QTC Keys (for WAE contests)
Ctrl+Z – in CW/SSB, enters or leaves QTC mode; in RTTY, cycles through Send, Receive and QTC Off
If Ctrl+Z is pressed before the QSO with the station has been logged, logs the QSO
Enter – logs the next QTC (receiving), or sends the next QTC in the batch (sending)
F3 (End of QSO Key) – sends the TU message and exits QTC mode
Alt+W – wipes the current row
Esc – terminates sending (CW or RTTY), or if the program is not currently sending, exists the QTC window (same as the Cancel button)
Alt+Enter, Keypad + (plus) key (sending QTCs only) – re-sends the last sent string
Alt+Enter, Alt+Tab, Alt+Space (receiving QTCs only) – force-logs the current QTC; overrides error-checking
Ctrl+A (receiving QTCs only) – removes the last blank line of received QTCs and reduces the count in the QTC header
Used, for example, when the number in the header was copied incorrectly and fewer QTCs are received than expected
Alt+A (receiving QTCs only) – adds a new QTC line (if fewer than 10) and increases the count in the QTC header
As above, when more QTCs are received than expected
1, 2, 3 (sending QTCs only) – if pressed while the Agn button is highlighted, resends the time(1), call(2) or serial number(3) from the previous QTC
Shift+1, Shift+2, Shift+3 (receiving QTCs only) – asks for a repeat of the time(1), call(2) or serial number(3)
