  • 5308阅读
  • 19回复
围观希望二号 [复制链接]
离线BH1IEO
只看楼主 倒序阅读 0楼 发表于: 2015-09-17
CAMSAT XW-2 Satellites Launch Information
Alan Kung BA1DU has posted launch information for the XW-2 (CAS-3) satellites on the AMSAT Bulletin Board.
Launch time: UTC 23:00:00 on 2015-09-18
The satellites will separate from rocket at UTC 23:15:14 on 2015-09-18
The satellites will be launched on Beijing’s new Chang Zheng 6 (CZ-6) rocket from the Taiyuan Satellite Launch Center.
It is understood the CZ-6 is carrying at least nine satellites with payloads operating in amateur bands. They include six satellites (designated XW-2A to XW-2F) with 435/145 MHz linear transponders for SSB/CW communications, and one satellite with an FM voice transponder. The frequencies to be used by the satellites are here.
XW-2A should operate in a sun-synchronous orbit at an altitude of about 450 km, with the other satellites at an altitude of about 530 km.
Predicted Two-Line Element (TLE) for tracking:XW-21 99999U          15261.96885740  .00004980  00000-0  28369-3 0 000002 99999 097.4712 269.8396 0010382 266.0521 270.6645 15.12847582000010
Further information on the XW-2 satellites is at
http://amsat-uk.org/satellites/communications/camsat-xw-2/
Satellite tracking information http://amsat-uk.org/beginners/satellite-tracking/
Adding new satellites to SatPC32 and Gpredict
http://amsat-uk.org/2013/11/23/adding-new-satellites-to-satpc32/
SatPC32 doppler.sqf http://www.pe0sat.vgnet.nl/2015/xw-2cas-3-launch-information/
[ 此帖被BH1IEO在2015-09-17 12:54重新编辑 ]
燕  巴  虎  开 始 玩 户 外 了
E-mail:1162846706@qq.com
QTH :未来火星人
Echolink Links Node:15668
WiRES-X Node ID:14231
WiRES-X Room:24231
ALLSTAR Links Node:28559
Echolink brought us into the 21st century
APRS:BH1IEO Home IGATE/Yaesu 1DR-5/Kenwood D72E-6/LM3G Mobile-7/GPRS APRS Mobile car-8/Yaesu 400DR Jeep Mobile-9/Mobile phone-12
离线BD6AHP
只看该作者 1楼 发表于: 2015-09-17
哇,TLE都出来了。
预祝成功!
de BD6AHP
安徽滁州
只看该作者 2楼 发表于: 2015-09-17
呵呵,星箭分离第一次信标收不到,过了覆盖长沙的区域,差两分钟
离线BG6BFN
只看该作者 3楼 发表于: 2015-09-17
可是中国卫星?一楼一个中国字没有,与世界接轨到家
离线BH3NEK
只看该作者 4楼 发表于: 2015-09-17
,BH1IEO随时透露最新消息,关注中
呼号:BH3NEK
直频:145.100MHz
中继: 439.125MHz-8 亚音103.5
          147.925MHz-3.8 无亚音
          APRS:144.640MHz
承德ham微信号:CDHAM01
QTH:河北承德开发区
离线BG6BBD
只看该作者 5楼 发表于: 2015-09-17
用一楼提供的Tle参数注入Orbitron软件后,发现不能正常运行,改成如下格式后即可运行:
XW-2 (CAS-3)
方法是:用记事本打开Orbitron\Tle\amateur   将上述参数复制到文件中保存,再打开Orbitron即可在amateur 中找到XW-2 (CAS-3)
这个应该是理论参数,不知道与实际运行的参数是否一致。
[ 此帖被BG6BBD在2015-09-17 21:35重新编辑 ]
呼号:BD6BBD
姓名:胡斌
地址:安徽省淮南市田家庵区政协(国庆中路128号)
兼职:BY6AB台长\BY6CD BY6EF辅导员
电话:0554-2698122  13966476805
我不是教师,我是政协委员,是几个学校的校外科技辅导员,业余时间免费带大中小学生玩无线电。
离线BH1IEO
只看该作者 6楼 发表于: 2015-09-17
等官网发布消息了。
离线BH1IEO
只看该作者 7楼 发表于: 2015-09-17
回  3楼(BG6BFN)的帖子
第3楼BG6BFN于2015-09-17 15:30发表的:
可是中国卫星?一楼一个中国字没有,与世界接轨到家[表情]
外网来的消息,复制过来滴。
离线bd7cv
只看该作者 8楼 发表于: 2015-09-17
一箭二十星,到里是卫星还是弹头
bd7cv
421300
湖南省衡山县人民中路289号2栋101(老农委家属楼)
离线bm2caj
只看该作者 9楼 发表于: 2015-09-18
以 Orbitron 預測如圖,向南飛行,新加坡可能可以看到軌跡 :)
73
离线vr2ung
只看该作者 10楼 发表于: 2015-09-19
祝成功,73vr2ung
VR2UNG M0UNG XX9TUN
居安思危, 熱心ARES, 做個開心真火腿^_^^_^^_^
只看该作者 11楼 发表于: 2015-09-19
散学,继续发呆
离线BG3GAC
只看该作者 12楼 发表于: 2015-09-19
回 BH1IEO 的帖子
BH1IEO:外网来的消息,复制过来滴。 (2015-09-17 21:46)
我去!这也要翻墙才能看到?
呼号:BG3GAC (B类操作证)
电邮:bg3gac@163.com
离线BG3GAC
只看该作者 13楼 发表于: 2015-09-19
如果是中国卫星,请用中文来说明。
呼号:BG3GAC (B类操作证)
电邮:bg3gac@163.com
离线BH4IWK
只看该作者 14楼 发表于: 2015-09-19
这些消息竟然都是外来的。
原会员证号:123022
操作证:B000015394
开始活跃在SO-50,AO-91,AO-92等业余卫星上
离线bm2caj
只看该作者 15楼 发表于: 2015-09-20
BA1DU Alan Kung 贴文在 AMSAT 说的
[ 此帖被bm2caj在2015-09-20 01:27重新编辑 ]
只看该作者 16楼 发表于: 2015-09-20
已经成功入轨,VU段DX 大餐来了。
离线BG2TOS
只看该作者 17楼 发表于: 2015-09-20
围观...........
高墙内外----围观.....
岁月如刀     我似切糕
BG2TOS@126.com
离线BH4IWK
只看该作者 18楼 发表于: 2015-09-20
没有uv段全模式电台
离线BG2TOS
只看该作者 19楼 发表于: 2015-09-20
希望2信标 bd3mm接收.rar (91 K) 下载次数:22
岁月如刀     我似切糕
BG2TOS@126.com
