虽然不懂CW 看出了KX3固件更新的目的,推着他上战场来
CW-IN-SSB TRANSMIT ADDED: This feature allows you to send CW while in SSB mode, which can be useful when your SSB signal cannot be copied due to poor conditions. The other station will hear a tone at your CW pitch. To enable CW-in-SSB: Locate the CW WGHT menu entry, then tap ‘1’ (PRE) to alternate between “SSW +CW” (enabled) and “SSB –CW” (disabled). The default is disabled. Important Notes: (1) CW-in-SSB does not yet apply in SPLIT mode. (2) When CW-in-SSB is enabled, tapping the KEYER/MIC knob toggles between keyer speed and mic gain rather than between the two transmit metering scales (CMP/ALC and SWR/RF). The CMP/ALC scale is still shown temporarily whenever CMP or mic gain are adjusted.
1-HZ TUNING PRESERVED AFTER APF-OFF: If you were using 1-Hz tuning prior to turning on APF (CW audio peaking filter), 1-Hz tuning will be restored when APF is turned off. Prior to this change, exiting APF would set the tuning rate to 10 Hz.
