  • 29789阅读
  • 110回复
关于WAE 的QTC意思及使用WINTEST的实战交换QTC操作例子 [复制链接]
离线BA7QT
只看该作者 100楼 发表于: 2019-08-10
QTC Keys (for WAE contests)
Ctrl+Z – in CW/SSB, enters or leaves QTC mode; in RTTY, cycles through Send, Receive and QTC Off
If Ctrl+Z is pressed before the QSO with the station has been logged, logs the QSO
Enter – logs the next QTC (receiving), or sends the next QTC in the batch (sending)
F3 (End of QSO Key) – sends the TU message and exits QTC mode
Alt+W – wipes the current row
Esc – terminates sending (CW or RTTY), or if the program is not currently sending, exists the QTC window (same as the Cancel button)
Alt+Enter, Keypad + (plus) key (sending QTCs only) – re-sends the last sent string
Alt+Enter, Alt+Tab, Alt+Space (receiving QTCs only) – force-logs the current QTC; overrides error-checking
Ctrl+A (receiving QTCs only) – removes the last blank line of received QTCs and reduces the count in the QTC header
Used, for example, when the number in the header was copied incorrectly and fewer QTCs are received than expected
Alt+A (receiving QTCs only) – adds a new QTC line (if fewer than 10) and increases the count in the QTC header
As above, when more QTCs are received than expected
1, 2, 3 (sending QTCs only) – if pressed while the Agn button is highlighted, resends the time(1), call(2) or serial number(3) from the previous QTC
Shift+1, Shift+2, Shift+3 (receiving QTCs only) – asks for a repeat of the time(1), call(2) or serial number(3)
BEST 73!   DE BA7QT/LIAO
QSL MGR:W3HNK
qq:48892357  广西短波群:47730720
离线BA4WI
只看该作者 101楼 发表于: 2019-08-11
QTC是WAE里最好玩的地方
EX:BD4RDR BG4RDR
QQ:175218318
MSN:BA4WI@MSN.CN
Mail:BA4WI.Jack@Gmail.com
QTH:OM92JC
SKCC,WWYC
离线BA7QT
只看该作者 102楼 发表于: 2019-08-11
当我用40WPM发QTC给毛子抄收的时候,有一种孽待的快感~
QSL MGR:W3HNK
在线bh6kok
只看该作者 103楼 发表于: 2019-08-19
感觉楼主分享,学习了。。。
离线BA7JS
只看该作者 104楼 发表于: 2020-07-23
回 BA7QT 的帖子
BA7QT:当我用40WPM发QTC给毛子抄收的时候,有一种孽待的快感~[表情]
 (2019-08-11 13:03)
顶你个肺
BA7JS
QQ:522977276
俺的围脖
俺的公众号
离线ba2ba
只看该作者 105楼 发表于: 2020-08-06
哪位大神们发个用N1MM的使用教程。
姓名:陈铁石/BA2BA
邮编:153021
电话:18804585572
QQ:464826156
离线hamly
只看该作者 106楼 发表于: 2020-08-07
明天又是WAE CW了
DE BH6KWC OM64
离线bg3apx
只看该作者 107楼 发表于: 2020-08-08
传播不好,听不到EU。
呼号:bg3apx
姓名:张
Email:46012832@qq.com
icom725
DP--40
离线BG8DIV
只看该作者 108楼 发表于: 2020-08-08
过来学习下 感谢楼主分享
动手动脑 脑动手动
BG8DIV  I3699OI9I58
离线BH7PFH
只看该作者 109楼 发表于: 2020-08-10
2020年的传播真差,一点也不好玩。
BH7PFH
在线bh3dax
只看该作者 110楼 发表于: 2022-08-09
学习中
BH3DAX    UV:欧讯UV9D(Plus)   UVD1P
                HF:协谷 G90S   YAESU  FT-710
Email:411689629@qq.com
