  • 6684阅读
  • 67回复
CQ游~VR2RC70纪念电台ARES [复制链接]
离线vr2yxn
只看该作者 20楼 发表于: 2019-08-10
离线vr2yxn
只看该作者 21楼 发表于: 2019-08-12
离线vr2yxn
只看该作者 22楼 发表于: 2019-08-12
离线vr2yxn
只看该作者 23楼 发表于: 2019-08-12
离线vr2yxn
只看该作者 24楼 发表于: 2019-08-12
离线vr2yxn
只看该作者 25楼 发表于: 2019-08-12
离线vr2yxn
只看该作者 26楼 发表于: 2019-08-12
离线vr2yxn
只看该作者 27楼 发表于: 2019-08-12
离线vr2yxn
只看该作者 28楼 发表于: 2019-08-12
离线vr2yxn
只看该作者 29楼 发表于: 2019-08-14
离线vr2yxn
只看该作者 30楼 发表于: 2019-08-14
离线vr2yxn
只看该作者 31楼 发表于: 2019-08-14
离线vr2yxn
只看该作者 32楼 发表于: 2019-08-14
离线vr2yxn
只看该作者 33楼 发表于: 2019-08-14
离线vr2yxn
只看该作者 34楼 发表于: 2019-08-14
离线vr2yxn
只看该作者 35楼 发表于: 2019-08-16
NOAA圖片格式
The Automatic Picture Transmission (APT) system is an analog image transmission system developed for use on weather satellites. It was introduced in the 1960s and over four decades has provided image data to relatively low-cost user stations at locations in most countries of the world. A user station anywhere in the world can receive local data at least twice a day from each satellite as it passes nearly overhead.
Transmission
                         The APT transmission format
Structure
The broadcast transmission is composed of two image channels, telemetry information, and synchronization data, with the image channels typically referred to as Video A and Video B. All this data is transmitted as a horizontal scan line. A complete line is 2080 pixels long, with each image using 909 pixels and the remainder going to the telemetry and synchronization. Lines are transmitted at 2 per second, which equates to a 4160 words per second, or 4160 baud.
离线vr2yxn
只看该作者 36楼 发表于: 2019-08-16
Images
On NOAA POES system satellites, the two images are 4 km / pixel smoothed 8-bit images derived from two channels of the advanced very-high-resolution radiometer (AVHRR) sensor. The images are corrected for nearly constant geometric resolution prior to being broadcast; as such, the images are free of distortion caused by the curvature of the Earth.
Of the two images, one is typically long-wave infrared (10.8 micrometers) with the second switching between near-visible (0.86 micrometers) and mid-wave infrared (3.75 micrometers) depending on whether the ground is illuminated by sunlight. However, NOAA can configure the satellite to transmit any two of the AVHRR's image channels.
离线vr2yxn
只看该作者 37楼 发表于: 2019-08-16
离线vr2yxn
只看该作者 38楼 发表于: 2019-08-16
离线vr2yxn
只看该作者 39楼 发表于: 2019-08-16
