? Are you in touch with other pilots operating /AM? Have you ever thought about creating an association or club for “winged hams”?
There are some pilots working /am but they are getting rare because many airlines get rid of their HF equipment when the routes they fly do not require it.
What are you feeling when working HF at an altitude of 11.000 meters?
It is great to do our hobby during work and even get paid for it…!!!
From your QRZ.com profile it appears you’re also an active operator from the ground. In this case, what are your preferences (in terms of modes, especially)?
I like to use as many languages as possible, therefore I prefer phone. I might try digi modes and CW one day, but being able to use different languages interests me most!
I am a founding member and QSL-manager of our contest team PA6NH. We are radio-active during some major HF contests and the PACC, representing the province of NH (=Noord Holland).
Your main three reasons why anybody would just have to love ham radio…
First, you can still find the good old ham-spirit. Then, meeting people with similar interests all over the world is just great. In the end, making friends on the air and getting to know them in person one day is the best!
[ 此帖被BG4CZX在2013-02-24 23:11重新编辑 ]
BD4CZX (US callsign: AF5JW)
Class B Ham Radio Operator's Certificate
Member of BY4BSJ 1998--2000
Member of BY4CSR 2001--2003
QSL info search:  www.QRZ.cn
QSL info search:  www.qrz.com/db/BD4CZX
离线bg3gru
只看该作者 28楼 发表于: 2013-04-04
用的什么频率啊
手机 15548101567
QQ    59008316
离线BD4VZ
只看该作者 27楼 发表于: 2013-03-19
郑州局的HAM!小心值乘的时候通联有检查组的办你!郑州据说管的很严但钱不多发!哈
离线BG4CZX
只看该作者 26楼 发表于: 2013-03-09
回 bd4ahs 的帖子
bd4ahs:楼主满血复活鸟?!
小人造了吗? (2013-03-08 14:38)
现在还是没时间上台啊,多造几个再说
离线BD7OXR
只看该作者 25楼 发表于: 2013-03-09
回 bg6mak 的帖子
bg6mak:我是火车司机,经常带着817在行车中通联,希望大家能跟我通上!! (2013-03-08 21:09)
不错哟,开火车还能玩电台!
呼号:BD7OXR (EX  BH7OXR)
电话:幺山漆幺幺山山吾林吾酒
地址:QRZ.cn
Q Q:1885639
邮箱:bd7oxr@126.com
离线BA2Bi
只看该作者 24楼 发表于: 2013-03-08
火车的还真没通过
/AM /MM 都通过
离线bg6mak
只看该作者 23楼 发表于: 2013-03-08
离线bg6mak
只看该作者 22楼 发表于: 2013-03-08
离线bd4ahs
只看该作者 21楼 发表于: 2013-03-08
楼主满血复活鸟?!
小人造了吗?
BD4AHS
ex: BG4AHS、BG1HS/4、BG1HS、BG1-1-0817
秦岭/Qinling
96-97年 BG1-1-0817
97-99年 member of BY1BY / BG1HS
99-2000年 BG1HS/4
2000-2006年 BG4AHS
2006年~ BD4AHS
QTH: http://aprs.fi/?call=BD4AHS
离线BD7OXR
只看该作者 20楼 发表于: 2013-03-07
很难遇到的 /am 通联,祝贺你们你有这样的好运气!
电话:幺山漆幺幺山山吾林吾酒
地址:QRZ.cn
Q Q:1885639
邮箱:bd7oxr@126.com
离线BG4CZX
只看该作者 19楼 发表于: 2013-03-06
回 BG7RMD 的帖子
BG7RMD:和4区一位民航驾驶员通过。当时他驾驶747从越南上空飞过,往上海方向。 400W功率与我通上! 印像非常深刻! (2013-03-06 17:00)
您还记得他的呼号吗?
离线BG7RMD
只看该作者 18楼 发表于: 2013-03-06
   EX:BG7RMD
离线BG4DYH
只看该作者 17楼 发表于: 2013-02-28
回 bg1tcs 的帖子
bg1tcs:民用航空通信业务分分秒秒关系到数百人的生命安全,事关各个相关方面数十上百亿元巨额财产安全,请有兴趣的朋友慎重。 (2013-02-28 10:44)
多滤了,说的根本不是一.码事
霸道是导演黄 ex.BG4DYH
设备:原装yaesu 杂散“被”不过关设备若干
天线:杂牌自来水管一根(废品回收站称重购得)
高度:88米
地址:中国 上海 233-599信箱 邮编:200233
联系电话:妖散酒灵妖酒吧误把腰闪
QQ:舞而灵尔,救起巴旗
回卡原则:来卡必回.
通联过的回通联卡,没通联过的回纪念卡.
欢迎来卡!
在线BD7JAC
只看该作者 16楼 发表于: 2013-02-28
回 bg1tcs 的帖子
多虑了,HAM都是在业余频段,无论天上还是地面的HAM,都不会跑到民航通信的业务频率去做业余的QSO。
读万卷书心中不留一字,行千里路忘尽途中影子!
EX:BG7JAC、XX9TJC
OL51EG   TEL:棕橙紫黑红灰紫蓝蓝红灰
Email:bd7jac艾特chinaham.org
在线BD7JAC
只看该作者 15楼 发表于: 2013-02-28
我和BG7IBY/AM通联过,但这家伙一直没有给卡片我。下次我再上去的话,也带个手台上去试试看能否打开周边几省的中继。
EX:BG7JAC、XX9TJC
离线BA5CJ
只看该作者 14楼 发表于: 2013-02-28
NQ4I/AM我也有一张卡片
EAIL:BA5CJ艾特CHINAHAM.ORG
QQ:191肆57贰87
离线bg1tcs
只看该作者 13楼 发表于: 2013-02-28
离线BD4CB
只看该作者 12楼 发表于: 2013-02-27
楼主复活了?
离线bg9kr
只看该作者 11楼 发表于: 2013-02-27
某年灰机低灰到某城上空时用手台试了一下,打不开中继
一人一车一电台
离线bg3dbu
只看该作者 10楼 发表于: 2013-02-26
上面的弟兄都牛! 俺还真没与飞机业余电台QSO过,专业台到通了不少。
CSKC   0008
呼号:BD3DBU
姓名:0491 1696 0948
邮编:300180
电话:AWAWUATGBSG
一名刚加入HAM队伍的新兵。
