Yaesu Reset方法 (转载hackersrussia)
03440
新版来袭 收藏
ft - 1000
hard reset         flip off backup switch (inside the top panel window)
memory reset press & hold (sub) & (enter) & turn power on
soft reset         press & hold (1,5) & (3,5) & turn power on
ft – 990
memory reset press & hold (gen) & (ent) & turn power on.
soft reset   press & hold (1,5) & (3,5) & turn power on. ( for checking display and rom versions)
ft – 890
hard reset       press & hold (ham/gen) & (clar) & turn power on.
soft reset       press & hold ( a/b) & (a = b) & turn power on. ( for checking display and rom versions)
ft – 767gx
hard reset      press & hold ( offset) & turn power on
(140.000 – 148.990 mhz)
press & hold (clar) & turn power on
(1400 – 145.999 mhz)
press & hold (mck) & turn power on
( 140.00 – 1487.99 mhz)
430/440 toggle      press & hold (0) & turn power on
ft – 757 gx
hard reset      press & hold (marker) & (linear) & turn power on
ft – 747 gx
hard reset      slide backup switch towards tuning dial( located on bottom of panel)
ft – 2400h
ham/extendetd rx      press & hold (up) & (down) & turn power on
memory reset      press & hold (d/mr) & (f/w) & turn power on
factory defaults      press & hold (d/mr) & (rev/skip) & turn power on & turn off & press & hold (d/mr) & turn on.
ft - 5100
factory defaults      press & hold (d/mr) & (rev) & turn power on
ft - 5200
ham/extendetd rx      press & hold (mhz) & ( dvs/hold) & turn power on
2003-03-31 11:14:04
二楼自古出人才
欢迎加入讨论。
我是有底线的
