  • 8855阅读
  • 29回复
【LOGGER32】V3.40.43-2012.07.01发布通告 [复制链接]
离线BD4EP
只看楼主 倒序阅读 0楼 发表于: 2012-05-06
时隔近三个月,V3.40.0总算发布了!
【注意】7月1日有新的修正版发布V3.40.43!请大家注意更新,每下载的请直接下载新版本!
V3.40.43完整安装包下载:
http://www.logger32.net/files/lgr32full34043.zip
V3.39.0,V3.40.* -> V3.40.43升级包:
http://www.logger32.net/files/lgr32upgrade34043.zip
【特别说明】
V3.40.* 专用升级包(尚未上传,目前共享的仍然是3.40.11,最近有时间一定做出来):
http://vdisk.weibo.com/s/81RTd
为了减轻频繁升级的压力,如果您刚刚升级了V3.40的任意版本,可以只下载LOGGER32主执行文件和发版说明文件压缩包,解压后释放到LOGGER32程序目录,覆盖原文件即可。这是我特别给中国的HAM准备的。供大家使用,这个包很小,才2M左右。
V3.40.0简体中文汉化包下载:
http://www.logger32.net/files/BY340.zip
V3.40.0繁体中文(湾湾版)汉化包下载:
注:
1. BX4BF已经回复了估计后期版本的繁体版汉化还是有希望的。呵呵。
2. V3.40.43应该是V3.40.*的最后一个版本,接下来就要等V3.41的发版了。
3. 前几天远程终端K4UGA服务器罢工了,跟LOGGER32程序没啥关系,最近已经回复。
[ 此帖被BD4EP在2012-07-08 02:59重新编辑 ]
呼号:BD4EPV
绰号:BD4EP
CSKC-404
Email:bd4epv(a)chinaham.org
离线BD4EP
只看该作者 1楼 发表于: 2012-05-06
照旧,贴一下新版更新说明:
Release change notes for Ver 3.40.0 as of....... 14 Apr 2012 ================================================
1) Change made to award database update procedure.
2) Change made to improve updating of Admin Subdivision info and award status.
3) Added: DXCC export file.
QSOs using SSB, AM and FM will be flagged as submitted for DXCC, DXCC_MIXED and DXCC_PHONE.
QSOs using CW will be flagged as submitted for DXCC, DXCC_MIXED and if the QSO date is within range DXCC_CW
QSOs using evey other mode will be flagged as submitted for DXCC, DXCC_MIXED and DXCC_RTTY
4) Added: $call$ & $band$ MACROs to Telnet window. Telnet shortcuts now accept $call$ (used the same way as Sound Card Data Window Macros).
5) Added  QTH field to the "Fields to transfer on click/autolookup"
6) New CW Macro: $winkeymergeletters$ added.  To send concatenated letters with a winkey enter a macro like this ... $winkeymergeletters$BT   This sends <ESC>BT to the winkey
7) Added a new menu added to the DX Spots Window, SETUP | APPEARANCE | SHOW STATION QSOD B4)
8) ADDED: New menu items on the Download LoTW Window
9) Added new menu item under SETUP | DX SPOTS. This allows DX Spot to be generated from the Local Hosts.
10) Database change: The BandMode32.db file is no longer used by Logger32.  When starting Logger32 a check is made to see if MyBandMode32.db exists.  If not, a copy of BandMode32.db is made and named MyBandMode32.db  Logger32 now uses the MyBandMode32.db for its bandplan information.
11) Change made to IOTA marathon tracking
12) Added keep-alive command, to the localhost configuration. New option under SETUP | DX SPOT | CONFIGURE KEEP ALIVE MESSAGES
13) Adjusted the size of The MultiRX window
14) Change made to allow copy and paste macro text in
the CW Machine, Soundcard Data and Data terminal window.
15) Added new feature on the Local Host setup window that filters reverse beacon spots based on frequency being within 1KHz and ignoring the comment field of the DX Spot.
16) Added more user friendly editing to the Telnet Script setup Window.
Click on line to be edited. Text will appear in the edit panes.
17) Change made to accommodate the CW Machine on the second monitor.
Logger 32 Version 3.40.000A
2012 Apr 22
Countries / Prefixes Database Updates
**  Changed Primary Prefix for these DXCC Entities:
SS     > Z8    (South Sudan)
FR\G     > FT\G    (Glorioso)
FR\J    > FT\J    (Juan de Nova & Europa)
FR\T    > FT\T    (Tromelin)
FT8W    > FT\W    (Crozet)
FT8X    > FT\X    (Kerguelen)
FT8Z    > FT\Z    (Amsterdam & St. Paul)
**  Changed the status of RI1MV (Malyj Vysotskij Island) to "Deleted after 16-Feb-2012".
**  Added prefix block 2O (letter O) to G (England)
**  Added specific callsigns:
<6O0F>    to     **    (Not accepted for DXCC)
<TO3X>        FJ     (Saint Barthelemy)
<TO5K>        FM    (Martinique)
<2O12W>        GW    (Wales)
<4U1GSC>    I    (Italy)
<IY0GA>        IS0    (Sardinia)
<NH8S>        KH8\S    (Swain's Island)
<VK9LHI>    VK9\LH    (Lord Howe Island)
<VK9PN>        VK9\LH    (Lord Howe Island)
<ZQ3M>         ZB    (Gibraltar)
<ZQ2ER>        ZB    (Gibraltar)
<9M6/OH2YY>    1S    (Spratly)
**  Deleted specific callsigns:
<UZ2FWA>    UA2    (Kaliningrad)
<VK9FLHI>    VK9\LH    (Lord Howe Island)
**  Thanks to Constantin, UA1AKE, and Serge, UT2IO
Bud, W2RU
Keeper of the C/P Database
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BD4EP
只看该作者 2楼 发表于: 2012-05-06
中文版更新说明似乎翻译了也没有多少人捧场,容我会儿吧,等空了再说。
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线bd8te
只看该作者 3楼 发表于: 2012-05-07
多谢 多谢
BD8TE
来自四季如春的春城昆明
VHF守候频率145.050MHz
要三吧--拎吧去要--而要要路
QTH:昆明市
离线sunstar
只看该作者 4楼 发表于: 2012-05-07
文本里怎么有好多的**的,是什么意思?让我们猜 吗,还是ZF逼我们用不规范的中文?
BG4UNY
孙勇
江苏省南通市起凤园新村7幢203室
QQ37852277
EMAIL:sunstar126@163.com
TEL:13003594829
离线BG4FQD
只看该作者 5楼 发表于: 2012-05-07
他的版本更新也算勤快的了。
莫不如和作者联系一下官方出个语言包不行嘛。
别人吃饭我看着,别人睡觉我站着。
离线bg6art
只看该作者 6楼 发表于: 2012-05-07
请问4ep旧版的数据怎么转移过来?
BG6ART,壹伍陆伍伍壹零零贰玖玖
如果没收到我的卡片,请给我留言或者发邮件
bg6art在gmail.com
出闲置设备:psk modem
QQ:71800222
离线BD4EP
只看该作者 7楼 发表于: 2012-05-07
回 bg6art 的帖子
bg6art:请问4ep旧版的数据怎么转移过来? (2012-05-07 16:11)
靠。。。论坛的BUG,害我重写三次了!!!
1、如果是从V3.39.0升级,使用升级包,分别升级数据库和程序,以及最新的汉化包,重启LOGGER32,搞定;
2、如果是从更旧的版本升级,推荐方法:备份整个LOGGER32目录,再导出完整的日志为ADIF格式。卸载旧版LOGGER32,并将原目录彻底删除;再安装新版LOGGER32至同样的路径下,并将备份目录中,LOGGER32.INI等设置文件复制回去(比如BandMode32.db是波段模式信息;CW.INI是CW虚拟机设置;MMVARISoundCardMacros.ini是MMVARI引擎的设置文件,等等),再将ADIF文件导入新的LOGGER32中。搞定。
笨办法:到LOGGER32网站寻找旧版的升级文件,逐格版本升级。
自己选一种吧。
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BD4EP
只看该作者 8楼 发表于: 2012-05-07
注意顶楼的帖子。新版升级了。
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BD4EP
只看该作者 9楼 发表于: 2012-05-08
回 sunstar 的帖子
sunstar:文本里怎么有好多的**的,是什么意思?让我们猜 吗,还是ZF逼我们用不规范的中文?
 (2012-05-07 07:41)
哪里有**?
英文的说明里面吗?那是分隔符。
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BD4EP
只看该作者 10楼 发表于: 2012-05-08
回 BG4FQD 的帖子
BG4FQD:他的版本更新也算勤快的了。
莫不如和作者联系一下官方出个语言包不行嘛。 (2012-05-07 13:24)
报告一下!
官方语言包就是我做的。2009年,我联系了作者K4CY,并成为了LOGGER32翻译组成员之一(你可以看HELP文档中的说明,有我的呼号和英文名)。另外,汉化包的下载地址就是官网地址,不是我自己发布的,呵呵。
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线bg6art
只看该作者 11楼 发表于: 2012-05-08
回 BD4EP 的帖子
BD4EP:靠。。。论坛的BUG,害我重写三次了!!!
2、如果是从更旧的版本升级,推荐方法:备份 .. (2012-05-07 22:16)
多谢4ep回复。
我原来安装有logger32的笔记本主板坏了,所以没来及导出adif文件,但是硬盘上的文件应该还在。原来安装的应该是3.32版本,可不可以用拷贝文件的方式把原来的数据保留下来,请您指点。
BG6ART,壹伍陆伍伍壹零零贰玖玖
bg6art在gmail.com
出闲置设备:psk modem
QQ:71800222
离线BG4FQD
只看该作者 12楼 发表于: 2012-05-08
回 BD4EP 的帖子
BD4EP:报告一下!
官方语言包就是我做的。2009年,我联系了作者K4CY,并成为了LOGGER32翻译组成员之一(你可以看HELP文档中的说明,有我的呼号和英文名)。另外,汉化包的下载地址就是官网地址,不 .. (2012-05-08 10:09)
绝对的好同志!
别人吃饭我看着,别人睡觉我站着。
离线BD4EP
只看该作者 13楼 发表于: 2012-05-10
回 bg6art 的帖子
bg6art:多谢4ep回复。
我原来安装有logger32的笔记本主板坏了,所以没来及导出adif文件,但是硬盘上的文件应该还在。原来安装的应该是3.32版本,可不可以用拷贝文件的方式把原来的数据保留下来,请您 .. (2012-05-08 18:28)
建议:
1、找回原来3.32的安装文件安装一下,再把原目录下的LOGBOOK32.*文件复制过去,启动LOGGER32 V3.32,倒出日志为ADIF文件;
2、卸载新装V3.32,并目录及目录下所有文件;
3、安装最新版V3.40.6,导入先前备份的ADIF日志。搞定。
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线bg6art
只看该作者 14楼 发表于: 2012-05-11
回 BD4EP 的帖子
BD4EP:建议:
3、安装最新版V3.40.6,导 .. (2012-05-10 01:01)
谢谢,按此试试
BG6ART,壹伍陆伍伍壹零零贰玖玖
bg6art在gmail.com
出闲置设备:psk modem
QQ:71800222
离线BG4FUF
只看该作者 15楼 发表于: 2012-05-12
ep,调用qtz上的信息现在已经可以用了,但是信息不全只有姓名和国家没有详细的QTH,有什么办法可以让现实的资料全一点
BD4FUF ex BG4FUF
离线BD4EP
只看该作者 16楼 发表于: 2012-05-15
Re:【LOGGER32】V3.40.7-2012.05.13发布通告
又升级了……大家看看吧。
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BD4EP
只看该作者 17楼 发表于: 2012-05-15
回 BG4FUF 的帖子
BG4FUF:ep,调用qtz上的信息现在已经可以用了,但是信息不全只有姓名和国家没有详细的QTH,有什么办法可以让现实的资料全一点 (2012-05-12 09:17)
木有看明白。啥意思?
QRZ信息显示要用N2AMG的外挂,还要受每天呼号内容查询次数的限制;
可以使用内置的HAMQTH查询方式,只要更改查询网址的用户名和密码就可以了,信息应该比QRZ.COM只多不少。
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BD4EP
只看该作者 18楼 发表于: 2012-05-22
昨天V3.40.11发布了,因今天网站下载的问题才得以解决,故此迟了一天再通知大家下载。
另外,BX4BF已经联系上了,台湾版汉化工作应该可以继续了。
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BH1NGG
只看该作者 19楼 发表于: 2012-05-27
LZ辛苦。谢谢。
BH1NGG
757665659@qq.com.
