  • 3306阅读
  • 5回复
Announcing the IOTA contest-2011‏ [复制链接]
离线BD2RJ
只看楼主 倒序阅读 0楼 发表于: 2011-07-23
收到的邮件,转发一下。
this year’s iota contest will take place, as always, over the weekend of 30/31 july, 1200 to 1200 utc. full rules, unchanged since last year, can be found at: http://www.rsgbcc.org/hf/rules/2011/riota.shtml this page also contains a link to a “help for newcomers” page. we hope to see many old and new participants in this year’s contest. the first three in most categories will receive a certificate, and there is a wide range of trophies available. see last year’s trophy winners at: http://iotacontest.com/contest/iota/2010/trophywinners.html uk stations should also note that there is a new trophy this year, sponsored by cdxc (chiltern dx club) in memory of henry lewis g3giq, who was always a staunch supporter of iota. the trophy is for the leading uk 24-hour ssb, single-op, to match the trophies already available for 12- and 24-hour cw and 12-hour ssb. we do hope that many uk operators will enter this category, with a view to winning this prestigious new trophy. all the major logging programs support the contest. if you don’t have anything suitable, try sdi by ei5di, available for free download at http://www.rsgbcc.org/hf/sd.shtml finally, we would ask all entrants to respect the contest bandplans, which aim to create space for others wanting to use the bands over the contest weekend. penalties will be applied for non-compliance. if you have any questions, please address them to iotacontest@rsgbcc.org logs should go to iota.logs@rsgbcc.org if you do not receive a reply from the robot, then your log has not been received – please try again. 73, cu in the contestdon g3xtt (contest manager), jim mm0bqi (adjudication and certificates), marios g0www/5b4wn (software), john g3lzq (trophies)
离线BD7OZG
只看该作者 1楼 发表于: 2011-07-23
收到邮件了
前面排了一大堆名字
后来又收到一封同样的
不过是致歉的
服务质量还是不错的。
离线BH1MAD
只看该作者 2楼 发表于: 2011-07-23
收到的邮件,转发一下。
学习一下!
离线BD1BYV
只看该作者 3楼 发表于: 2011-07-23
楼主准备去哪里活动
离线BD2RJ
只看该作者 4楼 发表于: 2011-07-23
还是去年那地---151长兴岛,今天下午看了场地,不错的。发现了pla,担心比赛时干扰到我。
离线BG4AHF
只看该作者 5楼 发表于: 2011-07-24
非常高兴的看到我们居然是排第一个的
不知道按照什么顺序来排的
