  • 68975阅读
  • 183回复
FT-991让我欢喜让我忧!!! [复制链接]
在线BA7CK
只看该作者 100楼 发表于: 2015-06-05
八重洲上海公司昨天才知道此事,已经开始处理。
离线BG4PVI
只看该作者 101楼 发表于: 2015-06-05
回 BG4THO 的帖子
BG4THO:991用了几天,有个BUG:当U、V段工作并执行过“SWEEP"频谱按钮操作后,再切回到HF频段(包括AIR、MW)时会出现无声,只能关机重启才恢复。
 (2015-05-23 12:34)
同样我也出现这个问题
离线BG4THO
只看该作者 102楼 发表于: 2015-06-05
回 BG4PVI 的帖子
BG4PVI:同样我也出现这个问题 (2015-06-05 10:03)
发现此类问题后已经及时与苏州YAESU 进行了反映,他们会向总部汇报情况
de BD4TH  (EX:BG4SEZ、BG4THO)
朝赴姑苏城外,暮归锡惠山下。
离线bg1uzj
只看该作者 103楼 发表于: 2015-06-05
回 BA7CK 的帖子
谢谢陈大大关注,一直打的都是八重州4006820079客服电话,这个说是售后客服。要是上海总部刚知道就证明售后根本没有反应此事给总部,口口声声告诉我高曾早就知道,就等日本回复!他们前天联系我购买的处的经销商说是测试后机器没有任何问题,只是驻波显示有一点点高与实际对此,说我提供的数据不准确怀疑我测试设备和数据。我要求前去苏州技术中心方面测量,他们说不接待客户本人。反正他们说了算。现在也不知道,这个说是上海八重州苏州技术中心到底是负责什么的,上海居然不知道事?
离线bg2sto
只看该作者 104楼 发表于: 2015-06-06
早已心仪,准备购买,
上网一查,问题来了,
等看结果,再下决心,
:107: 呼号:BG2STO
:107: 姓名:君无忌
:173: 电子邮箱:2929270@qq.com
八重州  FT891   天 线  PAC-12    MA -01
离线bg1uzj
只看该作者 105楼 发表于: 2015-06-07
来自eham!
The radio is good, but it could be better, it has some problem that I'm going to list:
1) Sometime the firmware fails, for example it happens that you call the memories and it show you an incorrect frequency for the selected memory, at the end you need to change band or switch off and on the radio to access the correct frequency in memory;
2) Sometime the firmware isn't able to read the correct tuning values (from the 100 memorized values) for the current frequency and you can have infinite swr, then you switch off and on again on the unit and all go well; it does not read the correct value even if you execute the tuning again on the current frequency, during tuning you can see that swr go less, but when you push the mike button in cw-ssb you have again infinite swr;
3) The CAT control via USB crashes if you press the mike button;
4) You can't memorize more than one shift per band, for example in 430Mhz where you can have repeaters with a shift of 1.6Mhz and others with 5 Mhz, you have to remember in mind the shift for every repeater that you put in memory and set it every time you need to use that repeater. This is a very bad thing!!
5) The atu has 100 memories, but I don't see their effects, the ATU is slow, very slow.
6) The atu doens't tune if you have more than 3.1 of swr, bad, very bad, in particulary if you have a long/random wire antenna;
7) It seems that the radio isn't good for a long/random wire antenna system, you need an external antenna tuner
离线BG5TLA
只看该作者 106楼 发表于: 2015-06-07
这两天测试了一下我的991UV段驻波显示情况,确实有楼主所说的情况,驻波显示无规律,有时外接驻波表显示1.5,机内驻波表都显示到2.5了,而有时外接驻波表显示1.5,机内驻波表却不起表。但愿这是991机子的软件问题,也希望八重洲公司能重视和解决此事。
呼  号:BG5TLA
地 址:福建南平
邮 箱:bg5tla@yahoo.com
设备: TG-UV2  X5105  FT-991
离线bg1uzj
只看该作者 107楼 发表于: 2015-06-08
希望拥有991的用户共同把问题反应给八重州。
离线王昊霖
只看该作者 108楼 发表于: 2015-06-08
不是说大陆出台新龟腚网购几日之内必须无条件退换么?楼主是实体店购买还是淘宝购买的?
离线BH4SQE
只看该作者 109楼 发表于: 2015-06-08
有幸拿到楼主的电台进行了如下的测试,(声明:本测试不代表任何厂家、个人之观点,仅是满足一下我个人好奇心。)
好吧,再贴些测试照片:
144MHz,50W输出功率。
147MHz,50W输出功率。
435MHz 50W输出功率。
440MHz 50W输出功率。
还有一假换载照片,楼下贴上。。
再次重申,不代表任何观点,只是为了满足好奇心而已。
~~~~~~~~~广告位招租~~~~~~~~~
离线BH4SQE
只看该作者 110楼 发表于: 2015-06-08
150W DC-1G假负载。
离线BA5AC
只看该作者 111楼 发表于: 2015-06-08
FT991不能任意存储频差严重不爽,希望固件有改进
浙江省杭州市临平区
吆三五88098920
古董ICOM IC-725 +C3S ANT ON AIR
离线BG5HIE
只看该作者 112楼 发表于: 2015-06-08
回 BA5AC 的帖子
BA5AC:FT991不能任意存储频差严重不爽,希望固件有改进 (2015-06-08 16:19)
AC老师也整了台?
离线BA5AC
只看该作者 113楼 发表于: 2015-06-08
回 BG5HIE 的帖子
BG5HIE:AC老师也整了台? (2015-06-08 19:44)
木有这个,上面那段洋文里看到的。
浙江省杭州市临平区
吆三五88098920
离线bh5hai
只看该作者 114楼 发表于: 2015-06-08
回 BH4SQE 的帖子
BH4SQE:有幸拿到楼主的电台进行了如下的测试,(声明:本测试不代表任何厂家、个人之观点,仅是满足一下我个人好奇心。)
....... (2015-06-08 15:44)
接天线测下,毕竟我们用电台时接的可不是假负载。
B1/BH5HAI
离线BG5HIE
只看该作者 115楼 发表于: 2015-06-08
回 BA5AC 的帖子
BA5AC:木有这个,上面那段洋文里看到的。[表情] (2015-06-08 20:08)
的确...这个存储太不科学了
离线bh5hai
只看该作者 116楼 发表于: 2015-06-08
回 BA5AC 的帖子
存成异频操作模式可以解决这个问题。
不同亚音值的中继存储就没办法了。
B1/BH5HAI
离线bg2xyw
只看该作者 117楼 发表于: 2015-06-09
才翻看完整个帖子及所有回复。991还在苏州维修中,刚开始玩短波,手头没有过多的专业设备测试,简单的描述下我的整个坎坷历程吧。
       机器到手后,HF驻波一直高居不下,开天调也无济于事。UV段驻波也是忽高忽低~基本在1.1~2.8之间。
       当时没有向大家一样考虑这么多,只是简单的以为是我的天线不好,我的馈线不好,我的使用和架设环境不好。
       7天后,第八天晚上下班回家,打开机器呼叫,无人应答。之后用手台直频测试了下,发现991接收有声音,讲话声音其它机器接收非常小。好吧,以为自己设置什么了,各种调也没好,重置菜单也没解决,一直到第二天晚上下班回家测试中发现,嘴贴着手咪讲话其它机器可以收到,离开话咪就无法收到。
       第二天立即联系售后,电话最后转接到苏州技术支持中心,告诉我说八重洲的机器质量都是很好的,不会出现这样的问题,问我是不是手咪坏了,给我快递过来一只全新的手咪,让我测试手咪是否有问题。好吧,找到当地的HAM帮我一起测试,最后确认了不是手咪问题。
       再次联系苏州技术支持中心,告知机器邮回去他们检测。邮回去机器一直没有消息,5天之后(6月12日)电话询问告诉我说等日本告知如何处理。在多次催促上海先景科技后,今天下午打来电话,告诉我机器有烧过的痕迹。已经给换了主板,尽快安排给我邮寄回来。。。
       另外机器不能存储频差,确实是非常的不方便。
因为本人水平有限,能力有限,不能像楼主一样做那么专业的测试。所以只能提供我的使用情况供楼主参考,同时等待能否有进一步的消息。这次机器邮回来都要开始犹豫还敢不敢继续使用了,万一再烧了哪里可怎么办。。机器毕竟也不便宜,不能刚买回来就三天两头的送回去修啊~这以后还怎么办。。。小弟已各种迷茫苦恼中~
离线bh5hai
只看该作者 118楼 发表于: 2015-06-09
回 bg2xyw 的帖子
bg2xyw:才翻看完整个帖子及所有回复。991还在苏州维修中,刚开始玩短波,手头没有过多的专业设备测试,简单的描述下我的整个坎坷历程吧。
       机器到手后,HF驻波一直高居不 .. (2015-06-09 00:02)
“机器到手后,HF驻波一直高居不下,开天调也无济于事”,请问所使用的HF天线的驻波是正常的吗?
B1/BH5HAI
离线bg2xyw
只看该作者 119楼 发表于: 2015-06-09
回 bh5hai 的帖子
bh5hai:“机器到手后,HF驻波一直高居不下,开天调也无济于事”,请问所使用的HF天线的驻波是正常的吗?
 (2015-06-09 00:09)
等这次机器修回来在试试机内驻波加大红点驻波表测试,之前机器刚到的那7天内,开天调HF驻波也在2.0以上,UV在1.1~2.8,有时候会出现红色警告。所以一直以为是自己的天线没调好或者是架设环境的问题,怕损坏机器也没敢长时间发射过,满功发射都比较少。更没有考虑过机器会有bug。之前使用的OUTBACK 2000多波段短波车载天线,另外有一副四波段倒v还未修剪,打算等这次机器回来用这两天线在测测。
