深深的海
:看过了,10米到20米的调整不需要截短啊,40米和80米需要截短那几根电容帽,还有就是这个天线必须要用纤绳固定,这在说明书里面也特别强调了, 请问您是在使用这款天线吗? 我发现我 ..
(2013-10-10 10:19)
原版说明如下:(只截取10米段的)
3a. If it favors the low end, shorten the 10-meter adjustment one inch or no more than 1 1/2 inches. Run another VSWR measurement.Now you will have an indication of how far that distance moved the antenna in your location. Make what additional adjustments are indicated by the VSWR curve to put 10 meters exactly on the portion of the band you desire as your center operating frequency.
你自己看一下~
缩短1英寸不超过1.5英寸再次测量~通过计算就可以确定该缩短多少了~
