  • 3955阅读
  • 8回复
6米信标台 JA6YBR [复制链接]
离线BA2Bi
只看楼主 倒序阅读 0楼 发表于: 2009-08-26
1.callsign         ja6ybr
  2.frequency         50.017mhz
  3.mode             cw(a1/a1a)
  4.operating time     24 hours
  5.location         miyazaki; south western part of japan
                  long: 131 25' 38" e
                  lat : 31 49' 11" n
  6.grid locator       pm51rt
  7.transmitter/power   homebrew 2sc2290pp/50w max
  8.antenna           turn styled hentenna
  /height           /60m asl/15m above the ground
  /polarization       /horizontal
  /direction         /omni direction
  9.transmitting message vvv vvv vvv de ja6ybr miyazaki
                  pm51rt .- ..- ...- ....-
                  rmks:"vvv" to ".-": 50w
                    "..-"       : 10w
                    "...-"     : 1w
                    "....-"     : 0.1w
10.operating manager   shirow kinoshita; jf6dea/ke1eo
11.reporting address   shirow kinoshita, jf6dea/ke1eo
                  2-15-10, shodai, sawara-ku
                  fukuoka, 814-0012, japan
                  e-mail:bcon(at)ja6ybr.org
12.farther information   *the system is with intelligent cpu.
                  *power level changing 50/10/1/0.1w
                            after every message.
13.historical story     nov. 3,1985 ja6ybr beacon starts to
                          operate on 50.020mhz with
                          10w into stacked halo.
                  sep.15,1986 change callsign to jf6dea/6.
                  sep.23,1987 change callsign to je6zih.
                  nov.13,1988 change frequency to 50.017mhz.
                  may. 3,1989 callsign back to ja6ybr and
                          change equipment and power to
                          50/10/1/0.1w.
                  may. 3,1990 change antenna to turn styled
                          hentenna.
                  nov. 6,1993 change antenna to new turn
                          styled hentenna.
14.reference         the equipment and/or antenna system of the
                  beacon was introduced in the following
                  references;
                  "mobile ham" dec.1989 pp.96-97 (japanese)
                  "cq ham radio" may.1995 pp.183 (japanese)
                  cq amateur radio (usa) aug.1988 pp.98
                  qst (arrl) jul.1995 p.99
                  and the antenna system of this beacon is
                  introduced on the arrl antenna compendium
                  vol.5 by shirow kinoshita;jf6dea/ke1eo.
离线BA2Bi
只看该作者 1楼 发表于: 2009-08-26
今天可以收到他1w 499
rig:ft-817nd
ant:dp(40m band)
离线ba4ta
只看该作者 2楼 发表于: 2009-08-26
我这里收的frequency 50.0175mhz
离线BA2Bi
只看该作者 3楼 发表于: 2009-08-26
信号怎么样???
离线ba4ta
只看该作者 4楼 发表于: 2009-08-26
信号很好啊.这个信标台一直能听到的
离线bg7nwf
只看该作者 5楼 发表于: 2009-08-26
ja 的6米信标应该不少于6个了!!
传播好时能同时收到4个!!!
离线BA2Bi
只看该作者 6楼 发表于: 2011-07-17
现在0.1w 信号 499
离线bv2ac
只看该作者 7楼 发表于: 2011-07-18
冬天沒有 es 干擾的時候, 拿它做流星雨的電波反射源, 計算流星數量, 與分怖時間, 非常有用.....
http://www.tsao5916.com/hro.htm
离线曾经拥有
只看该作者 8楼 发表于: 2011-07-18
50047上也有个信标,忘记是哪里了。我一般都是去50098附近,只要有动静,50兆会被围攻。
