  • 41266阅读
  • 21回复
一大堆的SDR软件,此帖有剧毒!严正声明:解药不要找我.... [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2015-12-06
先记号,有空慢慢看
http://www.sdr-j.tk/index.html
[ 此帖被爱不交租在2015-12-13 11:29重新编辑 ]
我读书少  不要骗我
只看该作者 1楼 发表于: 2015-12-06
http://sdr.ipip.cz/software
再记号一个网址,虽然有点旧,但还是有点意思的汇总了一些SDR硬件和软件信息..
我读书少  不要骗我
只看该作者 2楼 发表于: 2015-12-13
我读书少  不要骗我
只看该作者 3楼 发表于: 2015-12-13
http://www.rtl-sdr.com/big-list-rtl-sdr-supported-software/
February 11, 2014
The BIG List of RTL-SDR Supported Software
There are now dozens of software defined radio packages that support the ultra cheap RTL-SDR.On this page we will attempt to list, categorize and provide a briefoverview of each software program. We categorize the programs intogeneral purpose software, single purpose software, research software andsoftware compatible with audio piping.
If you know of a program that is missing please leave a comment in the comments section at the bottom of the page.
13/02/2014– Added Sodira, gr-wmbus, rtlsdr-waterfall, QTRadio, multimon,sdrangelove, lte-scanner, rtl_tcp, rtl_sdr_FS20_decoder.
17/02/2014 – Updated the Linrad description.
28/04/2014 – Added Modesdeco and Trunk88.
30/05/2014 – Added RTL Panorama, RTL SDR Panoramic Spectrum Analyzer,Chrome Radio Receiver, SeeDeR, DAB Player, RTL SDR Installer, PD/MaxWrapper, SDRWeather, LTR Analyzer, softEOT/softDPU and ScanEyes.
26/07/2014 – Added PiAware, OOK-Decoder, rtl_fm_python, rtl_powerheatmap viewer, RTL Bridge, threejs-spectrum, CANFI Software, PNAIS,FLARM Decoder, Xastir, RTLSDR-Airband, SDRTrunk.
13/11/2014 – Added Touchstone, RFAnalyzer, RTL1090 XHSI Interface, Parus Decoder, PlotRTL1090, LRPT Decoder.
05/02/2015 – Added rtl_tool_kit, CubicSDR, OregonWeather, FreqWatch.
15/04/2015– Added ADSBox, YouSDR, FlightAware Flight Feeder, Frequensea, Trackyour flight EUROPE, QSpectrumAnalyzer, Doppler & Demod, Redsea,rtl_heatmap, gr-gsm, driveby, SDRecord.
General Purpose RTL-SDR Software
We define general purpose SDR software as programs that allow the RTL-SDR to work like a normal wideband radio receiver.
SDR# (Windows) (Free)
SDR#
SDR#(pronounced “SDR Sharp”) is the most popular free RTL-SDR compatiblesoftware in use at the moment.  It is relatively simple to use comparedto other SDR software and has a simple set up procedure. We have a fulloverview of the installation procedure on our Quick Start Page.
SDR# is a simple to use program that also has some advanced features. It has a useful modular plugin type architecture, and many plugins have already been developedby third party developers. The basic SDR# download without any thirdparty plugins includes a standard FFT display and waterfall, a frequencymanager, recording plugin and a digital noise reduction plugin. SDR#also decodes RDS signals from broadcast FM.
HDSDR (Windows) (Free)
HDSDR
HDSDRis based on the old WinRAD SDR program. HDSDR supports the RTL-SDRthrough use of an ExtIO.dll module. To install HDSDR, download theprogram from the link on the main HDSDR page, then to use the RTL-SDRyou will need to download the ExtIO_RTL2832.dll file an place it intothe HDSDR folder. When opening HDSDR, select the newly copiedExtIO_RTL2832.dll. The other dlls that come with HDSDR will not workwith the RTL-SDR, even though they have RTL-SDR in their filename. Theofficial installation instructions can be found here.
Alongwith a FFT display and waterfall, HDSDR has some extra advancedfeatures. Users will also find an Audio FFT and waterfall display on thebottom of the screen. The output audio can also be bandpass filtered bydragging the filter borders on the display. Bandpass filtering theaudio can really help clean up a noisy signal. The audio processing alsosupports placing of notch filters either manually or automatically.There are also noise reduction and noise blanker features and anautomatic frequency centering algorithm which will automatically centerthe signal, so you don’t need to click exactly in the center of asignal. Traditional ham radio users will also enjoy the S-units signalstrength meter and the built in frequency manager.
SDR-RADIO.COM V2 (Windows) (Free)
SDR-RADIO.COM V2
SDR-RADIO.COMV2 is a popular SDR program with many advanced features. As such is it afair amount more difficult to learn and use compared to SDR# and HDSDR.Be sure you install version 2 and not V1.5 as only V2 has RTL-SDRsupport.
Once sdr-radio is installed, to get it working with theRTL-SDR you will need to compile or download three .dll files(SDRSourceRTL2832U.dll, rtlsdr.dll and libusb-1.0.dll) and place theminto the sdr-radio folder. To compile your own dlls see the instructions here, otherwise download the dlls directly from the bottom of this link.If the dlls were placed in the correct folder you will be able to addyour RTL-SDR as a receiver by clicking on the +Definitions button, andthen finding and adding the RTL SDR (USB) option under the search dropdown menu.
Like HDSDR, not only does sdr-radio have a RF FFTsignal and waterfall display, but also an optional audio spectrum FFTand waterfall display. Built in are also several DSP features like anoise blanker, noise reduction filter, notch filter and squelch options.The EMNS noise reduction filter is particularly good at automaticallycleaning up and clarifying voice signals.
To add to the featurelist, sdr-radio also has built in PSK, RTTY and RDS decoders, and alsocomes with a satellite tracker. Furthermore, sdr-radio has an excellentremote server which will allow you to easily set up and connect to aremote RTL-SDR server over a network or the internet. Finally, sdr-radiois capable of listening to up to 6 signals in the same chunk of visiblespectrum at a time.
Linrad (Windows/Linux/Mac) (Free) (Related Post)
Linrad
Linradis a free advanced SDR program with a steeper learning curve comparedto most other SDR programs. Many users prefer to use Linrad as it can beset up to have a very high amount of information density on the screenand it also has an advantage with receiving signals with the E4000 tuneras it can be made it run in a special linearity mode whichsignificantly improves the dynamic range.
Linradalso has some very advanced features not found in most other SDRreceivers. It has multi-frequency interval I/Q correction, a verypowerful “smart” noise blanker, multicast output, weak signal optimizedwaterfall, settings to aid in taking performance measurements, two RFchannel input, superior AGC and an adaptable automatic frequencycontroller (AFC). Linrad is probably the software most superior in termsof actual signal processing performance.
To install Linrad onWindows first download and run the setup-dll installer, and thendownload and extract the actual Linrad program. You will need to gothrough a text based set up at the very beginning.
GQRX (Mac/Linux) (Free)
GQRX
GQRXis a free simple to use SDR receiver which runs on Linux and Macsystems. It is similar to SDR# in terms of features and simplicity ofuse. GQRX comes with a standard FFT spectrum and waterfall display and anumber of common filter settings.
CubicSDR (Linux/Windows/Mac) (Free)
CubicSDR
A new cross platform SDR receiver which is based on the liquid-dsp libraries.
Studio1 (Windows) (Paid)
Studio1
Studio1is a non-free commercial SDR receiver with advanced DSP capabilities,and is claimed to have the lowest CPU usage of any general purpose SDRsoftware. Studio1 supports the RTL-SDR through use of an ExtIO.dllmodule.
Studio1’s main selling point is that it claims that itsspur/alias free dynamic range is greater than 130 dB compared to the 70dB that most free SDR software programs have (spurious free dynamicrange influences the capability of the receiver to resolve small signalsin presence of in-band strong signals). It also claims that it has avery efficient DSP engine that can run well on older Pentium 4 machines.
ShinySDR (GNU Radio) (Free) (Related Post)
ShinySDRis an SDR application built in GNU Radio with a web based interface. Itis currently in a usable state, but is still undergoing majordevelopment. Since ShinySDR is controlled via a web interface it caneasily be controlled over a network or the internet. It also has aplugin type development feature which allows demodulators to be easilywritten and integrated.
The current main technical advantage toShinySDR is that it has a persistent waterfall, meaning that thewaterfall can be moved, zoomed and re-tuned without loss of any historylike in other SDR software.
WebRadio (Linux) (Free) (Related Post)
WebRadio
WebRadiois a Linux based application that is attempting to build an open sourcesystem for the RTL-SDR and other software defined radios similar to theclosed source WebSDR . The WebSDR system allows for multiple publicusers to connect to a radio over the internet and tune to variousfrequencies. WebRadio is currently functional but still underdevelopment.
Sodira (Windows) (Trial/Paid)
Sodira
Sodirais a Windows application that is capable of decoding AM and FM+RDSradio as well as DRM/DRM+ and time signals DCF77/HBG. It supports theuse of the RTL-SDR through use of the ExtIO_RTL2832.dll module. The sameExtIO_RTL2832.dll module that is used with HDSDR and whose download islinked to in this HDSDR tutorialcan be used with Sodira. Just place the dll in the same folder asSodira, and then under Configuration->Receiver select the dll fileand then click on HW Init + Start to activate the RTL-SDR.
SDR Touch (Android) (Trial/Paid) (Related Post)
SDR Touch
SDRTouchwas the first Android based RTL-SDR software receiver available. Thereis a free restricted trial version and the full version can be boughtfrom the Google Play store. To run SDR Touch you need a modern Android4.0+ device with decent processing power and USB OTG support. You willalso need a USB OTG cable to connect to the Android device to an RTL-SDRdongle.
SDR Touch has several standard features such as FFTspectrum and waterfall displays, WFM/FM/AM/SSB tuning and a frequencymanager.
Wavesink Plus (Android) (Trial/Paid) (Related Post)
Wavesink Plus
WavesinkPlus is another Android based RTL-SDR receiver with a free trial andpaid full version. Wavesinks main feature is that it is capable ofdecoding DAB+ and DRM+ digital radio signals. As well as the digitalradio signals, it can also receive standard FM and do FM-RDS decoding aswell. To use Wavesink, like SDR Touch you will need a decently powerfulAndroid 4.0+ device with USB OTG cable.
RFAnalyzer (Android) (Free/Paid)
Androidapp similar to SDR Touch. Originally for the HackRF, but now alsosupports the RTL-SDR. Still under heavy development. Available for asmall price on the Google Play store, or for free from the GitHub.
cuSDR (Windows) (Free)
cuSDR
An SDR receiver intended for use with the HPSDR project SDR hardware, but can be used with the RTL-SDR through use of the RTL_HPSDRtranslation server program. One advantage to cuSDR is that it cansupport up to seven simultaneous RTL-SDR dongles. cuSDR is stillcurrently under development.
PowerSDR (Windows) (Free)
PowerSDR
PowerSDRis an SDR receiver intended for use with the FlexRadio SDR hardware. Itis compatible with the RTL-SDR through use of the RTL_HPSDR translation server program. PowerSDR is capable of supporting up to four simultaneous RTL-SDR dongles.
QtRadio (Windows/Linux) (Free)
QtRadio
QtRadiois an open source SDR receiver that is based on a client-serverarchitecture from the ground up. It is designed so that multiple clientscan connect to a single server. QtRadio comes with a special RTL-SDRserver which you will need to download and run.
Multimode (GNU Radio) (Free)
A simple GNU Radio based “multi mode” receiver which can receive AM, FM, SSB, WFM, and TV-FM.
Sdrangelove (Linux) (Free)
Sdrangelove
Sdrangelove is an SDR receiver primarily designed for the OsmoSDR hardware but also supports the RTL-SDR.
SeeDeR (Windows) (Free)
SeeDeR Software Defined Radio GUI
SeeDeris a general purpose SDR GUI that has a focus on decoding data fromsatellites. Legality Note: SeeDeR may be an illegal clone of SDR#. Ifthis is proven in the future we will remove links to SeeDeR on our site.
Single Purpose RTL-SDR Software
Herewe list single purpose RTL-SDR supported software. By single purpose wemean an application that decodes a single protocol, or performs asingle function.
RTL SDR Installer (Windows) (Free)
A script that can be used to aid in installing the RTL-SDR. Works on XP and abov
RTL_FM (Windows/Linux) (Free)
RTL_FMis a command line based FM receiver for the RTL-SDR which is bundled inthe official RTL-SDR release. It is extremely useful in Linux as it canbe used to pipe decoded FM audio to decoder software.
SoftFM (Linux) (Free)
SoftFMis a command line FM receiver for the RTL-SDR that is similar toRTL_FM. The difference is that SoftFM claims to get much better audioresults compared to RTL_FM.
RTL_UDP (Windows/Linux) (Free) (Related Post)
RTL_UDP is a modification of RTL_FM which allows FM audio to be broadcast over a network or the internet via UDP.
RTL_TCP (Windows/Linux) (Free)
RTL_TCPis used to stream IQ data from the RTL-SDR over a TCP network. Manyprograms can connect to this, for example in SDR# there is theRTL-SDR/TCP option.
RTL_FM_PYTHON (Windows/Mac/Linus) (Free)
rtl_fm_python
A Python program based on rtl_fm that allows you to tune to any station using a web interface.
RTLSDR Scanner (Windows/Linux/Mac) (Free) – Wideband Frequency Scanner
RTLSDR Scanner
RTLSDRScanner is a simple cross platform python based wideband spectrumanalyzer for the RTL-SDR. It can scan an arbitrarily large frequencybandwidth. The scanner also has an auto calibration feature which canhelp find the PPM offset of a dongle. Newer versions also have a GPSfeature, which allows you to interface a hardware GPS receiver to thesoftware and do signal mapping experiments.
RTL-SDR Wide Spectrum Analyzer (Windows) (Free) – Wideband Frequency Scanner
RTL-SDR Wide Scanner
Similar to the RTLSDR scanner but written in the basic for gambas programming language. Essentially a front end for rtl_power.
RTL Panorama (Windows) (Free) – Wideband Frequency Scanner
RTL Panorama
Anotherwideband RTL-SDR scanner but based on the command line softwarertl_power. Essentially a GUI interface for rtl_power. Scans much fastercompared to RTLSDR Scanner.
RTL SDR Panoramic Spectrum Analyzer (Windows) (Free) – Wideband Frequency Scanner
Another GUI interface for rtl_power. Similar in function to RTL Panorama.
SDR-J (Windows/Linux) (Free) (Related Post) – DAB
SDR-J
SDR-Jis a free program that is split into two different programs. There isthe SDR-J DAB/DAB+ receiver program and the SDR-J FM decoder program.The DAB decoder is the most popular of the two. To install the SDR-J DABreceiver go to the SDR-J website and download the dabstick-radio.zipfile, unzip it and run dabreceiver.exe. If your RTL-SDR is plugged inyou’ll be able to click the start button and begin choosing the DAB bandin your country using the left drop down box.
DAB Player (Windows) (Free) – DAB
RTL2832U DAB Player
DAB Player is software for listening to DAB radio. It requires use of the official manufacturer RTL2832U drivers.
RTL-SDR Radio Receiver for Chrome (Chrome)(Free) (Related Post) – FM Receiver
Chrome RTL-SDR App
An RTL-SDR WBFM receiver app for Chrome. Runs in the Chrome browser and works on Chrome Books too.
ADSB# (Windows) (Free) (Related Post) – ADS-B Decoder
ADSB#
ADSB#is a Windows Mode S ADS-B decoder for the RTL-SDR written by the authorof SDR#. Use this program to broadcast data via TCP/IP locally via TCPto a graphical radar program such as Virtual Radar Server, Planeplotteror adsbSCOPE.
RTL1090 (Windows) (Free)  (Related Post) – ADS-B Decoder
RTL1090
RTL1090is another Windows Mode S ADS-B decoder for the RTL-SDR. As with ADSB#you need to use this program to broadcast data via TCP/IP to a graphicalradar program. The latest installation program known as the RTL1090 IMUsimplifies the installation by automatically downloading some required.dll files. The current series 2 beta version aims to improve decodingand also has a built in radar display.
dump1090 (Windows/Linux) (Free) (Related Post) – ADS-B Decoder
Dump1090is a lightweight command line Windows and Linux based Mode S ADS-Bdecoder. It also has a built in web service which can display thedecoded aircraft positions on Google maps. Many people report thatdump1090 has the best decoding performance.
ADSBox (Linux) (Free) (Related Post) – ADS-B Decoder
AnADS-B decoder similar to dump1090, with built in web interfaceand Google maps interface. Also has a Google Earth interface. Link is inRussian, see the Related Post for extra info about compilation. The ADSBox web interface
Modesdeco (Windows/Linux/Mac/RPi) – ADS-B Decoder
Amultiplatform command line based ADS-B Mode S and Mode A/C decoder forthe RTL-SDR. Can feed Basestation natively without the need for com portconverters. Can also decode Mode S and mode A/C simultaneously.
cocoa1090 (Mac) (Free) (Related Post) – ADS-B Decoder
Cocoa1090 is a Mac based Mode S ADS-B decoder. It connects to the RTL-SDR via rtl_tcp.
gr-air-modes (GNU Radio) (Free) (Related Post) – ADS-B Decoder
gr-air-modes is a GNU Radio based program which performs Mode S ADS-B decoding.
ADS-B on USB SDR RTL (Android) (Paid) (Related Post) – ADS-B Decoder and Radar
ADS-B Decoding on Android
ADS-Bon USB SDR RTL is an Android app that can help receive, decode anddisplay on a map ADS-B aircraft positions with the RTL-SDR. To run thisprogram you will need an Android 4.0+ device with a decent processor, aUSB OTG cable and an RTL-SDR dongle.
PiAware (Raspberry Pi) (Free) (Related Post) – ADS-B Data Sharer
PiAwareis software for the Raspberry Pi which allows data coming from dump1090to be shared with the FlightAware.com public servers.
FlightAware Flight Feeder (Android) (Free) (Related Post) – ADS-B Decoder, Radar and Data Sharer
An Android app that not only decodes ADS-B data, but also plots it on a map and shares the data with the FlightAware network. FlightAware ADS-B App
Track your flight EUROPE (Android) (Free) (Related Post) – ADS-B Decoder and Radar
Android based ADS-B decoder with offline maps for Europe.
FLARM Decoder (Raspberry Pi/ARM/x86 Linux) (Free) (Related Post)
A decoder for FLARM, a protocol similar to ADS-B but used for smaller aircraft like gliders and helicopters.
SDRWeather (Android) (Paid) – Weather Radio
SDRWeather
AnAndroid app for listening to weather radio in the US and Canada. Canalso decode EAS alerts. To run this program you will needan Android 4.0+ device with a decent processor, a USB OTG cable and anRTL-SDR dongle.
rtl_acars_ng (Linux) (Free) – ACARS
rtl_acars_ngis an improvement of the old rtl_acars command line based Linux ACARSdecoder.  It is capable of scanning multiple frequencies and has a builtin airline database. See this post for some more information.
Acarsdec (Linux) (Free) – ACARS
Acarsdecis a mulithreaded, multi channel (up to four simultaneous channels canbe monitored) ACARS decoder with error detection.
PNAIS (Windows) (Free) (Related Post) – AIS
[img]http://rtlsdrblog.rtlsdrblog.netdna-cdn.com/wp-content/uploads/2014/07/PNAIS.png[/img]PNAIS
Software that connects directly to the RTL-SDR and decodes AIS data. Outputs NMEA data via UDP.
我读书少  不要骗我
只看该作者 4楼 发表于: 2015-12-13
TVSharp (Windows) (Free) (Related Post) – PAL/NTSC TV
TV Sharp Running
TVSharpis a simple analogue PAL/NTSC TV decoder. Due to the RTL-SDRs limitedbandwidth in SDR mode it is only capable of decoding black and whiteimages.
Unitrunker (Windows) (Free) – Trunking Control
Unitrunkeris a trunking control channel decoder and controller. It can be used inconjuction with general purpose SDR receiver software like SDR#, or thelatest preview version can be used directly with the RTL-SDR.Unitrunker listens to a control channel, and then can correctly tuneSDR# (via a plugin), or itself in the preview version to the correctchannel in order to successfully follow a trunked voice conversation. Unitrunker
Trunk88 (Windows) (Free) – Trunking Control
A trunking control channel decoder and controller. Supports most Motorola systems. Can connect directly to the RTL-SDR. Trunk88
SDRTrunk (Windows/Linux/Java) (Free) – Trunking Control
SDRTrunkis a java based application for decoding and trunk tracking multipleanalog and digital radio channels across multiple USB dongle tunersand/or sound card inputs from discriminator-tapped scanner radios. SDR Trunk
NRF905 Decoder (Linux) (Free) (Related Post) – Digital Signal Decoder
A decoder for the NRF905 tranceiver.
NRF24-BTLE Decode (Linux) (Free) (Related Post) – Digital Signal Decoder
A decoder for the NRF24-BTLE tranceiver. This protocol is used by many common devices such as mice and keyboards.
RTL_433 (Linux) (Free) – Digital Signal Decoder
A program to decode temperature sensors on the 433 MHz ISM band.
GR-Elster (GNU Radio) (Free) (Related Post) – Digital Signal Decoder
A program to decode data sent by Elster R2S smart meters.
ec3k (GNU Radio) (Free) (Related Post) – Digital Signal Decoder
A command line program that allows the decoding of EnergyCount 3000 energy loggers.
rtlamr (Linux) (Free) – Digital Signal Decoder
A command line program for decoding smart meters on the 900 MHz ISM band.
RTL_HPSDR (Linux) (Free) (Related Post) – HPSDR
A translation server which allows the RTL-SDR to be used on HPSDR specific software.
GR-RDS (GNU Radio) (Free) (Related Post) – RDS
A gnuradio RDS decoder.
Airprobe (Linux) (Free) (Related Post) – GSM
A GSM decoder.
gr-gsm (Linux) (Free) (Related Post) – GSM
An upgraded version of Airprobe.
RTL_Tool_Kit (Linux) (Free) (Related Post) – GSM
An upgraded version of gr-gsm that can also connect and control a test mobile phone.
RTL-Entropy (Linux) (Free)
rtl_entropy is a command line Linux program which uses the RTL-SDR as an entropy (randomness) source.
GR-AIS (GNU Radio) (Free) – AIS
GNU Radio based AIS decoder which can decode both AIS channels simultaneously.
GR-Phosphor (GNU Radio) (Free) – Spectrum Display
A GPU accelerated spectrum viewer.
ViewRF (BeagleBone Black) (Free) (Related Post) – Spectrum Display
ViewRF is software that displays a FFT RF display on a BeagleBone Black mini computer.
rtl_power (Linux) (Free) (Related Post) – Spectrum Display
rtl_poweris a wideband spectrum monitor. This tool let’s you gather signal dataover a very wide area of the frequency spectrum, and then that data canbe used to find active areas of the spectrum.
kalibrate-rtl (Linux) (Free) (Related Post) – Calibration
Kalibrate-rtlis a command line Linux tool that is used to determine an RTL-SDRdongles frequency offset in PPM. It uses the time synchronizationinformation in GSM signals to do this.
pymultimonaprs (Linux) (Free) – APRS
An APRS-IS gateway which supports the RTL-SDR.
gr-wmbus (Linux) (Free) – M-Bus
Receiver for wireless m-bus (EN 13757-4) based on the RTL-SDR
rtlsdr-waterfall (Linux) (Free) – Waterfall Display
A simple waterfall display for the RTL-SDR.
LTE-Scanner (Linux) (Free) – LTE
A collection of tools to locate and track LTE basestation cells which supports the RTL-SDR.
LTE-Scanner (TD-LTE Support) (Linux) (Free) – LTE
A fork of LTE-Scanner which supports decoding of Time Division LTE (TD-LTE) signals.
rtl_sdr_FS20_decoder (Linux) (Free) – FS20
A tool for decoding the FS20 protocol which is used in home automation.
LibRedio (Linux) (Free) – Digital Signal Decoder
LibRediois a tool which can decode temperature and humidity readings that arebroadcast from many commercially available wireless environmentalsensors.
PureData and MAX RTL-SDR Wrapper (PD/MAX) (Free)
PureDataand Max/MSP are graphical programming tools for creating music, sound,video and interactive graphics applications. This software is a wrapperfor RTL-SDR that allows the dongle to be used in these tools.
OOK-Decoder (Linux/MacOS) (Free) (Related Post)
A On-Off Keying (OOK) decoder for radio data commonly found in the 433 MHz ISM band.
Rtl_power Heatmap Viewer (Windows/Mac/Linux) (Free) (Related Post)
Softwarethat allows you to visualize the output of a rtl_power scan using agenerated waterfall image in a web browser. Shows the current frequencyand time wherever the mouse is.
RTL Bridge (Windows) (Free) (Related Post)
RTL Bridge
RTLBridge allows a connection between the RTL-SDR dongle and theRadio-SkyPipe and Radio-Sky Spectrograph radio astronomy software.
Threejs-Spectrum (Chrome) (Free) (Related Post)
Chrome 3D Frequency Spectrum for RTL-SDR
Software for the Chrome browser that allows you to view an RTL-SDR waterfall in 3D.
CANFI Software (Windows) (Free) (Related Post)
Noise Figure Indicator Software
Software for using the RTL-SDR as a cheap noise figure indicator. Requires extra hardware.
Touchstone (Windows) (Free/Paid)
RFSpectrum analyser software. Pro version unlocks extra features such asrecording/playback mode, zoom, topographic maps and logging.
RTLSDR-Airband (Windows/Mac/Linux) (Free) (Related Post)
Softwarethat allows you to decode up to eight airband channels simultaneouslyand stream them to online services like liveatc.net.
OregonWeather (Mac) (Free)
A Mac only app that can receive data from Oregon Scientific weather temperature sensors.
FreqWatch (Windows/Mac/Linux) (Free)
Freqwatchmakes use of rtl_power to scan a wide swath of RF spectrum and thenautomatically records and stores in a database sound files of activesignals by using rtl_fm.
YouSDR (Linux) (Free) (Related Post) – Web based streaming and control
Runs a server which broadcasts audio from an RTL-SDR. Has a web interface which allows for remote control of the server. The YouSDR web interface.
Frequensea (Linux, OSX, Raspberry Pi) (Free) (Related Post) – Visualisation
Allows you to visualise the FFT in various 3D modes.
QSpectrumAnalyzer (OSX) (Free) (Related Post) – rtl_power GUI
An OSX based spectrum analyser rtl_power GUI. QSpectrumAnalyzer GUI for rtl_power.
Redsea (Linux) (Free) (Related Post) – RDS
A command line utility for decoding Radio Data System (RDS). Uses rtl_fm.
Driveby (Linux) (Free) (Related Post) – RF Noise Finder
Helps to pinpoint RF noise by driving around with several RTL-SDR dongles.
Sigmira (Windows/Linux) (Free) – Ham digital mode decoder
Sigmirais a free software program that is capable of decoding a wide range ofham radio signals. Sigmira is best known for it’s support for decodingthe “Japanese Navy Slot Machine” signal and STANAG4285 signals. Newerversions of Sigmira can interface directly with the RTL-SDR, or use inconjunction with a general purpose SDR receiver and pipe the audiooutput to Sigmira.
Research
Under this heading we list RTL-SDR software that is mainly intended for education and research purposes.
GNU Radio (Linux) (Free)
GNURadio is a powerful digital signal processing (DSP) package forcreating software defined radios. DSP programs can be written visuallyusing block diagrams in the GNU Radio Companion software. It supportsthe RTL-SDR with an RTL2832U source block. Various decoders are writtenin GNU Radio and require it to be installed to run.
Redhawk (CentOS) (Free)
Redhawkis another digital signal processing package that is very similar toGNU Radio. It is designed to aid in the development, deployment, andmanagement of real-time software radio applications
MATLAB RTL-SDR Support (MATLAB) (Paid) (Related Post)
MATLABis a well known mathematical computing language. With this supportpackage MATLAB can interface with the RTL-SDR, and digital signalprocessing algorithm can then be written in MATLAB.
SDR Lab (LabVIEW) (Paid) (Related Post)
LabVIEWis a software package usually used for control systems engineering.With SDR Lab, the RTL-SDR is able to interface with LabVIEW.
Programs Compatible Through Piping
Theseprograms do not directly access the RTL-SDR but are compatible with theRTL-SDR either through piping of the audio output via software likeVBCable, Virtual Audio Cable, Windows Stereo Mix, Linux pipes or aphysical Audio Cable or via receiving RTL-SDR received data through someother way such as through a network. Most of these are general hamradio programs that have found wider use with the RTL-SDR.
WxtoIMG (Windows) (Free/Paid) (Related Post) – NOAA Weather Satellites
WxToIMG
WxToImgto a program which can be used to decode NOAA weather satellite dataand then display and post process the weather images. Use in conjunctionwith a general purpose SDR receiver and pipe the audio output toWxToIMG.
PDW (Windows) (Free) (Related Post) – POCSSAG/Flex Pagers
PDWis a POCSAG/Flex pager decoding program. Use in conjunction with ageneral purpose SDR receiver and pipe the audio output to PDW.
DSD/DSD+ (Windows) (Free) (Related Post) – Digital Speech Codecs
DSD+ Output
DSDis an acronym for digital speech decoder. It is a program that iscapable of decoding digital speech codecs such as P25, DMR/MOTOTRBO,NXDN and D-Star. DSD+ is a new version of DSD which has the samefeatures as DSD, but has improved decoding performance. For DSD you willneed to copy cygwin.dll into the same direction as dsd to run theprogram. For DSD+ you won’t need cygwin, but instead you willneed lame_enc.dll. Use in conjunction with a general purpose SDRreceiver and pipe the audio output to DSD/DSD+.
There is now also the in development DSD 1.7 which supports new features like D-Star voice decoding.
DREAM (Windows) (Free) (Related Post) – DRM
DREAMis a Digital Radio Monodiale (DRM) decoder. You will need anupconverter to receive DRM signals with the RTL-SDR as they are on theHF band. To use DREAM you’ll need to also compile or download an AACdecoder dll file, see our tutorial for a pre-made .dll. Use inconjunction with a general purpose SDR receiver and pipe the audiooutput to DREAM.
SondeMonitor (Windows) (Free) (Related Post) – Weather Balloons
SondeMonitoris commercial software with a 21 day free trial that is used to decodevarious weather balloon (radiosonde) telemetry signals.  Use inconjunction with a general purpose SDR receiver and pipe the audiooutput to SondeMonitor.
dl-fldigi (Windows/Mac/Linux) (Free) – High Altitude Balloons
Amodification of fldigi that can receive telemetry from amateur highaltitude balloons (HABs). Use in conjunction with a general purpose SDRreceiver and pipe the audio output to dl-fldigi.
PlanePlotter (Windows) (Paid) (Related Post) – ADS-B Radar/ACARS
PlanePlotteris a commercial advanced graphical ADS-B radar display with a 21 dayfree trial. With the RTL-SDR, use in conjunction with an ADS-B decoder.PlanePlotter also has an excellent ACARS decoder. To use the ACARSdecoder, use with a general purpose SDR receiver and pipe the audiooutput to PlanePlotter.
GlobeS (Windows) (Free) (Related Post) – ADS-B Radar
GlobeS is a simple lightweight graphical ADS-B radar display. With the RTL-SDR, use in conjunction with an ADS-B decoder.
adsbSCOPE (Windows) (Free) (Related Post) – ADS-B Radar
adsbSCOPE is a graphical ADS-B radar display. With the RTL-SDR, use in conjunction with an ADS-B decoder.
Virtual Radar Server (Windows) (Free) (Related Post) – ADS-B
VirtualRadar Server is a free program which will display ADS-B data on aGoogle Maps window. With the RTL-SDR, use in conjunction with an ADS-Bdecoder.
Acarsd (Windows) (Free) (Related Post) – ACARS
ACARSD
Acarsdis a free ACARS decoder program. It contains a database of aircraft andwill display their images if they exist. Use in conjunction with ageneral purpose SDR receiver and pipe the audio output to Acarsd.
ShipPlotter (Windows) (Trial/Paid) (Related Post) – AIS
ShipPlotteris a commercial program which can plot ship positions on a nautical mapor Google maps from decoded AIS datastreams. It has a 21-day freetrial. Use in conjunction with a general purpose SDR receiver and pipethe audio output to ShipPlotter.
AISMon (Windows) (Free) (Related Post) – AIS
AISMonis a free AIS data decoder. It can output decoded AIS data through aUDP stream for use in other programs that display the ship positionaldata such an OpenCPN. Use in conjunction with a general purpose SDRreceiver and pipe the audio output to ShipPlotter.
OpenCPN (Windows) (Free) (Related Post) – AIS
OpenCPNis a free nautical AIS mapping tool which can display ship positions ona map using AIS data. Use this software in conjunction with a programthat decodes AIS data, such as AISMon.
RDS Spy (Windows) (Free) (Related Post) – RDS
RDS Spy
RDSSpy is a free and very sensitive Radio Data System (RDS) decoder. Usein conjunction with a general purpose SDR receiver and pipe the audiooutput to RDS Spy.
Orbitron (Windows) (Free) (Related Post) – Satellite Tracking
Orbitronis a free satellite tracker. With a plugin, Orbitron can be made tocontrol the tuned frequency in SDR# allowing for automatic satellitetracking, and doppler effect correction. Use in conjunction with the Orbitron SDR# plugin.
Qtmm AFSK1200 Decoder (Windows) (Free) (Related Post) – AFSK Decoder
AFSK1200is an AFSK1200 decoder. This mode is used by APRS radio hobbyists. Usein conjunction with a general purpose SDR receiver and pipe the audiooutput to AFSK1200.
FunCube Telemetry Dashboard (Windows) (Free) (Related Post) – FunCube
Thisis a program designed to decode the Funcube satellite telemetrydata. Use in conjunction with a general purpose SDR receiver and pipethe audio output to the dashboard.
GNSS (Linux) (Free) (Related Post) – GPS
A software GPS receiver code base which supports the RTL-SDR.
DStar (Windows) (Free) (Related Post) – Dstar
Dstar is an DStar decoder program. Use in conjunction with a general purpose SDR receiver and pipe the audio output to dstar.
Spectrum Lab (Windows) (Free) (Related Post) – Audio Analysis
SpectrumLab is a free specialized audio analyzer, filter, frequency converter,hum filter, data logger. It is usually used in the field of radioastronomy for things like meteor detection. Use in conjunction with ageneral purpose SDR receiver and pipe the audio output to Spectrum Lab.
Baudline (Mac/Linux) (Free) (Related Post) – Audio Analysis
Baudlineis a free audio spectrum analyzer usually used to analyze radio datasignals. Use in conjunction with a general purpose SDR receiver and pipethe audio output to Baudline.
HROFFT (Windows) (Free) (Related Post) – Audio Analysis
HROFFTis a specialized audio analysis software program designed formonitoring meteor scatter signals. Use in conjunction with a generalpurpose SDR receiver and pipe the audio output to HROFFT.
multiPSK (Windows) (Free for non-commercial use) – Ham digital mode decoder
multiPSKis a popular ham digital mode decoder and supports a very wide range ofdigital modes. It also directly supports connecting to the RTL-SDR viaRTL_TCP.exe. You will need to download the rtlsdr official Windows release,and copy the rtl_tcp.exe, rtlsdr.dll, pthreadVC2-w64.dll andlibusb-1.0.dll into the same directory as multipsk.exe to use thisoption. Otherwise you can simply pipe the audio from a general purposeSDR receiver into multiPSK.
Fldigi (Windows/Mac/Linux) (Free) – Ham digital mode decoder
Fldigiis a free software program capable of decoding various ham radiodigital data signals such as CW, Contestia, Domino, Feld Hell, Olivia,MT63, PSK, RTTY, Thor and WEFAX. Use in conjunction with a generalpurpose SDR receiver and pipe the audio output to Fldigi.
multimonNG (Windows/Mac/Linux) (Free) – Ham digital mode decoder
multimonNGis a fork of the multimon software. It is a general purpose decodercapable of decoding POCSAG512, POCSAG1200, POCSAG2400, EAS, UFSK1200,CLIPFSK, AFSK1200, AFSK2400, AFSK2400_2, AFSK2400_3, HAPN4800, FSK9600,DTMF and ZVEI. Use in conjunction with a general purpose SDR receiverand pipe the audio output to MixW.
MixW (Windows) (Free) – Ham digital mode decoder
MixWis a free software program used for decoding various digital ham radiosignals. It is capable of decoding CW, BPSK31, QPSK31, FSK31, RTTY,Packet, Pactor, Amtor, MFSK, Throb, MT63, Hellschreiber, WEFAX andSSTV. Use in conjunction with a general purpose SDR receiver and pipethe audio output to MixW.
Sorcerer (Windows) (Free) (Related Post) – Ham digital mode decoder
Sorcereris a free software program capable of decoding a wide range of hamradio signals. Sorcerer is known for its decoder support for rarely usedsignals, but it is mostly used to decode STANAG 4285 signals. Use inconjunction with a general purpose SDR receiver and pipe the audiooutput to Sorcerer.
Rivet (Windows/Mac/Linux) (Free) – Ham digital mode decoder
Rivetis a free open source decoder for various spy agency and numbersstation related HF signals such as Baudot, CCIR493-4, CIS36-50, CROWD36,FSK200/500, FSK200/1000, FSK, GW FSK, XPA and XPA2.
DMRDecode (Windows/Mac/Linux) (Free) – DMR Decoder
DMRDecode is a free open source DMR decoder which currently only displays DMR frames in text.
CWSkimmer (Windows) (Paid) (Related Post) – CW Decoder
CWSkimmeris a Morse code (CW) decoder. It is generally regarded as one of thebest CW decoders available. Use in conjunction with a general purposeSDR receiver and pipe the audio output to CWSkimmer.
MMSSTV (Windows) (Free) – SSTV
MMSSTV is a dedicated SSTV decoder program.
Taxidecoder (Windows) (Free) (Related Post) – MDT Decoder
Taxidecoderis a free mobile data terminal (MDT) decoder. It will only work incountries that use MDT data signals that taxi decoder supports. Use inconjunction with a general purpose SDR receiver and pipe the audiooutput to taxidecoder.
ScanEyes (Free) – Archiver
A PHP based web server program which can be used to record, log and analyze trunked radio traffic.
LTR Analyzer (Free) (Related Post) – LTR
Used to analyze trunked LTR signals.
softEOT/softDPU (Free) (Related Post) – Trains
Can be used to decode end of train, head of train and distributed power unit telemetry which is used on some trains.
Xastir (Free) (Related Post) – APRS
Linux software that allows you to visualize APRS signals on a map.
RTL1090 XHSI Interface (Free) (Related Post) – ADS-B
Allows RTL1090 to interface with XHSI, a program that can emulate airplane flight instruments.
Parus Decoder (Free) (Related Post) – Satellites
Decodes data from the Russian Parus military communications and navigation satellites.
PlotRTL1090 (Free) (Related Post) – ADS-B
Creates a 3D image of ADS-B data from dump1090 using MATLAB.
LRPT Decoder (Free) (Related Post) – LRPT Satellites
Decodes LRPT weather satellite images.
SDRrecord (Free) – Recorder
Used for recording audio from an SDR with squelch feature that stops recording when there is no sound.
Doppler & Demod (Free) (Related Post) – Satellites
TwoLinux based programs which work with the piped output of rtl_sdrto correct for satellite doppler shift and to also demodulate FM.
rtl_heatmap (Free) (Related Post) – FFT Plotting
Create a heatmap image from an rtl_power scan.
If you enjoyed this tutorial you may like our ebook available on Amazon.
  • 478
  • 53
Related posts:
  1. A list of 5 Free Virtual Audio Cable Software Programs
  2. New RTL-SDR software: rtl_ais
  3. SeeDeR: New SDR GUI Software Supporting RTL-SDR
  4. RTL_Power Frequency Display Software
  5. Skywave Linux: New Linux Ubuntu Distribution made for Software Defined Radio
我读书少  不要骗我
离线bh1tju
只看该作者 5楼 发表于: 2015-12-14
果断关注
离线m6sig
只看该作者 6楼 发表于: 2015-12-14
大多数都是常见的
CS: M6SIG   LOC: JO01
新浪微博:@熊猫阿B0
不再更新的旧数据: http://t.cn/RhrIAYe
离线m6sig
只看该作者 7楼 发表于: 2015-12-14
等会!Orbitron也算SDR软件啊?
CS: M6SIG   LOC: JO01
新浪微博:@熊猫阿B0
只看该作者 8楼 发表于: 2015-12-15
回 m6sig 的帖子
m6sig:等会!Orbitron也算SDR软件啊? (2015-12-14 17:59)
不是SDR软件,是有个插件支持协调控制SDR#进行频率多普勒修正
我读书少  不要骗我
离线m6sig
只看该作者 9楼 发表于: 2015-12-15
回 爱不交租 的帖子
爱不交租:不是SDR软件,是有个插件支持协调控制SDR#进行频率多普勒修正 (2015-12-15 09:00)
帖子标题明明写的SDR软件嘛
CS: M6SIG   LOC: JO01
新浪微博:@熊猫阿B0
只看该作者 10楼 发表于: 2015-12-15
回 m6sig 的帖子
m6sig:帖子标题明明写的SDR软件嘛[表情] (2015-12-15 09:14)
标题是RTL-SDR支持的软件也就是只要电视棒能支持的都包罗万有....
我读书少  不要骗我
离线m6sig
只看该作者 11楼 发表于: 2015-12-15
回 爱不交租 的帖子
爱不交租:The BIG List of RTL-SDR Supported Software
标题是RTL-SDR支持的软件[表情]也就是只要电视棒能支持的都包罗万有....[表情] (2015-12-15 16:17)
"一大堆的SDR软件,此帖有剧毒!严正声明:解药不要找我...."
这才是标题
CS: M6SIG   LOC: JO01
新浪微博:@熊猫阿B0
只看该作者 12楼 发表于: 2015-12-16
回 m6sig 的帖子
m6sig:"一大堆的SDR软件,此帖有剧毒!严正声明:解药不要找我...."
这才是标题[表情] (2015-12-15 20:22)
那是我懒得开新帖放那么多毒气....
我读书少  不要骗我
离线m6sig
只看该作者 13楼 发表于: 2015-12-16
回 爱不交租 的帖子
爱不交租:那是我懒得开新帖放那么多毒气.... (2015-12-16 17:31)
这个版块里明明很多你发的类似的帖子
CS: M6SIG   LOC: JO01
新浪微博:@熊猫阿B0
离线BD1CM
只看该作者 14楼 发表于: 2016-01-10
毒死了
QQ:63545177
离线osagem
只看该作者 15楼 发表于: 2016-01-23
剧毒无比
呼号…………BH7JAG DMRID4607039
QRZ.com
离线BH1LHS
只看该作者 16楼 发表于: 2016-01-24
BH1LHS
北京市通州区
FT857D + 3波段倒V+PAC-12
img: http://service.t.sina.com.cn/widget/qmd/1408405743/9f204b90/1.png
离线郑智
只看该作者 17楼 发表于: 2017-02-05
你好毒,你好毒
离线ba5aa
只看该作者 18楼 发表于: 2017-02-25
请问卫星电视接收吗?
离线BG7OAF
只看该作者 19楼 发表于: 2017-06-20
哇,真是很多很多很多。。。。。。
:152: My radio call sign is BG7OAF(HF持照上岗)。
:159: TEL:棕橙橙棕蓝黑蓝橙棕灰红。
:103: QQ:陸伍貳貳陸伍壹貳。
:173: My information in the search QRZ.CN be.
