  • 2010阅读
  • 4回复
缩略语BN [复制链接]
在线BG1TRP
只看楼主 倒序阅读 0楼 发表于: 2017-10-26
关于缩略语BN网上有两种说法,
一种是:been
一种是:all between
不知哪个是对的,还是不同地区有不同的用法?
三合一台咪套件
天线切换器套件
离线bl7ia
只看该作者 1楼 发表于: 2017-10-27
可能以前 大量通訊內容才用
The repetition signals AA, AB, WA, WB and BN
If only a part of the message has not been received properly then it would send as follows:
RPT AA: Repeat all after
RPT AB: Repeat all before
RPT WA: Repeat word after
RPT WB: Repeat word before
RPT BN: Repeat word between
Example:
“Repeat all before group Kilogrammes” – RPT AB Kilogrammes
“Repeat all between words ‘boats’ and ‘survivors’” – RPT BN boats and survivors
The transmitting station on completing of transmission may send the signal RPT and then commence re-transmitting the entire message.
If however the transmitting station transmits RPT at the end of its transmission and then does not re-transmit then it would mean that it is requesting the receiving station to repeat the entire transmission of what it has received.
K.C Yeung
在线BG1TRP
只看该作者 2楼 发表于: 2017-10-27
回 bl7ia 的帖子
bl7ia:可能以前 大量通訊內容才用
....... (2017-10-27 13:18)
豁然开朗
三合一台咪套件
天线切换器套件
离线bh3aip
只看该作者 3楼 发表于: 2017-10-29
看来我还要继续学习英语
只看该作者 4楼 发表于: 2017-11-05
都是懒人整出来的
