  • 3359阅读
  • 14回复
收到邮件,2010CQWW记录出来了 [复制链接]
离线BG1TXU
只看楼主 倒序阅读 0楼 发表于: 2011-08-08
http://www.cqww.com/cq-ww-ssb-2010.htm.
8.4收到的邮件,看了下操作水平较低,错了不少,通联双方的都有,今后继续不断提高吧。
离线BD7OZG
只看该作者 1楼 发表于: 2011-08-08
70906 claimed score
66000 final   score
-6.9% score reduction
离线BD7RDC
只看该作者 2楼 发表于: 2011-08-08
密码居然打不开
离线BG1TXU
只看该作者 3楼 发表于: 2011-08-08
邮件里的密码,没问题呀,各项写的很详细的。
离线BD7RDC
只看该作者 4楼 发表于: 2011-08-08
打开了,直接复制,多了个空格
离线BG9TX
只看该作者 5楼 发表于: 2011-08-08
没参加,等看cw
离线ba6iv
只看该作者 6楼 发表于: 2011-08-09
同楼上,也没参加,等看cw。
在线BA5CJ
只看该作者 7楼 发表于: 2011-08-09
259434 claimed score
224220 final   score
-13.6% score reduction
    0 (0.0%) duplicates
    9 (1.5%) calls copied incorrectly
    0 (0.0%) band change violations
    7 (1.2%) not in log
    1 (0.2%) calls unique to this log only (not remo
扣分扣得比较多啊。
离线bg4wen
只看该作者 8楼 发表于: 2011-08-09
contest: 2010 cq ww dx ssb contest
call:   bg4wen
category: single op 21 mhz low power
************************** summary ***************************
  135 claimed qso before checking (does not include duplicates)
  128 final   qso after checking reductions
  280 claimed qso points
  204 final   qso points
    45 claimed countries
    42 final   countries
    20 claimed zones
    17 final   zones
    65 claimed mults
    59 final   mults
  18200 claimed score
  12036 final   score
-33.9% score reduction
    0 (0.0%) duplicates
    5 (3.7%) calls copied incorrectly
    2 (1.5%) not in log
    0 (0.0%) calls unique to this log only (not removed)
********************** results by band ***********************
          band   qso qpts zone cty mult
  claimed   160m   0   0   0   0   0
  final     160m   0   0   0   0   0
  claimed     80m   0   0   0   0   0
  final     80m   0   0   0   0   0
  claimed     40m   0   0   0   0   0
  final     40m   0   0   0   0   0
  claimed     20m   0   0   0   0   0
  final     20m   0   0   0   0   0
  claimed     15m   135   280   20 45   65
  final     15m   128   204   17 42   59
  claimed     10m   0   0   0   0   0
  final     10m   0   0   0   0   0
  claimed     all   135   280   20 45   65 score   18200
  final     all   128   204   17 42   59 score   12036
************************* not in log *************************
21000 ph 2010-10-30 0906 bg4wen       24 s79k         39
21000 ph 2010-10-31 0347 bg4wen       24 8n5a         25
********************* incorrectly copied *********************
21000 ph 2010-10-30 0602 bg4wen       24 yt3z         15 correct   yt7z
21000 ph 2010-10-30 0639 bg4wen       24 ve4cq       28 correct   v84cq
21000 ph 2010-10-31 0034 bg4wen       24 k3xx         3 correct   k6xx
21000 ph 2010-10-31 0047 bg4wen       24 w7lh         3 correct   w6lh
21000 ph 2010-10-31 0852 bg4wen       24 yl3w         15 correct   yl6w
********************** lost multipliers **********************
21000 ph 2010-10-30 0906 bg4wen       24 s79k         39 not in log
******************* multipliers by band ********************
160m multiplier total 0
80m multiplier total 0
40m multiplier total 0
20m multiplier total 0
15m multiplier total 59
3w   4o   9m6   a7   by   ce   cu   dl   du   e7
es   eu   ex   f   g   gi   ha   hs   ja   k
kh0   kh2   kh6   lz   oe   oh0   ok   om   oz   s5
sm   sp   ua   ua9   uk   un   ur   vk   xu   yb
yo   yu
3 12 14 15 16 17 18 20 21 23 24 25 26 27 28 30 31
10m multiplier total 0
************ stations copying bg4wen incorrectly *************
21300 ph 2010-10-30 0546 rl3a         16 bg4weg       24
21000 ph 2010-10-31 0248 un7to       17 bg4wew       24
21000 ph 2010-10-31 0322 hs0zee       26 bg4wn       24
21303 ph 2010-10-31 0915 dj7yp       14 bg4en       24
错了一大堆,汗~
离线BD6AHP
只看该作者 9楼 发表于: 2011-08-09
call:   bd6ahp
category: single op 21 mhz low power assisted
  165 claimed qso before checking (does not include duplicates)
  160 final   qso after checking reductions
  378 claimed qso points
  350 final   qso points
    49 claimed countries
    49 final   countries
    18 claimed zones
    18 final   zones
    67 claimed mults
    67 final   mults
  25326 claimed score
  23450 final   score
  -7.4% score reduction
    0 (0.0%) duplicates
    4 (2.4%) calls copied incorrectly
    1 (0.6%) not in log
离线BD4HZ
只看该作者 10楼 发表于: 2011-08-09
call:   bd4hz
category: single op all band low power
  367 claimed qso before checking (does not include duplicates)
  346 final   qso after checking reductions
  662 claimed qso points
  462 final   qso points
    83 claimed countries
    75 final   countries
    54 claimed zones
    49 final   zones
  137 claimed mults
  124 final   mults
  90694 claimed score
  57288 final   score
-36.8% score reduction
    0 (0.0%) duplicates
    17 (4.6%) calls copied incorrectly
    4 (1.1%) not in log
    2 (0.5%) calls unique to this log only (not removed)
  final     80m   0   0   0   0   0
  claimed     40m   52   120   12 22   34
  final     40m   49   92   12 20   32
  claimed     20m   111   158   16 19   35
  final     20m   106   118   13 17   30
  claimed     15m   196   368   20 36   56
  final     15m   185   252   19 33   52
  claimed     10m   8   16   6   6   12
  final     10m   6   0   5   5   10
  claimed     all   367   662   54 83 137 score   90694
  final     all   346   462   49 75 124 score   57288
离线BG1TXU
只看该作者 11楼 发表于: 2011-08-09
目前看楼上各位,7ozg错误率最低
离线BA7NQ
只看该作者 12楼 发表于: 2011-08-10
call:   b7p
category: multi-multi
  6292 claimed qso before checking (does not include duplicates)
  6170 final   qso after checking reductions
  14535 claimed qso points
  13351 final   qso points
  509 claimed countries
  501 final   countries
  171 claimed zones
  171 final   zones
  680 claimed mults
  672 final   mults
9883800 claimed score
8971872 final   score
  -9.2% score reduction
    1 (0.0%) duplicates
    94 (1.5%) calls copied incorrectly
    28 (0.4%) not in log
    93 (1.5%) calls unique to this log only (not removed)
离线BH4SKP
只看该作者 13楼 发表于: 2011-08-10
1 (1.8%) duplicates
    5 (8.9%) calls copied incorrectly
    2 (3.6%) not in log
错了很多。。。。竟然还有重复的,手抄的不靠浦阿。。。
离线BD4SP
只看该作者 14楼 发表于: 2011-08-10
1 (1.8%) duplicates
    2 (3.6%) not in log
抄得不仔细吧
软件可以提醒你哪些台重复了。
最最最佩服全手操的contester了
