请有经验的大大讲解一下,如果给ic7000和ft857d共用的话(不是同时使用),哪个性价比高一些?两者只能取其一。
预计使用频率60%在户内,40%户外。户外使用时多以ft857d为主,可以同时兼顾“温顿”和“yp3”,户内使用以ic7000为主,天线是多波段gp.
但也不排除ic7000到户外接“温顿”和“yp3”的可能。。。咋办。。。
z-11proii:
# 0.1 to 125 watt power range (ssb and cw), 100w on 6m.
# easy to read led display for swr and status.
# 2000 memories for instantaneous band changing.
# tuning time: 0.1 to 6 seconds full tune, 0.1 seconds memory tune.
# selectable user parameters: auto/semi, threshold, and more.
# 1.8 to 54.0 mhz coverage. built-in frequency sensor.
# tunes 6 to 1000 ohm loads (16 to 150 on 6m).
# for dipoles, verticals, vs, beams or and coax fed antenna.
# optional external balun allows tuning of random length, long wire or ladder line fed antennas.
# includes dc power cable, icom interface and coax jumper.
# power requirements: 6 to 16 volts dc at 300 ma max. 25 ua standby current.
# user installable 4-aa battery holder (not supplied).
# small size enclosure: 7.7l” x 5.0w” x 1.5h”. weight: 1.5 pounds.
note for use with ft-857(d) or ft-897(d): if you plan to use vhf or uhf, these two radios may transmit a small amount of vhf/uhf rf energy out of the hf connector and will fool the tuner into tuning. not all radios do this. this anomaly with the radio does not hurt the radio or the tuner. simply turn off dc power to the tuner or place the tuner into semi mode if the issue becomes too annoying.
at-100proii:
# 1 to 125 watt power range (ssb and cw), 100w on 6m.
# easy to read led bargraph display for rf power, swr, status. led indicator for antenna selection and bypass.
# 4000 memories for instantaneous band changing.
# two position antenna switch. separate memories for each antenna.
# tuning time: 0.5 to 6 seconds full tune, 0.2 sec memory.
# selectable user parameters: auto/semi, 125/12.5 watt scale, autotuning threshold and more.
# tunes 6 to 1000 ohm loads (16 to 150 on 6m),.
# includes dc power cable, icom interface cable and coax jumper.
# power requirements: 11 to 16 volts dc at 500 ma max.
# small size enclosure: 7.5” x 5.5” x 2.0”. weight: 1.5 pounds.
