  • 4101阅读
  • 5回复
关于IC-7800的新消息(英文) [复制链接]
离线BD3RJ
只看楼主 正序阅读 0楼 发表于: 2004-04-08
the spent means has not regretted. radio class, obviously a step forward in transiverostroenii, the following generation. dsp filters (probably due to fast processors) work not worse quartz, did not trust, that earlier so can be. panoramnik reacts to the most short-term signals, too due to separate and fast dsp. dynamics very good (it is subjective, did not measure). worked 3b9c on 1822.4 at split from 1823.1 calling did not prevent at all. on 14.150 rz3cc has stopped qso with ua9hn from for handicapes from r9j, i quite with it consulted. has worked in wpx including on 40, 80 - one pleasure. sounding of stations - deep and transparent, even in comparison with 1000d, does not tire absolutely. the keyboard suffices for work rtty/psk to usb to port of the transceiver podkljucht. i shall try, as time will appear. it is possible to connect to a computer either on ci-v to the interface or through rs232 (db9) a socket. in this case ci-v it is possible to use for management band decoder (automatic switching of aerials, for example). radio works perfectly both with writelog and with dx4win, to choose it is necessary from the menu of programs 756pro or pro2, and in the menu 7800 to change the address on 5a, on mine such corresponds to these models. in the transceiver of 4 jacks for aerials, are programmed in the any order, ant4 it is possible to program as soon as reception. it is possible to connect external preamp, filters, etc. the dynamic microphone quite suffices for 7800, that too distinguishes it from previous models icom. is lan port, opportunities of use kotorgo icom promises to declare later. built - in cf the card allows to keep adjustments of the menu, memory, sound files (rx and tx). in the complete set give 64 mb. as a whole the device is made very soundly and accurately. the display is equally well seen also in the afternoon.
离线bg3aaj
只看该作者 5楼 发表于: 2004-04-08
BG3RJ你好;
你好,我喜欢icom和yaesu。这两公司 的机器,在工做台上摆放很痛快。
离线BD3RJ
只看该作者 4楼 发表于: 2004-04-08
这个机器是200w,国内好象没有,但听说有人从hk买到了,价格不到7万,估计配全附件得将近8万了。老兄对756pii厌烦了?
离线BD3RJ
只看该作者 3楼 发表于: 2004-04-08
bg3rj你好ic-7800这款机器有几个频段功率多大在国内有吗价格
                      多谢,
tx: 10-160 m + warc / 6 m
rx: 0.03-60 mhz
mode:      am/fm/ssb/cw/rtty/psk31
rf power output:      5-200 w (am: 5-50 w) 100% duty cycle!
sensitivity:      ssb/cw/rtty (2.4 khz bw, 10 db s/n)
0.1-1.79 mhz: 0.5 uv
1.6-30 mhz: 0.16 uv
50-54 mhz: 0.13 uv
am (6 khz bw, 10 db s/n)
0.1-30 mhz: 2 uv
50-54 mhz: 1 uv
fm (15 khz bw, 12 db sinad)
28-30 mhz: 0.5 uv
50-54 mhz: 0.32 uv
ssb/rtty (2.4 khz bw)
2.4 khz (-3 db), 3.6 khz (-60 db)
cw (500 hz bw)
500 hz (-3 db), 700 hz (-60 db)
am (6 khz bw)
6 khz (-3 db), 15 khz (-60 db)
fm (15 khz bw)
12 khz (-3 db), 20 khz (-60 db)
image rejection:      better than 70 db
voltage:      mains 85-265 vac
current drain:      rx: max 210 va
tx: max 800 va
impedance:      50 ohms, 4*so-239
dimensions (w*h*d):      424*150*420 mm
weight:      25 kg
manufactured:      2003-200x
other:      4*32 bit dsp's. built-in rtty/psk31 encoder/decoder.
built-in auto-at. 7" color tft with vga output. twin rx
spectrum scope. digital voice recorder
rs-232c. built-in voice synthesizer
compact flash card for storing personal settings
+40 dbm ultra high intercept point.
new price 2004 in sweden: 92500:- sek
离线bg3aaj
只看该作者 2楼 发表于: 2004-04-08
请教;;;
                      多谢,
离线BD3RJ
只看该作者 1楼 发表于: 2004-04-08
电脑翻译的
被花费的方法不遗憾。 收音机种类,显而易见一个在transiverostroenii,下列产生里向前的台阶。 dsp 过滤器(由于快的处理器或许)运转并非更坏的石英,不要相信,更早如此可能是。 太由于单独和快的dsp panoramnik对最短期的信号有反应。 好的力学(是主观的,不要测量)。 关于1822.4工作9c 3b在从1823.1 叫分开不确实防止。 在14.150 rz3cc上已经用和十分从r9j,我以来为handicapes阻止有ua9hn的qso商量的它。 已经在wpx在40,80 包括过程中工作 - 一种快乐。 车站的发出 - 深和透明,即使跟1000d比较,不绝对疲劳。 键盘足够工作rtty/psk 给usb 给发报机podkljucht的港口。 我将试验,因为时间将出现。 连接一计算机或者在v ci在接口或者一插座通过rs232(db9)上是可能的。 把乐队译码器(天线的自动开关,例如) 使用给管理是可能的的v ci这样的话。 收音机完全既用writelog又用dx4win工作, 为了选择,它从计划756pro或者pro2的菜单必要, 在我的上,以及要兑换由5a开出的那些地址的在那些菜单内7800 这样相当于这几次模特。 在发报机那儿的去天线的4台千斤顶的内,被用那些任何编程序预订,给计划可能和接待一样快的ant4。 连结外部preamp,过滤器,等等是可能的 动态的话筒完全足够7800,那也分辨它和以前的模型icom。 局域网是港口,用途的机会kotorgo icom 许诺稍后声明。 建造 - 用cf这张卡片允许保存菜单,记忆,声文件(rx和tx)的调整。 在成套方面给64毫巴。 整体来看设备被非常严厉而准确做。 展示下午也被同样清楚地看见。
