echolink官方网站上2007年2月27日发布
经过几天的努力,终于基本汉化完毕
2.0版新特性:
current version: 2.0.902
2.0.902 (february 25, 2007)
updated installer.
drop-down box to select public proxy; new proxy and performance tabs.
下拉框选择公共代理服务器
proxy can be changed without requiring re-start.
换代理服务器时不用退出重新启动程序
sound card fine-tuning control with self-calibrate option.
built-in firewall test utility (similar to troubleshooter).
内置防火墙测试工具
added dtmfdigit event to api.
opening wave device at startup so it shows up on vista volume panel.
moved text and wav files to my documents area instead of install directory.
added more com ports to drop-down lists (com9-com16).
bug fix for: showing incorrect list of input devices on audio page
bug fix for: vista behavior on links to level adjustments
bug fix for: speed-dial ambiguity between base and sysop calls
bug fix for: startrecordingqso parameter in api
bug fix for: api events that have boolean parameters using wrong value for true
bug fix for: space bar sometimes non-responsive as tx control
bug fix for: allowing connect command via api when link disabled
bug fix for: incorrect listings for serbia and macau
bug fix for: incorrect shortcut key for switching views in keyboard shortcuts help page
bug fix for: minimize/restore not working as expected
bug fix for: incorrect initialization of interface type in link setup wizard
bug fix for: when using the web remote control feature in sysop mode, the connect to function does not work with callsigns that begin with a digit
最新下载地址:
http://www.by1tt.cn/forum/read.php?tid=345汉化说明:
1、本次汉化一些词语的翻译在上一个版本翻译的基础上有所调整,更准确更符合ham的语言习惯,仍有诸多不足和错误之处,请及时指出和谅解!
2、本版汉化基本上完成了90%的翻译工作,时间关系(要赶在三八节给广大ham男同胞献礼,呵呵~),仍有部分没来得及翻译。
3、汉化后重新打包,无需原版,直接安装,更加方便使用。
