UID:30
UID:10238
UID:3820
UID:46342
UID:1243
UID:30908
UID:4104
UID:36068
UID:47730
UID:2104
UID:5471
UID:46640
UID:18939
UID:120
UID:22721
建议全模式.金属外壳,做成小台式qrp机器.
UID:35213
双手赞成
UID:740
UID:43846
UID:9962
frequency range: rx: 26.000 - 31.975 mhz (f3e)tx: 10m amateur bands (f3e)channel steps: 5/6.25/10/12.5/25/50/100 khzemission type: f3eantenna impedance: 50 ohmsfrequency stability: ±3ppm -20℃ ~+60℃operating temperature range: -20℃ ~ +60℃audio frequency response: 300 to 3,000hzoccupied bandwidth: ≤ 16khz supply voltage: nominal: 8.4 v dc, negative groundoperating: 6 ~ 9 v, negative groundcurrent consumption: rx: 0.2 a (receive)tx: 0.3a/0.5a/1.0a/1.5a @ 0.5w/1w/3w/5wcase size (w x h x d): 68 x 150 x 38 mm (w/o knobs & connectors)weight (approx.): 0.35 kg)transmitterrf power output: 0.5w/1w/3w/5wmodulation type: variable reactancespurious radiation: at least 60 db belowmaximum distortion: ≤5%maximum frequency deviation: ≤±4.5khzmicrophone impedance: 2 k ohmsreceivercircuit type: fm double-conversion super heterodyneintermediate frequencies: fm 1st: 45 mhz, 2nd: 450 khzsensitivity: 0.15uv typ for 12 db sinadsquelch sensitivity: better than 0.12 uv (amateur band)selectivity : ≥65db spurious response rejection: ≥60dbaf output: 0.5 w @ 4 ohm for 10 % thd (@ 8.4 v) af output impedance: 4-16 ohms
