UID:103055
UID:36369
千里共明月!
图片:1906 Bug-1.jpg
图片:1906 Bug-2.jpg
UID:61888
再次长知识。
图片:1907 Bug.jpg
阮兄、勾兄好,节日快乐!
UID:94793
图片:Shorting sw-1.jpg
若該电键接上当今业余无线电器材上,开关器在闭合状态下能让操作员腾出双手来操控手动天调或功放匹配旋钮。但在1880年代流行于美国丶德国及澳洲的「闭路电报网络」上,报站电键定必设有开关装置(sw1和sw2)将键体与近端接点「连起」(r)或「切断」(s) 。收报一方(k2)需将该开关置于"r"档位而发报一方(k1)则要设于"s"位置。
....在1880年代流行于美国丶德国及澳洲的「闭路电报网络」上,报站电键定必设有开关装置(sw1和sw2)将键体与近端接点「连起」(r)或「切断」(s) 。收报一方(k2)需将该开关置于"r"档位而发报一方(k1)则要设于"s"位置。
图片:1886 CLOSER.jpg
图片:1894 CLOSER.jpg
图片:1905 CLOSER.jpg
UID:101348
又学习了 其实也就是有线发报通信中的运用 另外李老师能否讲解一下最早臭虫的发明 是解决了四路闭合电路中的“啾啾声”?
when the armature of a neutral relay in an early quadruplex telegraph system around 1870s is attracted by the full current strength and a reversal of the current takes place, that armature momentarily falls away from the front stop with the likelihood of producing a “kick” or false signal in the local sounder. such kicks were called “bug”.semiautomatic transmitting keys came into being around 1904 but such keys were nicknamed as “bug” commencing from 1908 when quite a lot of telegraphers manoeuvred the said keys improperly over the landline circuits making the sounder clicks erratically. semiautomatic key does not resolve the "bug" (false signals) arising from the early quadruplex telegraphy. they are not interrelated.
when the armature of a neutral relay in an early quadruplex telegraph system around 1870s is attracted by the full current strength and a reversal of the current takes place, that armature momentarily falls away from the front stop with the likelihood of producing a “kick” or false signal in the local sounder. such kicks were called “bug”.....
图片:False Sig Solved.jpg
图片:em BUG 1902.jpg
图片:em BUG 1915.jpg
i have read the origin of the word "bug"but there are some parts which i can't understand fully
来自1870年代四路多工电报体系内非极性继电器受逆流引致的虫鸣声与1908年快键新手所造成的点划不分鸣叫声是两码子事,不能混为一谈。以两种弊端而言前者利用电桥整流器即能改善而后者报手只要多加练习便可消弭。
UID:2124
这种电磁式快键也是类似电铃的原理吧?图上部件24是否就是控制电路振荡的常闭触点?我曾经用继电器做过类似的试验,但吸合过程有个延迟的问题无法解决。
电磁式快键的主要缺点是体积大、质量重、须外接电源、衔铁嘈吵、调节程序繁复、键控迟缓等等。报务历史昭示了商业高速报手们只选用结构简单、易调的纯机械式快键作为他们紧密合作的专业仪器。
