[quote=bg2cw/7]以前dds3的板子能用吗?[/quote]
it required a few changes from dds 3.xx for pcb deisgn use dds3.xx or dds 2.xx designs
dds 3.xx 的pcb需要很少的修改
changes required in the circuit of dds 3.xx
1. remove 74ls139 but keep resistor on ra4
2. remove connection on rb1, and rb2 connect these to pic-2 serial port
3. disconnect lcd pin 4 (rs) from sw3..sw6 common, and connect to ra6
4. connect sw3..sw6 (i.e. rit/ssb/step/cal) common to ra7
done!.
pic 2 connections
1. connect pic 2 serial to pic 1 serial port, i.e. rb1 to rb1 and rb2 to rb2
2. connect vdd (+5v) on pin 14 and ground (0v) on pin 5
3. connect a pull up resistor on ra4 (4k7) to vdd
band out puts are (pic-2)
rb0 general coverage
rb3 band 1
rb4 band 2
rb5 band 3
rb6 band 4
rb7 band 5
ra6 band 6
ra7 band 7
ra0 band 8
ra1 band 9
mode selection
am - ra4 on pic-1
cw - ra2 on pic-2
lsb - ra3 on pic-2
usb - ra4 on pic-2
ra5 left unconnected
