  • 8230阅读
  • 10回复
SmartSDR 2.0即将发布 [复制链接]
离线BA7NQ
只看楼主 倒序阅读 0楼 发表于: 2017-07-23
https://community.flexradio.com/flexradio/topics/smartsdr-v2-0-17-now-available
FlexRadio Systems announces the immediate availability of SmartSDR v2.0.17 for the FLEX-6000 Signature Series SDRs.  SmartSDR v2.0.17 is a General Availability (GA) release containing new features and fixes for SmartSDR for Windows, SmartSDR for Maestro, SmartSDR CAT and DAX.
SmartSDR 2.0.17 can be downloaded from the FlexRadio Systems web site. Please download and review the SmartSDR v2.0.17 Release Notes and SmartSDR for Maestro Release Notes prior to installing SmartSDR v2.0.17 to ensure an optimal software installation experience.
SmartSDR v2.0.17 is the first release of SmartSDR v2.  A software license is required to run SmartSDR v2.
All owners of the Limited Edition (LE) FLEX-6700 and FLEX-6500 SDRs or radios sold after May 19, 2017, have been pre-authorized for SmartSDR v2 and do not require the purchase of a SmartSDR v2 license.  To run SmartSDR v2 on all other radios requires the purchase of a software license for the radio.
Obtaining and validating a license for your FLEX-6000 software defined radio is a simple process.  Once the radio and client have network access to the Internet, just load any version of the SmartSDR v2 software on your PC or Maestro.  In the radio chooser, if a radio requires a license, a status message will indicate a license is required before connecting to the radio and updating the firmware.  A “Buy” button is also presented so that you can conveniently purchase a SmartSDRv2 license using our Online Store.  Please see details below regarding purchasing a SmartSDR software license for your radio.
The following highlights are SmartSDR specific features:
Initial Release of SmartLink (Internet remote access) with SmartSDR CAT:   SmartLink is the integrated remote access feature that does not require additional hardware, complicated VPNs or remote desktop software.  Setting up SmartLink is a straightforward process.  Just create a secure user account, log in to the account, associate a radio with your account and establish a remote connection.
It is highly recommended that you review the SmartLink Quick Start Guide for SmartSDR and the SmartLink Quick Start Guide for Maestro available on the FlexRadio Systems web site before installing SmartSDR v2.0.17.  More detailed information regarding the operation of SmartLink is available in the SmartSDR Software User’s Guide and the SmartSDR for Maestro Software User Guide.
SmartSDR CAT is also SmartLink enabled, allowing you to use a logger or any other CAT enabled application in a remote setting.  Like SmartSDR for Windows, you will need to login to SmartSDR CAT with your user ID and connect to your SmartLink enabled radio.
Pop Out Panels: The ability to “pop out” or undock panadapters and the CWX and TX sidebar panels is included in SmartSDR v2.0.17.  This new feature allows you to undock panadapters and move them to different locations on your Windows Desktop.  This capability also extends to the CWX and TX sidebar panels as well.  Once undocked, their display position is remembered after SmartSDR is closed and restarted.  Note that there must be at least one panadapter in the main console windows, but subsequently created panadapters can be undocked.
Support for N1MM Spectrum Display Feature: SmartSDR v2.0.17 now provides support for the new Spectrum display feature with integrated spots in N1MM+ (v 1.0.6559 and greater).  For more information on the N1MM+ Spectrum feature, refer to the N1MM website.
Improved Dynamic Range for FLEX-6300: The IMD dynamic range performance of the FLEX-6300 has been improved in this release by a software modification.  This change benefits all FLEX-6300s.
Additional RF Preamp Gain for FLEX-6700 and FLEX-6700R: An additional +10 dB of RF preamp gain has been enabled in the FLEX-6700 and FLEX-6700R.  When operating on higher frequency bands where the antenna is not noise limited (a low noise floor), you can enable up to +40 dB of RF gain.  Please refer to the HelpDesk article How to determine the amount of RF Preamp gain to apply for band conditions for configuring the RF preamp for maximum SNR performance.
New TURFs: New region/entity specific TURF files have been added for IARU Region 2 and Australia (Update #4529 and #4951).
New FlexVSP driver: A new and updated FlexVSP driver (v1.0.6) used with SmartSDR CAT is included in SmartSDR v2.0.17.  The driver installs automatically.  This virtual serial port driver has better performance and stability characteristics than the previous version, especially when used on Windows 10. This updated FlexVSP driver also corrects an existing defect #4394, Serial Ports left "in use" when CAT is shut down. After installing SmartSDR v2.0.17, you will have to manually reset and clear any com ports currently in use by using the HelpDesk procedure Removing "In Use" Com Ports for Available Com Ports
Maestro: X/RIT Readouts Added:   When using XIT or RIT the offset frequency is shown on the display (Feature #4353).
New metering sidebar for Maestro:   A new feature has been added to Maestro that provides a user definable metering side bar that will always show RF Power output, SWR, Mic Level, Compression, and hardware ALC voltage levels.  The new metering side bar is activated by tapping the “Meters>” menu control at the bottom right-hand corner of the screen (Feature #3087).
Corrected Maestro Disconnect Issues:   Multiple disconnect issues have been addressed in SmartSDR v2.0.17, including disconnects related to connection state when using a WiFi  connection, too many clients connections were left in an open state, and client-side out of memory errors  (Defects #4566, #4305, #4428, #4731)
Maestro: Issue with RF Preamp Not Being Set Properly Resolved:   A defect that prevented the RF preamp form properly setting the RF preamp has been resolved (Defect #4676)
SmartSDR for iOS
In addition, SmartSDR for IOS v2 is also available from the Apple App Store.
This update includes several improvements and user requested features.
First of all, this update supports all new features of Version 2 of SmartSDRTM for Windows which includes Remote Access via SmartLinkTM.
In addition, this update includes:
Improved slice touch / moving
Option to enable the statusbar (Battery, WiFi Status)
Option to reverse the tuning wheel
Griffin and CMD Micro: New Commands for Slice and main Mute added
Additional user hints in case of wrong settings
Finally, the following bugs were fixed:
In DX-Cluster, now six digit GRID QTH Locators are working
Griffin Powermate de-bouncing time reduced
In Remote Mode, the Tuning Wheel now stays displayed
Crash when editing Memories fixed
Crash when editing USB Cables
DX-Cluster Filter settings are now saved to iCloud
The cumulative SmartSDR v1.10.17 Change Log detail is listed below.
#5092    Fixed Maestro not working properly if downgraded from 2.0.15 to 1.10.16
#4992    CAT: Make new chooser more obviously different to avoid confusion
#4951    Add new Australian region to TURF
#4870    IMD DR3 Performance enhancements for FLEX-6300
#2497    Fix spur on 6M
#4847    Rapid band changes no longer show duplicate slices
#4910    Fix UHE on CAT exit
#4904    UHE on forced disconnect
#4902    Fix UHE related to ModeList
#4867    Fix UHE related to disconnect in RadioChooser
#4879    SmartSDR: Fix no profile list or TX settings in TX panel
#4892    Fix VOX level being lost on reboot
#4824    CAT: Add radio chooser (enabled CAT use with SmartLink)
#4595    CAT: Avoid creating COM ports that are reserved
#4848    Fix memory leak when changing global profiles
#4831    Fix CW Delay being reset to 0 after update
#4825    FlexLib: API zip file no longer needs extra steps to compile after decompressing
#4777    Fix pan edge tuning with FlexControl after profile load
#4774    DAX and CAT v2.0.X versions no longer connect to non 2.0 versions
#4688    Add CAT and radio support for streaming panadapter data to N1MM
#4772    Add 6M NF improvement by adding +40dB preamp setting for 6700 and 6700R
#4789    Maestro: Fix network status bars
#4769    Add slice button no longer defaults to USB all the time
#4625    Mic Profile load correctly sets up Mic Input
#4779    Maestro: Radio chooser entry text no longer overlaps with long FQDNs
#4767    Added headphone volume control to FlexControl
#4771    Maestro: Slice menu is now automatically closed when the ENT button is pressed
#4353    Maestro: Add XIT/RIT readouts when in use
#4394    CAT: VSP driver updated to v5.5.5.0 (should fix the serial ports 'in-use' problem)
#4798    Fixed radio crash
#4687    SmartLink: Fix distortion on transmit audio
#4747    Maestro: Fix CW issue that would disable Maestro CW
#4625    Profiles: Fix several instances of profiles showing up modified when they weren't and incorrect MIC input on startup
#4780    Remote TX audio buffering improvements
#3087    Maestro: Add "METERS" sidebar button
#4762    Maestro:  Fixed a bug where more than two slices could appear
#4781    Maestro: Added "Switch Radio" button that takes the user back to the radio chooser window (Menu -> Radio)
#4714    Fix UHE when closing SmartSDR
#4708    API: Fix meter conversion based on software version
#4733    Reduced UDP receive buffer size (memory usage improvement)
#4731    Maestro: Fix out of memory on client disconnect
#4724    Fix disconnect of client by another client (no longer hangs on 'in-use')
#1075    RemoteAudio: Handle out of order packets (should result in improved audio through SmartLink)
#4655    Fix FlexControl not working on startup
#4676    Fix Maestro preamp control not working
#4675    Fix Maestro LEDs
#4455    Initial SmartLink Alpha Implementation
#4410    Fixed XVTR Power Persistence
#4312    TX Watchdog added to ensure radio goes back to RX if a crash is encountered while transmitting
#4428    Fixed crash due to many clients connecting and disconnecting (just under 200)
#4334    Updates show Unable to contact radio message after updating the radio
#4305    Fixed Maestro disconnect during upgrade over Wifi
#4305    Initial PowerGenius XLTM Functionality
#4412    FPS Now loaded from persistence on direct frequency band change
#4335    Fix transmit slice references in FlexLib
#4433    Fix zoom buttons in SmartSDR
#4470    Radio protocol version now v1.3.0.0
#4486    TX Filter no longer cuts off TUNE tone in DIGU/L and USB/LSB
#4511    Fixed issue with opening the profile import/export form if the old import filepath no longer exists
#4507    Fixed a rare UHE that occurs when the radio is disconnecting
#1008    Meters now support the change in voltage depending on radio version
#4172    CWX: Closing a slice while sending CWX no longer leaves radio in keyed state
#4512    RTTY: Tune no longer gets cut off by TX Filter
#4544    Sideband Suppression: Implement low-cut dependent filter sharpness to fix suppression when low cut is below 200Hz
#4533    TUNE now works properly in USB/LSB/DIGU/DIGL when CWL is selected
#4547    CWX: Radio no longer stays keyed when erasing the last character
#4542    CWX: 'cwx erase' no longer triggers a 'cwx clear' from CAT
#4529    Added IARU Region 2
#4540    DSTAR no longer shows up in cable type in SmartSDR
#2563    First band change to XVTR band now creates slice on correct frequency (instead of LO)
#1570    RFGain Persistent across antenna changes
#4482    RFGain Persistent when changing TX Slice (affected SO2R )
#4245    Can now use DAX and Remote TX Audio (Maestro) with VOX at the same time. (DAX Overwrites if audio is present)
#2910    CAT:  Improved resiliency of client settings when the PC reboots
#4575    CAT:  Fixed ZZSW1 not working properly
#4565    Fixed a UHE related to the FlexControl
#4566    Fixed several connect/disconnect issues with clients
#4583    API: 'remote_audio' replies with correct responses instead of 'unknown'
#4589    API: Persistence loads from 'client gui' command instead of 'client udpport <port>' command
#4585    USB: SO2R TX Antenna fixes (BCD does not drop out when TX slice changes)
#4597    CAT: Fixed problem with CAT split mode
#3988    Added pop-out panadapters, CWX and TX windows
#4113    VOX: Fix intermittent key when VOX is used with DAX
#4586    Fix crash with client disconnect
#3641    Remote Audio: Upgrade OPUS Codec - 10% Less CPU Usage
离线BD7OH
只看该作者 1楼 发表于: 2017-07-23
站长,整个教程吧
73's
http://www.qsl.net/bg7oh
6 METER DXCC #622[/SIZE][/COLOR]
只看该作者 2楼 发表于: 2017-07-23
嚯嚯,别忘了天朝有伟大的wall
离线BA7NQ
只看该作者 3楼 发表于: 2017-07-25
回 BD7OH 的帖子
BD7OH:站长,整个教程吧[表情]  (2017-07-23 12:34)
我现在也没有拿到软件,等发布后我弄一下。
离线BA7NQ
只看该作者 4楼 发表于: 2017-07-25
回 爱不交租 的帖子
爱不交租:嚯嚯,别忘了天朝有伟大的wall (2017-07-23 23:49)
活在当下,等出来后试一下才有结论。
离线BD3RJ
只看该作者 5楼 发表于: 2017-08-17
Stay Here Forever!
在线BG5ILE
只看该作者 6楼 发表于: 2017-08-17
要199USD?
离线BD3RJ
只看该作者 7楼 发表于: 2017-08-20
嗯                         哪
Stay Here Forever!
离线bg6knl
只看该作者 8楼 发表于: 2017-11-23
这个有没有破解的啊?
离线bd8uk
只看该作者 9楼 发表于: 2018-03-20
smartSDR v2.1.33版本已出,大家赶紧更新去喽!
只看该作者 10楼 发表于: 2018-11-19
3.0快了,大家准备好零钱
