  • 4521阅读
  • 5回复
FT-897D 隐藏菜单参数(供参考) [复制链接]
离线BA2Bi
只看楼主 正序阅读 0楼 发表于: 2013-03-08
Function Setting in BA2Bi
Adjust-No      Function            Setting  Mode    Frequency
NO-001         HF1-RXG             72        CW     1.845.00
NO-002         HF2-RXG             71        CW     7.150.00
NO-003         HF3-RXG             83        CW    21.400.00
NO-004         50M-RXG             68        CW    50.110.00
NO-005         VHF-RXG             76        CW   145.145.00
NO-006         UHF-RXG             69        CW   438.500.00
NO-007         SSB-S9              89        CW    21.400.00
NO-008         SSB-FS              57        CW    21.400.00
NO-009         FM-S1               81        FM   145.145.00
NO-010         FM-FS              112        FM   145.145.00
NO-011         DISC-L              50        FM   145.145.00
NO-012         DISC-H              82        FM   145.145.00
NO-013         FM-TH1              88        FM   145.145.00
NO-014         FM-TH2              93        FM   145.145.00
NO-015         FM-TI1               4        FM   145.145.00
NO-016         FM-TI2               4        FM   145.145.00
NO-017         VCC                138        FM   145.145.00
NO-018         HF1-IC              95        CW     1.845.00
NO-019         HF2-IC              92        CW     7.150.00
NO-020         HF3-IC             121        CW    21.400.00
NO-021         50M-IC             114        CW    50.110.00
NO-022         VHF-IC              76        CW   145.145.00
NO-023         UHF-IC              71        CW   438.500.00
NO-024         HF1-PO-MAX         168        CW     1.845.00
NO-025         HF1-PO-MID2        109        CW     1.845.00
NO-026         HF1-PO-MID1         31        CW     1.845.00
NO-027         HF1-PO-MIN          12        CW     1.845.00
NO-028         HF2-PO-MAX         169        CW     7.150.00
NO-029         HF2-PO-MID2        108        CW     7.150.00
NO-030         HF2-PO-MID1         30        CW     7.150.00
NO-031         HF2-PO-MIN          11        CW     7.150.00
NO-032         HF3-PO-MAX         167        CW    21.400.00
NO-033         HF3-PO-MID2        108        CW    21.400.00
NO-034         HF3-PO-MID1         30        CW    21.400.00
NO-035         HF3-PO-MIN          11        CW    21.400.00
NO-036         50M-PO-MAX         156        CW    50.110.00
NO-037         50M-PO-MID2         97        CW    50.110.00
NO-038         50M-PO-MID1         48        CW    50.110.00
NO-039         50M-PO-MIN           9        CW    50.110.00
NO-040         VHF-PO-MAX          91        CW   145.145.00
NO-041         VHF-PO-MID          45        CW   145.145.00
NO-042         VHF-PO-MIN           7        CW   145.145.00
NO-043         UHF-PO-MAX         128        CW   438.500.00
NO-044         UHF-PO-MIN          13        CW   438.500.00
NO-045         HF1-TXG            255        USB    1.845.00
NO-046         HF2-TXG             53        USB    7.150.00
NO-047         HF3-TXG             51        USB   21.400.00
NO-048         50M-TXG             48        USB   50.110.00
NO-049         VHF-TXG             39        USB  145.145.00
NO-050         UHF-TXG             37        USB  438.500.00
NO-051         ALC1-M             183        USB   21.400.00
NO-052         ALC-M              110        USB   21.400.00
NO-053         HF1-REV-ALC         48        CW     1.845.00
NO-054         HF2-REV-ALC         42        CW     7.150.00
NO-055         HF3-REV-ALC         40        CW    21.400.00
NO-056         50M-REV-ALC         36        CW    50.110.00
NO-057         VHF-REV-ALC         45        CW   145.145.00
NO-058         UHF-REV-ALC         75        CW   438.500.00
NO-059         CW-CAR-LEVEL       138        CW    21.400.00
NO-060         AM-CAR-LEVEL       125        AM    21.400.00
NO-061         DEV-W              190        FM   145.145.00
NO-062         DEV-N               90        FM   145.145.00
NO-063         MOD-MTR            187        FM   145.145.00
NO-064         DTMF-DEV            74        FM   145.145.00
NO-065         CTCSS-DEV          245        FM   145.145.00
NO-066         DCS-DEV            171        FM   145.145.00
NO-067         LSB-CAR-POINT       -7        LSB   21.400.00
NO-068         USB-CAR-POINT       +7        USB   21.400.00
NO-069         VSWR2 at 10W         9        CW    14.180.00
NO-070         VSWR3 at 10W        34        CW    14.180.00
NO-071         ATAS-TEST                     LSB   14.180.00
NO-072         AMTR-TEST                     LSB   14.180.00
NO-073         HTEMP-THRESHOLD     38        LSB   14.180.00
NO-074         FTEMP-THRESHOLD    102        LSB   14.180.00
只看该作者 5楼 发表于: 03-13
记号。
BG2ALB   电波
离线bd3nn
只看该作者 4楼 发表于: 2013-04-03
不知道有什么用!!91相菜单和那快捷键就够用的了,我看了三天才明白!!
离线BG4IGX
只看该作者 3楼 发表于: 2013-03-09
这个参数没意思,自己记下吧,除了本机,没用处。
IC-705 FT-818ND 50W功放
IC-705 FT-818ND KX3 100W功放
只看该作者 2楼 发表于: 2013-03-09
嗯,差别大呢,感觉和817的类似
离线BI7JMD
只看该作者 1楼 发表于: 2013-03-08
每台机都有差异吧?
