  • 4261阅读
  • 11回复
the WD6CNF Web site 几个有趣的小程序 [复制链接]
离线BG0APD
只看楼主 倒序阅读 0楼 发表于: 2014-07-25
CW Decoder Program Features
•Decode Morse code from a radio
◦5 to 50 wpm
◦Scrollable text window, save to a file
◾Variable text display sizes, upper/lower case
◦Variable character spacing
◦Variable speed selection, helps in reducing noise
◦Spectrum display, waterfall display, timeline display
◦Variable noise thresholds, noise blanking threshold
◦Automatic frequency control (AFC)
•Transmit Morse code, keyboard input
◦5 to 50 wpm
◦Key the transmitter via computer serial (com) port
◦Synchronize to receive speed
◦10 memories, store/recall
◦Download from a text file
◦Various transmit modes
◾Interactive (immediate)
◾Block transfer (send typed screen)
◦Functions keys perform transmit functions
Keep hands on the keyboard, mouse free transmit/receive operation
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 1楼 发表于: 2014-07-25
Audio Spectrum Analyzer Features
•Analyzes audio from 10 Hz to 20 kHz
•Input from microphone or wave file
•Variable displays
◦Fast Fourier Transform (FFT) display
◾Variable sample rates (8000 Hz, 11025 Hz, 22050 Hz, 44100 Hz)
◾Variable transform sizes (1k, 2k, 4k, 8k)
◾Upper and lower limits adjustable
◾Continuous, averaged, peak hold
◾Selectable foreground/backgrounds
◾Variable markers (2)
◾Save a reference plot, compare with the foreground plot
◦Time display (oscilloscope)
◾Triggered sweep
◦Waterfall display (color or B/W)
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 2楼 发表于: 2014-07-25
Voice Keyer Program Features
  •Audio voice keyer
•Microphone input, speaker output
◦Live microphone enable
•Record/play audio from twelve memories
•Display text of recorded audio
•Transmitter keyed via serial (com) port
•Loop (with variable delay) audio output
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 3楼 发表于: 2014-07-25
Piano Program Features:
•Musical note capture/display
•Tune instruments, or check pitch of voice
•Violin, guitar, piano modes
•Displays input tone to nearest musical note
◦Frequency display
◦Meter center
◦Hold mode
Useful for both all instruments including wind instruments
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 4楼 发表于: 2014-07-25
SpectraScope is a simple Windows interface program allowing your computer to view up to two audio waveforms in either the time or frequency domain. The program is a Windows soft panel operating as a dual channel oscilloscope and spectrum analyzer. The useful frequency of operation is 20 to 10,000 Hz in the time domain and 20 to 20,000 Hz in the frequency domain. The program uses the computer sound card to capture the audio input.
SpectraScope Features:
1. Simultaneous two channel operation
2.Separate gain and offset controls for each channel
3.Time or frequency domain measurements
4.Channel Add mode
5.Channel XY mode (allows display of Lissajous patterns)
6.Multiple triggering options
7.Single sweep capability
8.Display hold
9.Dual vertical markers for waveform time measurements
10.File save of the form or graphic screen
11.Trace and background color selections
12.All menu selections and most of control settings are saved in a Configuration file.
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 5楼 发表于: 2014-07-25
Packet Terminal Interface Program Features
•Simple Windows based TNC interface program
•Designed for ARES operation
◦Simple operator interface to connect and perform communication functions
◦Control operator programs screens before operations
•Both receive and transmit screens
◦Operation via single or dual screen modes
•Transmit control via TNC commands
•Text file transfers
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 6楼 发表于: 2014-07-25
Vox Recorder Features
The Vox Recorder program incorporates the following features:
·        Voice activated recording (.wav format).
·        Continued recording (hangtime) from 0.5 seconds to 5 seconds.
·        Playback of recorded audio.
·        File to file transfer of the audio with both voice activation and filter enabled.
·        Mono or stereo recording.
·        Supported sample rates of 11025 Hz, 22050 Hz, and 44100 Hz.
·        Input and output Sound Card selection
·        Timed (to the hour, minute, second, and AM/PM) recording.
·        Timeline display of the recorded or playback audio.
·        Bandpass filter (bandwidth/limits can be set by the operator) of recorded or playback audio.
·        Output volume control.
·        Help file support.
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 7楼 发表于: 2014-07-25
Click on the program in the list to download it onto your computer. Then run the .exe  program. After the files have been unzipped (to the directory of your choice), run the Setup.exe program. All programs are around 2 megabytes in size except for the instrument tuner which is about 900 kbytes. Programs that are now Windows 7/Vista compatible must have the previous versions de-inst alled (use the Start->Control Panel->Add/remove programs). The new inst aller will not remove the previous inst allation and programs may not execute properly if the previous version is not de-installed!
http://www.hotamateurprograms.com/downloads.htm
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 8楼 发表于: 2014-07-25
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 9楼 发表于: 2014-07-25
DSP Filter Program Features
•Audio Digital Filter
◦Two bandpass filters
◦Three notch filters
◦Two noise filters
◦All filters cascadable
•Graphical setting of filter center frequency and bandwidth
◦Drag vertical lines on top of signal
◦Mono, 5 kHz bandwidth
•File record and playback filtered audio
◦Simultaneous operation
•Frequency or time display
邮箱:BG0APD@163.com
电话:15309910960
只看该作者 10楼 发表于: 2014-07-26
有没有国内的?!
离线hailong
只看该作者 11楼 发表于: 2014-07-28
不明觉历
