首先,调节电键边上的两个调节螺钉,使电键触点对齐.同时,使得电键的梁可以自由运动,但又不松垮.
第二部分,(把弹簧上的调节螺钉放松,但不要全放松,留意点弹力)调节键梁远端的螺钉,设定合适的触点间距.一般是一张至几张纸的厚度;然后调节弹簧上面的螺钉,压紧弹簧时,打键力会加打,电键手感硬,打键力撤销后,触点迅速分离,有利于快发操作:反之,电键手感软.这两步调节,直到你的手感舒服为止.
第二部分的两个调节非常灵活,主要是根据操作者的手感和需要而定.
使用完毕后,应把弹簧上的调节螺钉放松,避免弹簧和键梁疲劳变形.
以上内容是根据自己学习的体会和参考下文所得,仅供你参考,并请不吝赐教!
参考全文
http://home.windstream.net/johnshan/cw_ss_straight_key.html主要部分:
in adjusting the key, the side set screws should be adjusted so that the contact points (or platina points) come together squarely. once that is achieved, they should be adjusted so the key lever moves freely, but does not wobble. once that adjustment is made, the set screw at the far end of the lever is adjusted to set the spacing of the contact points. i prefer a fairly close setting, perhaps two thicknesses of paper versus the three to five thicknesses mentioned in the book. finally the set screw at the spring is adjusted to give a good feel to the key closure. i prefer a somewhat strong spring setting so the contacts snap apart quickly when i release pressure on the key-button. the last two adjustments i mentioned are pretty much up to the personal feel of the operator.
