  • 4164阅读
  • 15回复
求业余数字通信实验合适的频点 [复制链接]
离线BA5RW
只看楼主 倒序阅读 0楼 发表于: 2009-11-19
例如psk31、rtty、sstv等,国内能不能约定一个频点?就象7023那样的cw乐园……四十米波、二十米波和十五米波国内在哪个点比较合适?希望大家综合考虑后给出宝贵意见,谢谢先!
离线BG5ROJ
只看该作者 1楼 发表于: 2009-11-19
似乎没人响应来着 , 哎~~!
世上本没有路,看来走的多了也自然成了路
离线bh1iig
只看该作者 2楼 发表于: 2009-11-19
40米 7.033
20米 14.230     14.233     14.236
15米 21.340
这应该是常用的。不知可否。
离线chinahamer
只看该作者 3楼 发表于: 2009-11-19
同问,等高人回答。。
离线BA5RW
只看该作者 4楼 发表于: 2009-11-19
40米 7.033
15米 21.340
这应该是常用的。不知可否。
谢谢!我们希望国内的爱好者约个频点玩.以下是psk31的国际频点
band frequency band frequency
160 meters 1.838 mhz 6 meters 50.290 mhz
80 meters 3.580 mhz 2 meters 144.144 mhz
40 meters 7.035 mhz 1.25 meters 222.07 mhz
30 meters 10.140 mhz 70 centi-meters 432.2 mhz
20 meters 14.070 mhz 33 centi-meters 909 mhz
17 meters 18.100 mhz
15 meters 21.080 mhz
10 meters 28.120 mhz
数字模式的国际频标
digital operating frequency guide
provided by w0pya, larry.
160 meters
1.838.150               psk31, stream, etc.
1.890                   sstv
80 meters
3.580.150 to 3.620     data (rtty, psk31, hellschreiber, stream
3.620 to 3.635         packet
3.845                   sstv
40 meters
7.035.150               psk31
7.037                   stream, hellschreiber
7.080                   rtty
7.171                   sstv
30 meters
10.130                 psk31
10.130 to 10.140       rtty
10.137                 hellschreiber
10.140 to 10.150       packet
20 meters
14.063.5                 hellschreiber
14.070.150             psk31
14.070 to 14.095       rtty
14.080                 stream
14.100.5 to 14.112     packet
14.230                 sstv
14.233                 sstv
17 meters
18.100 to 18.105       rtty
18.103                 hellschreiber
18.105                 stream
18.105 to 18.110       packet
15 meters
21.063                 hellschreiber
21.070 to 21.100       rtty
21.080.150             psk31 , stream
21.100 to 21.110       packet
21.340                 sstv
12 meters
24.920 to 24.925         rtty
24.925 to 24.930         packet
24.929                 stream
10 meters
28.070 to 28.150       rtty
28.080                 stream
28.120.150             psk31, hellschreiber
28.680                 sstv
28.690                 sstv (there are some sstv repeaters on this frequency.)
28.700                 sstv
6 meters
50.680                     sstv
51.120                     psk31
2 meters
145.500                   sstv   nationwide, fm sstv simplex frequency
145.550                   psk31, hellschreiber, stream
145.600                   sstv
145.650                   experimental digital   (shared with irlp in some areas)
离线BA5RW
只看该作者 5楼 发表于: 2009-11-19
请roj选一个最好能覆盖国际常用到的附近频点,以便国内外通用都能玩得到.
离线BA5RW
只看该作者 6楼 发表于: 2009-11-19
these recommended frequencies are in accordance with the iaru bandplan for region 1. there may be differences for regions 2 and 3
1838.150
3580.150
7035.15 for region 1 and region 3, and 7080.15 for region 2 *
10142.150
14070.150
18100.150
21080.150 (although most activity can be found 10 khz lower)
24920.150
28120.150
* this is due to the fact that the 7 mhz band is much wider in region 2 (the americas), and the iaru bandplan reflects this.
离线BG5ROJ
只看该作者 7楼 发表于: 2009-11-19
抄收啦,
离线BD2ALB
只看该作者 8楼 发表于: 2009-11-19
现在7038上全是psk31信号,全是老外!!!
离线BD2ALB
只看该作者 9楼 发表于: 2009-11-20
和ra0an 、ra9ut通上了,psk31模式,ppc pocketdigi软件,100w短波电台。
离线BG4-2-12747
只看该作者 10楼 发表于: 2009-11-20
我经常在14。070收psk31信号。国内玩的话,是不是能避开这些频点?至少我们跟j台拼功率有优势的朋友不多啊。
离线BG5ROJ
只看该作者 11楼 发表于: 2009-11-20
psk31撞车的机会很小吧,频宽占用非常少,绿色的,环保的,呵呵~!
  我觉得倒是该跟国际接轨, 频线上热闹点好,国内毕竟圈子还是相对小,
  bd2alb 你是论坛老游击队员啦,呵呵, 看您也很关注数据通信版的,呵呵,
离线bd8ub
只看该作者 12楼 发表于: 2009-11-21
正确,这几种模式国内本来玩的就不多,在重新找频点更没有多少人。与国际接轨是正确的。
离线jzkuangbiao
只看该作者 13楼 发表于: 2011-05-25
记号 记号
离线weed
只看该作者 14楼 发表于: 2011-05-25
正在搞psk31!
离线hocool
只看该作者 15楼 发表于: 2011-05-25
希望楼主能够成为新标准的引领者。
