  • 21107阅读
  • 36回复
ICOM机器复位方法 [复制链接]
离线神仙
只看该作者 20楼 发表于: 2004-05-06
找了好久.谢谢................
离线bg9ep
只看该作者 21楼 发表于: 2004-07-20
老兄,你资料上写的IC735是不是没有复位的办法呀~!?
  我把IC735拆开再装上就没了显示,线都插对了,就是没显示~!晕~!~!~!~
离线bg4uvd
只看该作者 22楼 发表于: 2004-07-20
象建伍-样.能提供中文的就好了.真是一大快事.
离线BG4IND
只看该作者 23楼 发表于: 2004-07-20
e不好,请提供中文的。
离线BA4REC
只看该作者 24楼 发表于: 2004-07-22
俺现在还没有ICOM的机器,唉。
先收藏了的说。以后有了钱就买。
h a n d h e l d s:
ic-delta1 - hold [function] & [a] & [clr] buttons and turn the radio on.
ic-2gat - turn the radio on, hold [light] & [function], turn the radio off, then turn back on. release the buttons after the display returns to normal.
ic-2gxat - hold [func] & [vmc] & [dup] & [hi/lo] buttons and turn the radio on.
ic-02at - serial numbers below 34000: push the button on the main circuit board next to the lithium battery. serial numbers above 34000: hold [func] button and turn the radio on.
ic-2ia - hold [light] & [monitor] buttons and turn the radio on.
ic-2sa - hold [light] & [monitor] buttons and turn the radio on.
ic-2sat - hold [function] & [a] buttons and turn the radio on.
ic-2sra - hold [function] & [a] & [clr] buttons and turn the radio on.
ic-p2at - hold [function] & [a] buttons and turn the radio on.
ic-?at - hold [light] button and turn the radio on.
ic-03at - serial numbers below 34000: push the button on the main circuit board next to the lithium battery. serial numbers above 34000: hold [func] button and turn the radio on.
ic-3sa - hold [light] & [monitor] buttons and turn the radio on.
ic-3sat - hold [function] & [a] buttons and turn the radio on.
ic-4ia - hold [light] & [monitor] buttons and turn the radio on.
ic-4gat - turn the radio on, hold [light] & [function], turn the radio off, then turn back on. release the buttons after the display returns to normal.
ic-4gxat - hold [func] & [vmc] & [dup] & [hi/lo] buttons and turn the radio on.
ic-04at - serial numbers below 34000: push the button on the main circuit board next to the lithium battery. serial numbers above 34000: hold [func] button and turn the radio on.
ic-4sa - hold [light] & [monitor] buttons and turn the radio on.
ic-4sat - hold [function] & [a] buttons and turn the radio on.
ic-4sra - hold [function] & [a] & [clr] buttons and turn the radio on.
ic-p4at - hold [function] & [a] buttons and turn the radio on.
ic-12at - hold [func] button and turn the radio on.
ic-12gat - turn the radio on, hold [light] & [function] buttons, turn the radio off, then turn back on. release the buttons after the display returns to normal.
ic-24at - hold [function] & [a] buttons and turn the radio on.
ic-32at - hold [function] & [a] & [light] buttons and turn the radio on.
ic-q7a - hold [func] & [band] & [v/m] buttons and turn the radio on.
ic-t2a - hold [a] & [c] buttons and turn the radio on.
ic-t2h - hold [av] & [ct] buttons and turn the radio on.
ic-t21a - full reset: hold [a] & [*] & [func] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.
ic-t22a - full reset: hold [a] & [*] & [func] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.
ic-t41a - full reset: hold [a] & [*] & [func] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.
ic-t42a - full reset: hold [a] & [*] & [func] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.
ic-t7a - hold [mr] & [vfo] & [band] buttons and turn the radio on.
ic-t8a - hold [mr] & [vfo] & [band] buttons and turn the radio on.
ic-t81a - hold [sql] & [vfo] & [mr] buttons and turn the radio on.
ic-v21at - hold [f] & [a] & [*] buttons and turn the radio on.
ic-w2a - hold [function] & [a] & [clr] buttons and turn the radio on.
ic-w21a - hold [hi/lo] button and turn the radio on.
ic-w21at - hold [f] & [a] & [*] buttons and turn the radio on.
ic-w31a - full reset: hold [a] & [*] & [moni] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.
ic-w32a - full reset: hold [sql] & [vfo] & [mr] buttons and turn the radio on. partial reset: hold [vfo] button and turn the radio on.
ic-z1a - full reset: hold [a] & [*] & [moni] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.[/quote]
离线BG6QCB
只看该作者 25楼 发表于: 2004-07-22
e文看不懂请贴个中文的谢谢
离线BD3RJ
只看该作者 26楼 发表于: 2004-07-25
hold是按住的意思,[]里面的是按键的名字,&是“...和...”的意思。
一般是按住某个键开机就复位了。
离线bd8bk
只看该作者 27楼 发表于: 2004-09-30
e文看不懂,能详细说明一下ic-m100的复位方法吗?谢谢!
离线bg2igs
只看该作者 28楼 发表于: 2004-11-23
你好,我有icom-gw1的机器,不知道如何置频,请指教.73
离线刺猬
只看该作者 29楼 发表于: 2005-02-02
厉害!资料够齐全!感谢!
离线火腿蛋
只看该作者 30楼 发表于: 2005-02-25
qal弄到什么好机?再这里看个没完?
离线BD3HX
只看该作者 31楼 发表于: 2005-05-01
hgggjvguoihjoi[okp[l
离线BA2QA
只看该作者 32楼 发表于: 2005-05-28
ICOM-M600扩频方法
ic-m600是一部海事专业机,原机只能工作在专业频段。全段工作扩频方法如下:将逻辑单元d8&d15两个二极管断开即可。(d15版子上未印字,离cpu最近的双二极管就是)
原机lsb方式未使能,设置方法:f+mode开机、按mode键直至屏幕出现lsb字样、按rx键使lsb方式使能、关机退出。同理,你也可以将不用的r3e和h3e关闭,方法同上。(工作方式右侧出现rx和tx既被打开)如果将r3e和h3e方式关闭在按mode键时工作方式将在usb和lsb之间来回切换。
f+0开机可以设置显示信道数目,此机可自定义99个信道。比如你将常用频率放在1---20里面,那么你可以将21-----99隐藏。进入子菜单后按数字键20然后按rx键确定后关机退出。
离线海阔天空
只看该作者 33楼 发表于: 2006-06-14
就是没有ic2200啊.急....
离线bg7iey
只看该作者 34楼 发表于: 2011-06-09
大佬.我的ic-2410h.按住[set] & [mw]再开机不能复位.请问是何原因.
离线bg7iey
只看该作者 35楼 发表于: 2011-06-09
r e p e a t e r s:
ic-rp1220 - turn the power off for a few minutes. push s1 on the logic circuit board.
ic-rp1520 - turn the power off for a few minutes. push s1 on the logic circuit board.
ic-rp4020 - turn the power off for a few minutes. push s1 on the logic circuit board.
离线bd3mv
只看该作者 36楼 发表于: 2018-05-16
这个帖子太好了
