  • 21106阅读
  • 36回复
ICOM机器复位方法 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2004-04-06
h a n d h e l d s:
ic-delta1 - hold [function] & [a] & [clr] buttons and turn the radio on.
ic-2gat - turn the radio on, hold [light] & [function], turn the radio off, then turn back on. release the buttons after the display returns to normal.
ic-2gxat - hold [func] & [vmc] & [dup] & [hi/lo] buttons and turn the radio on.
ic-02at - serial numbers below 34000: push the button on the main circuit board next to the lithium battery. serial numbers above 34000: hold [func] button and turn the radio on.
ic-2ia - hold [light] & [monitor] buttons and turn the radio on.
ic-2sa - hold [light] & [monitor] buttons and turn the radio on.
ic-2sat - hold [function] & [a] buttons and turn the radio on.
ic-2sra - hold [function] & [a] & [clr] buttons and turn the radio on.
ic-p2at - hold [function] & [a] buttons and turn the radio on.
ic-?at - hold [light] button and turn the radio on.
ic-03at - serial numbers below 34000: push the button on the main circuit board next to the lithium battery. serial numbers above 34000: hold [func] button and turn the radio on.
ic-3sa - hold [light] & [monitor] buttons and turn the radio on.
ic-3sat - hold [function] & [a] buttons and turn the radio on.
ic-4ia - hold [light] & [monitor] buttons and turn the radio on.
ic-4gat - turn the radio on, hold [light] & [function], turn the radio off, then turn back on. release the buttons after the display returns to normal.
ic-4gxat - hold [func] & [vmc] & [dup] & [hi/lo] buttons and turn the radio on.
ic-04at - serial numbers below 34000: push the button on the main circuit board next to the lithium battery. serial numbers above 34000: hold [func] button and turn the radio on.
ic-4sa - hold [light] & [monitor] buttons and turn the radio on.
ic-4sat - hold [function] & [a] buttons and turn the radio on.
ic-4sra - hold [function] & [a] & [clr] buttons and turn the radio on.
ic-p4at - hold [function] & [a] buttons and turn the radio on.
ic-12at - hold [func] button and turn the radio on.
ic-12gat - turn the radio on, hold [light] & [function] buttons, turn the radio off, then turn back on. release the buttons after the display returns to normal.
ic-24at - hold [function] & [a] buttons and turn the radio on.
ic-32at - hold [function] & [a] & [light] buttons and turn the radio on.
ic-q7a - hold [func] & [band] & [v/m] buttons and turn the radio on.
ic-t2a - hold [a] & [c] buttons and turn the radio on.
ic-t2h - hold [av] & [ct] buttons and turn the radio on.
ic-t21a - full reset: hold [a] & [*] & [func] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.
ic-t22a - full reset: hold [a] & [*] & [func] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.
ic-t41a - full reset: hold [a] & [*] & [func] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.
ic-t42a - full reset: hold [a] & [*] & [func] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.
ic-t7a - hold [mr] & [vfo] & [band] buttons and turn the radio on.
ic-t8a - hold [mr] & [vfo] & [band] buttons and turn the radio on.
ic-t81a - hold [sql] & [vfo] & [mr] buttons and turn the radio on.
ic-v21at - hold [f] & [a] & [*] buttons and turn the radio on.
ic-w2a - hold [function] & [a] & [clr] buttons and turn the radio on.
ic-w21a - hold [hi/lo] button and turn the radio on.
ic-w21at - hold [f] & [a] & [*] buttons and turn the radio on.
ic-w31a - full reset: hold [a] & [*] & [moni] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.
ic-w32a - full reset: hold [sql] & [vfo] & [mr] buttons and turn the radio on. partial reset: hold [vfo] button and turn the radio on.
ic-z1a - full reset: hold [a] & [*] & [moni] buttons and turn the radio on. partial reset: hold [a] button and turn the radio on.
离线BD3RJ
只看该作者 1楼 发表于: 2004-04-06
m o b i l e s:
ic-27a/h - push the reset button under the top access cover.
ic-28a/h - push the reset button in the aft left corner under the bottom cover.
ic-37a - push the reset button under the top access cover.
ic-38a - push the reset button in the aft left corner under the bottom cover.
ic-47a - push the reset button under the top access cover.
ic-48a - push the reset button in the aft left corner under the bottom cover.
ic-delta100 - full reset: hold [set] & [spch] buttons and turn the radio on. partial reset: hold [spch] button and turn the radio on.
ic-207h - full reset: hold [set] & [s.mw] buttons and turn the radio on. partial reset: hold [v/mhz] button and turn the radio on.
ic-228a/h - hold [squelch/monitor] & [lock] buttons and turn the radio on.
ic-229a/h - hold [set] & [mw] buttons and turn the radio on.
ic-281h - full reset: hold [set] & [spch] buttons and turn the radio on. partial reset: hold [spch] button and turn the radio on.
ic-448a - hold [squelch/monitor] & [lock] buttons and turn the radio on.
ic-449a - hold [set] & [mw] buttons and turn the radio on.
ic-481h - full reset: hold [set] & [spch] buttons and turn the radio on. partial reset: hold [spch] button and turn the radio on.
ic-706 - hold [up] & [down] buttons and turn the radio on.
ic-706mkii - hold [up] & [down] buttons and turn the radio on.
ic-706mkiig - hold [up] & [down] buttons and turn the radio on.
ic-900 - hold [mr] button, turn the power off and then on again.
ic-901a - hold [check] & [mw] buttons and turn the radio on.
ic-1200a - hold down the tuning control and turn the power on.
ic-1201a - hold [squelch/monitor] & [lock] buttons and turn the radio on.
ic-2000h - hold [set] & [pgr/cs/mw] buttons and turn the radio on.
ic-2100h - full reset: hold [set] & [s.mw] buttons and turn the radio on. partial reset: hold [v/mhz] button and turn the radio on.
ic-2340h - full reset: hold [set] & [spch] buttons and turn the radio on. partial reset: hold [spch] button and turn the radio on.
ic-2350h - full reset: hold [set] & [s.mw] buttons and turn the radio on. partial reset: hold [dup] & [low] and turn the radio on.
ic-2400a - hold [sub vol] & [mw] buttons and turn the power on.
ic-2410a/h - hold [set] & [mw] buttons and turn the radio on.
ic-2500a - hold [sub vol] & [mw] buttons and turn the power on.
ic-2700h - full reset: hold [set] & [spch] buttons and turn the radio on. partial reset: hold [spch] button and turn the radio on.
ic-2710h - hold both [s.mw] buttons and turn the radio on.
ic-2800h - full reset: hold 3rd buttons from the top on both sides of the lcd display and turn the radio on. partial reset: hold 2nd buttons from the top on both sides of the lcd display and turn the radio on.
ic-3200a - hold [f] button and turn the radio on.
ic-3210a - hold [squelch/monitor] & [lock] buttons and turn the radio on.
ic-3220a/h - hold [set] & [mw] buttons and turn the radio on.
离线BD3RJ
只看该作者 2楼 发表于: 2004-04-06
v h f / u h f b a s e:
ic-271a/h - reprogram the ram card.
ic-275a/h - hold [m-cl] button and turn the radio on.
ic-375a - hold [m-cl] button and turn the radio on.
ic-471a/h - reprogram the ram card.
ic-475a/h - hold [m-cl] button and turn the radio on.
ic-575h - hold [m-cl] button and turn the radio on.
ic-820h - hold [mw] button and turn the radio on.
ic-821h - hold [mw] button and turn the radio on.
ic-970a/h - hold [mw] button and turn the radio on.
ic-1271 - reprogram the ram card.
ic-1275a - hold [m-cl] button and turn the radio on.
离线BD3RJ
只看该作者 3楼 发表于: 2004-04-06
h f b a s e:
ic-77 - clone with a computer.
ic-707 - hold [mw] & [lock] buttons and turn the radio on.
ic-718 - hold [up] & [down] buttons and turn the radio on.
ic-725 - hold [function] & [mw] buttons and turn the radio on.
ic-726 - hold [function] & [mw] buttons and turn the radio on.
ic-728 - hold [function] & [mw] buttons and turn the radio on.
ic-729 - hold [function] & [mw] buttons and turn the radio on.
ic-735 - no cpu reset available.
ic-736 - hold [clr] & [ent] buttons and turn the radio on.
ic-737 - hold [clr] & [ent] buttons and turn the radio on.
ic-737a - hold [clr] & [ent] buttons and turn the radio on.
ic-738 - hold [clr] & [ent] buttons and turn the radio on.
ic-746 - hold [f-inp] & [m-cl] buttons and turn the radio on.
ic-751 - no cpu reset available.
ic-751a - no cpu reset available.
ic-756 - hold [f-inp] & [m-cl] buttons and turn the radio on.
ic-756pro - hold [f-inp] & [m-cl] buttons and turn the radio on.
ic-761 - hold [m-clear] button and turn the radio on.
ic-765 - hold [m-write] button and turn the radio on.
ic-775 - hold [clear] button and turn the radio on.
ic-775dsp - hold [clear] button and turn the radio on.
ic-781 - hold [m-clear] button and turn the radio on.
离线BD3RJ
只看该作者 4楼 发表于: 2004-04-06
r e p e a t e r s:
ic-rp1220 - turn the power off for a few minutes. push s1 on the logic circuit board.
ic-rp1520 - turn the power off for a few minutes. push s1 on the logic circuit board.
ic-rp4020 - turn the power off for a few minutes. push s1 on the logic circuit board.
离线BD3RJ
只看该作者 5楼 发表于: 2004-04-06
接收鸡
h a n d h e l d s:
ic-r1 - hold [f] and [cl] buttons and turn the radio on.
ic-r2 - hold [func] & [band] & [v/m] buttons and turn the radio on.
ic-r10 - full reset: hold [clr] button and turn the receiver on. rotate the main dial to select yes, then push [ent] button. partial reset: hold [mode] button and turn the radio on.
离线BD3RJ
只看该作者 6楼 发表于: 2004-04-06
b a s e / m o b i l e:
ic-r71a - reprogram the ram card.
ic-r72 - hold [mw] button and turn the radio on.
ic-r75 - hold [up] & [dn] buttons and turn the receiver on.
ic-r100 - hold [func] & [ent] buttons and turn the radio on.
ic-r7100 - hold [mw] button and turn the power on.
ic-r8500 - hold [mw] button and turn the receiver on.
ic-r9000 - hold [m-write] button and turn the radio on.
离线BD3RJ
只看该作者 7楼 发表于: 2004-04-06
海事鸡
h a n d h e l d s:
ic-m1 - push and hold [all clear] button
ic-m1v - clone with a computer.
ic-m5 - push the button on the main circuit board next to the lithium battery.
ic-m7 - turn the radio on, hold [hi-low] & [lock] buttons, turn the power off and on again. push [ch16/d] button to select dial mode.
ic-m8 - hold [light] button and turn the radio on.
ic-m9 - hold [hi/lo] & [dw/scan] buttons and turn the radio on. wait until ch 16 displays on the lcd.
ic-m10 - clone with a computer.
ic-m11 - turn the radio on, hold [light] & [function] buttons, turn the radio off, then turn back on. release the buttons after the display returns to normal.
ic-m15 - hold [hi/lo] & [call] & [dual] buttons and turn the radio on.
ic-gm1500 - clone with a computer.
离线BD3RJ
只看该作者 8楼 发表于: 2004-04-06
m o b i l e s:
ic-m45 - clone with a computer.
ic-m45a - clone with a computer.
ic-m55/b - remove the plastic screw from the bottom cover and push the reset button underneath the screw.
ic-m56 - turn the radio on, hold [ch16] & [mr] buttons, turn off, then turn the radio on again and release the buttons.
ic-m57 - hold [ch16] & [hi/lo] buttons and turn the radio on. hold the buttons for approximately 3 seconds after the radio comes back on.
ic-m58 - clone with a computer.
ic-m59 - clone with a computer.
ic-m80 - disconnect the lithium battery, ground all cpu pins to chassis.
ic-m100 - turn the radio on, hold the squelch knob and press [reset]
ic-m120 - turn the radio on, hold [ch16] & [usa], turn the radio off and then back on.
ic-m125 - hold [func] & [ch16] buttons and turn the radio off and back on.
ic-m126 - hold [func] & [ch16] buttons and turn the radio off and back on.
ic-m127 - clone with a computer.
ic-m500 - hold [dimmer] & [13/67] buttons and turn the radio on.
离线BD3RJ
只看该作者 9楼 发表于: 2004-04-06
n a v i g a t i o n:
ff-88 - no reset available.
fp-561 - hold [menu] button, turn the unit on, choose "all reset" and turn the unit off.
mr-40 - no reset available.
mr-61 - no reset available.
mr-610 - no reset available.
离线BD3RJ
只看该作者 10楼 发表于: 2004-04-06
s s b r a d i o s:
ic-m600 - hold [function] & [ce] and turn the radio on.
ic-m700 - cpu reset not available.
ic-m700pro - clone with a computer.
ic-m710 - clone with a computer.
ic-m710rt - clone with a computer.
ic-m800 - remove dc power from both the control head and the main unit. wait approximately 5 minutes.
ic-m810 - remove dc power from both the control head and the main unit. wait approximately 5 minutes.
离线BD3RJ
只看该作者 11楼 发表于: 2004-04-06
航空鸡
h a n d h e l d s:
ic-a2 - push [f] & [ptt] buttons and turn the radio on.
ic-a3 - hold [f] & [0] & [ent] buttons and turn the radio on.
ic-a4 - no keypad reset, clone with a computer.
ic-a20 - push [f] & [clear] buttons and turn the radio on.
ic-a21 - push [f] & [clear] buttons and turn the radio on.
ic-a22 - hold [f] & [0] & [ent] buttons and turn the radio on.
g r o u n d / m o b i l e:
ic-a110 - clone with a computer.
ic-a200b/m - no cpu reset.
p a n e l m o u n t:
ic-a200 - no cpu reset.
离线BD3RJ
只看该作者 12楼 发表于: 2004-04-06
陆地鸡
p o r t a b l e s:
ic-f3 - reclone
ic-f3g - reclone
ic-f3s - reclone
ic-f4 - reclone
ic-f4g - reclone
ic-f4s - reclone
ic-f4tr - reclone
ic-f10 - reclone
ic-f20 - reclone
ic-f30 - reclone
ic-f30lt - reclone
ic-f40 - reclone
ic-f40lt - reclone
ic-h8 - reclone or hold [ptt] & [clone] buttons and turn the radio on.
ic-h10 - reclone or hold [ptt] & [clone] buttons and turn the radio on.
ic-h16 - reclone
ic-h18 - reclone
ic-h19 - reclone
ic-u8 - hold [ptt] & [clone] buttons and turn the radio on.
ic-u10 - hold [ptt] & [clone] buttons and turn the radio on.
ic-u16 - reclone
ic-u18 - reclone
ic-u19 - reclone
离线BD3RJ
只看该作者 13楼 发表于: 2004-04-06
m o b i l e s:
ic-f320 - reclone
ic-f320s - reclone
ic-f420 - reclone
ic-f420s - reclone
ic-f1020 - reclone
ic-f2020 - reclone
ic-u200 - reclone
ic-u220 - reclone
ic-u400 - reclone
ic-v100 - reclone
ic-v200 - reclone
ic-v220 - reclone
离线BD3RJ
只看该作者 14楼 发表于: 2004-04-06
r e p e a t e r s:
ic-rp1620 - turn the power off, wait a few minutes and turn the power back on.
ic-rp4520 - turn the power off, wait a few minutes and turn the power back on.
ic-ur8050 - turn the power off, wait a few minutes and turn the power back on.
离线bd3uv
只看该作者 15楼 发表于: 2004-04-09
谢版主!提供这么多资料。
bd3uv@163.com
离线小嘟嘟嘴
只看该作者 16楼 发表于: 2004-04-11
我即将有一个21at了,我有什么不懂的地方要多多请教版主哦!
离线梁山火腿
只看该作者 17楼 发表于: 2004-04-24
好象没有发现t90a的手持机?
离线ncham
只看该作者 18楼 发表于: 2004-04-30
斑竹
请问有ic-02n的改频资料没???
谢谢!!!
离线BD3RJ
只看该作者 19楼 发表于: 2004-04-30
好象没有发现t90a的手持机?
印象里90在菜单里有复位选项。没写的型号就是没有这个功能或是没找到。
