  • 7660阅读
  • 23回复
FT-891可以升级了(2021.2.1版) [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2021-02-04
2/1/21
FT-891 Firmware Update Information
The latest versions are listed below with the release dates.
MAIN Firmware Version 01-09 (2/01/21)
DSP Firmware Version 02-04 (2/01/21)
Panel Firmware Version 01-01 (9/06/17)
*If you already have the above listed firmware versions, it is not necessary to update the FT-891
again.
There are three different firmware installations. Each one must be followed carefully. Installing the
wrong type firmware may cause difficulties. Check your radio before installing firmware to be sure
which updates are needed. Please read the FT-891 Firmware Upgrade Manual before
proceeding.
Before installing new firmware, please verify your current version firmware with the following
procedure:
(This image & version is for illustration only)
Download the FT-891 data and [FT-891_Firmware_Update_2021_02.zip] from the following
website:
https://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=102&encProdID=DF4DB2
62968932E999EAF928B5B6A1A7&DivisionID=65&isArchived=0The zip file contains all of the current software versions. Please verify which version software is
already on your radio before updating. If you have each of the listed versions, you do not need to
update the radio again.
Please read the FT-891 Firmware Upgrade Manual before proceeding!
Implements improvements
1. Fixed a bug that the S meter may not indicate to the received signal level.
2. Improved and optimized additional functions.
We hope this new firmware will increase your enjoyment of your FT-891. Thank you for
choosing Yaesu radios. If you have any problems or questions, please contact Yaesu Amateur
Tech Support amateurtech@yaesu.com.
Best regards,
Yaesu USA | 6125 Phyllis Drive | Cypress, CA 90630 | 714.827-7600 | FAX: 714.827-8100
http://www.yaesu.com
只看该作者 1楼 发表于: 2021-02-04
FT-891固件更新信息
下面列出了最新版本以及发布日期。
§ 主要固件版本01-09(2/01/21)
§ DSP固件版本02-04(2/01/21)
§ 面板固件版本01-01(9/06/17)
主固件版本01-09(2/01/21)
1.修复了S表可能无法指示接收信号电平的错误。
2.改进和优化的附加功能。
离线BG4FQD
只看该作者 2楼 发表于: 2021-02-04
固件下好了,就差拥有一台FT891 了
别人吃饭我看着,别人睡觉我站着。
离线bg8hr
只看该作者 3楼 发表于: 2021-02-06
己经升了
只看该作者 4楼 发表于: 2021-02-07
回 bg8hr 的帖子
bg8hr:己经升了 (2021-02-06 18:42)
谈一下体会!
离线bi8deq
只看该作者 5楼 发表于: 2021-02-07
固件已下载求刷机软件,此次更新后与之前有何区别》
只看该作者 6楼 发表于: 2021-02-08
回 bi8deq 的帖子
bi8deq:固件已下载求刷机软件,此次更新后与之前有何区别》
 (2021-02-07 14:19)
官方下载,很简单的。
离线BG5CHA
只看该作者 7楼 发表于: 2021-02-10
感谢提醒,已成功升级完毕
现使用呼号:BG2ENW
QRZ: img: https://www.qrz.com/db/bg2enw
只看该作者 8楼 发表于: 2021-02-17
我升级的时候感觉电脑识别慢,开始以为有故障。。。。。。。。。。。
离线BG2UE
只看该作者 9楼 发表于: 2021-02-21
升级成功,一会有传播的时候听听。
B4/BG2UE
离线bg6fhi
只看该作者 10楼 发表于: 2021-02-27
请教楼上几位友台,升级后的891可有什么变化,谢谢
离线bg2efx
只看该作者 11楼 发表于: 2021-02-28
回 bg6fhi 的帖子
bg6fhi:请教楼上几位友台,升级后的891可有什么变化,谢谢 (2021-02-27 11:01)
没感觉出来有啥变化。。
不过有新的升级就是了
Hello, This is BG2EFX.
See you on the air! 73!
离线BG2UE
只看该作者 12楼 发表于: 2021-03-04
回 bg6fhi 的帖子
感觉没什么变化,可能是没有对比吧!
B4/BG2UE
离线BG1WCG
只看该作者 13楼 发表于: 2021-03-04
主要问题有没有解决啊?5Mhz,NR换波段需要重新设置的这些刚需问题。
[ 此帖被BG1WCG在2021-03-05 23:03重新编辑 ]
地址: 北京市朝阳区
Email: bg1wcg@163.com
Hi-Fi 胆机
离线BG2UE
只看该作者 14楼 发表于: 2021-03-06
回 BG1WCG 的帖子
BG1WCG:主要问题有没有解决啊?5Mhz,NR换波段需要重新设置的这些刚需问题。 (2021-03-04 23:01)
我的机器过保了!硬扩的!那都可以发射!
B4/BG2UE
离线BG1WCG
只看该作者 15楼 发表于: 2021-03-09
我是国行的机器,升级完了,5MHz 依旧不能发射。看来只能硬扩了,大家有和我一样的情况吗?
地址: 北京市朝阳区
Hi-Fi 胆机
离线BA4WI
只看该作者 16楼 发表于: 2021-03-24
没兴趣,哪天能升级成彩屏再升
EX:BD4RDR BG4RDR
QQ:175218318
MSN:BA4WI@MSN.CN
Mail:BA4WI.Jack@Gmail.com
QTH:OM92JC
SKCC,WWYC
离线bg3myx
只看该作者 17楼 发表于: 2021-03-28
回 BG2UE 的帖子
BG2UE:我的机器过保了!硬扩的!那都可以发射! (2021-03-06 00:08)
请教如何硬扩频?
离线BG2UE
只看该作者 18楼 发表于: 2021-03-28
回 bg3myx 的帖子
bg3myx:请教如何硬扩频? (2021-03-28 10:07)
https://www.hellocq.net/forum/read.php?tid=356918&page=1
参考这个帖子里的方法。
B4/BG2UE
离线BG9AU
只看该作者 19楼 发表于: 2021-04-24
已成功升级完毕,感觉不到变化
