19th STEW PERRY TOPBAND DISTANCE CHALLENGE
1. Contest period: 1500Z December 27th to 1500Z December 28th, 2014.
Operate for a maximum of 14 hours. Off times are 30 minutes minimum
and a maximum of four off periods are permitted.
A separate warm-up event will be held on October 19/20th with the
same time period and entry categories. A Summer event will be held
on June 15/16th - again with the same time period and categories.
2. Bands and mode: 160 meters CW only.
1.大赛期间:1500Z12月27日至1500Z2014年12月28日。
操作最长为14小时。关闭时间至少30分钟
并允许最多四个off周期。
一个单独的热身活动将于10月19日/20日与
同一时期,入境类别。夏日活动将举行
6月15日/16日 - 再次在同一时期和类别。
2.带和模式:160米CW而已。
8. Reporting: Your log can be sent via the internet to TBDC@CONTESTING.COM using the Cabrillo format within 15 days of the contest. You can also usethe form provided by WA7BNM on the web to enter your ASCII or paper logdata - http://www.b4h.net/cabforms/stewperry_cab.php
8.报告:您的日志可以通过互联网发送到TBDC@CONTESTING.COM
使用中的较量15天卡布里洛格式。您还可以使用
在网络上提供的WA7BNM的形式输入ASCII或纸张记录
数据 - http://www.b4h.net/cabforms/stewperry_cab.php
[ 此帖被BG4KYA在2014-12-18 15:49重新编辑 ]
