  • 14612阅读
  • 42回复
LINK-ALL新版驱动V5.1 [复制链接]
离线BA3OE
只看该作者 40楼 发表于: 2010-10-30
windows xp/server 2003/vista/7 (v6.1)
version 6.1
     corrections
     corrected a memory leak which could bog the system down after extended use of a contiuously
     opened com port, and conditionally yield bluescreens on certain systems
     corrected a problem where an io reqest would sometimes return a busy status to
     user mode, instead the queue is restarted if necessary before adding an io request
     to the queue
     corrected a condition which would blue screen on cancelling write request that hasn't been
     fully sent out usb
     corrected the capabilites return value, which incorrectly reported that timeouts are not supported
     corrected several queue size return values, which affected behavior in the mscomm control
     corrected dtr/rts value on device insertion, visible when serial enumeration is disabled
     corrected the ability to override baud rate and line control from the inf file
http://www.silabs.com/support%20documents/software/cp210x_vcp_win_xp_s2k3_vista_7.exe
离线BG2UE
只看该作者 41楼 发表于: 2011-07-13
download for windows xp/server 2003/vista/7 (v6.3a)
the cp210x manufacturing dll and runtime dll have been updated and must be used with v6.0 and later of the cp210x windows vcp driver. application note software downloads affected are an144sw.zip, an205sw.zip and an223sw.zip. if you are using a 5.x driver and need support you can download archived application note software.
离线BG2ITG
只看该作者 42楼 发表于: 2011-11-15
补充下载地址
http://www.silabs.com/products/mcu/pages/usbtouartbridgevcpdrivers.aspx
点击 vcp driver kit 这行即可下载最新驱动
