本次Logger32的版本更新,其重大功能改进点就是添加了电台控制面板,据说还提供了频谱显示。(可惜我手边没有电台,试不了)
新功能估计也会有很多新BUG,各位老少爷们多多包涵!有问题可以告诉我,我去反馈给Logger32的开发组成员。
Logger32的新版具体更新说明如下,英文的,没时间翻译了,抱歉。
Changes for Logger32 version 3.43.0
1) Added: "Radio Control Panel"
2) Bug Fix: Quick QSL window did not immediately update the Logbook.
3) Change made to the logic used for: "Adjust DX Spot for audio frequency".
4) Changes to DX Spot History Window.
Now detects the mouse scroll wheel
Sizeable up to 20 lines.
Supress audio alerts being triggered when clicking on a DX Spot in the history
window
Added more color capability.
Colors change in real time (just like the DXSPot window and the band maps).
Now functions without the necessity for a radio CAT connection
5) Expanded menu options under CONFIG
6) Bug fix: Internal callsign and QRZ lookup
7) Bug fix: DX Spot window did not always show "X" for previously worked stations
8) Changes to the Alpha 87A Window
9) Bug fix: Clicking in dx spot from the telnet window did not set the radio and populate the callsign field in Entry window.
10) Informational logbook entries are now excluded from the eQSL and ClubLog real-time feed.
11) Change made so the LoTW, QSL and eQSL file. Exports DO NOT include logbook informational entries
12) Added user selection to show tooltips in the DX Spot history .
13) Bug fix: County is shown on the Call Entry Pane but is not saved to the logbook.
14) Bug Fix: Opening the Quick qsl screen cleared the worked/confirmed window.
15) Change made to provide real time update to the Logbook & Worked confirmed windows following a QSL update
16) Bug fix: Allows "Conversion" pane to remain open while navigating to other Child windows.
17) Added Setup menu "Hotkeys", Allows user to select which hotkeys are set for Global functionality.
18) Added option to sound card MMVARI settings: FFT Display amplitude
19) Bug Fix: QSO B4 code not working properly.
20) Implemented Macro $callchanged$ in the CWM.
Logger 32 Version 3.43.000
2012 Nov 06
Countries / Prefixes Database Updates
** Removed TX5 from the list of alternative prefixes for FH (Mayotte)
** Added specific callsigns:
<TX5M> FH (Mayotte)
<TX5NK> FH (Mayotte)
<TX5T> FH (Mayotte)
<TX5FS> FK (New Caledonia)
(TO9R> FM (Martinique)
<TX5K> FO\C (Clipperton Island)
<TX4FO> FO\P (French Polynesia)
<TX5EG> FO\P (French Polynesia)
<TO2A> FY (French Guiana)
** Thanks to Constantin, UA1AKE
Bud, W2RU
Keeper of the C/P Database
