  • 5910阅读
  • 6回复
Kenwood TH-D72的扩频资料 [复制链接]
离线米宝爸爸
只看楼主 倒序阅读 0楼 发表于: 2011-01-19
kenwood th-d72 extended tx mod
其实只要把图里显示的d729二级管去掉就可以了。
扩频后发射:142-151.995 mhz 420-449.975 mhz
这个我估计很有可能是d72a的扩频方法,d72e是否适合还需测试。
原帖地址: http://www.worldwidedx.com/kenwood/85009-kenwood-th-d72-extended-transmit-mod.html
here is how you modify the th-d72 to transmit out of the 2m/440 band:
1.take the radio apart by following this sequence of steps:
2.remove the battery.
3.remove the antenna and pull off the top dial knobs
4.remove the two screws on the back.
5.unlatch the rubber ports cover from the post on the back. use a small screwdriver to slip under and it just pops off.
6.pull the case up and off.
7.detach the rubber button cover from the front and set it aside.
8.at the bottom front of the circuit board, below the number button pads, there is a small diode labeled d729. remove that diode shown in this pic:
离线dingding
只看该作者 1楼 发表于: 2011-01-19
貌似国外的资料是另一个,深圳某个ham论坛有贴图。
离线i86net
只看该作者 2楼 发表于: 2011-01-20
d72扩频,资料来自mods.dk
动完硬件reset机子
离线BH1AYY
只看该作者 3楼 发表于: 2011-01-21
太恐怖了,不扩了
离线BG6JJI
只看该作者 4楼 发表于: 2011-01-21
会了就不难
离线BG4BWP
只看该作者 5楼 发表于: 2011-01-21
不错!移除比焊上要简单,哈哈!
离线bh3uwf
只看该作者 6楼 发表于: 2017-03-22
已经扩频了
