  • 5469阅读
  • 17回复
======YAESU FT-818====== [复制链接]
离线BD4WM
只看楼主 倒序阅读 0楼 发表于: 2018-03-05
2018年3月1日发布YAESU FT-818
https://www.universal-radio.com/catalog/hamhf/0818.html
https://www.hamradio.com/detail.cfm?pid=H0-016097
http://www.yaesu.com.cn/product/html/?134.html
The new FT-818 incorporates all the many basic and attractive features of the ever-popular FT-817ND while providing upgrades requested by Amateur Radio Operators around the World.
The FT-818 provides 6W of solid output power with an external DC power source. The supplied Ni-MH battery pack (SBR-32MH) has been upgraded to now provide larger battery capacity - 9.6v/ 1900mAh. The recent launch of several new satellites is a certain indicator that the large global community of satellite enthusiast are going to be very delighted to learn that the FT-818 includes a Built-in TCXO-9oscillator that gives the FT-818 fantastic frequency stability (±0.5ppm).
The FT-818 includes all the useful functions that are included in the FT-817ND: Dual VFOs; Split-Frequency operation; IF Shift; Clarifier “R.I.T”; IF Noise Blanker; RF Gain and Squelch control; IPO (Intercept Point Optimization); AM Aircraft reception; AM and FM Broadcast reception; VOX; Built-in Electronic Keyer; Adjustable CW Pitch; Automatic Repeater Shift (ARS); Built-in CTCSS Encoder/ Decoders; 208 memory channels with 10 memory groups; two antenna connectors; Automatic Power-Off (APO) and Time-Out-Timer(TOT) functions; and so on. For any further details, please refer to the attached sheet.
The introduction of the FT-818 naturally means that we will be discontinuing the production of the FT-817ND. We sincerely appreciate your long-term patronage of the FT-817ND that has been such a steady seller for so many years. With the superior upgrades, the new FT-818 is guaranteed to contribute to your business by serving the customer base who continue to be attracted to the features and specifications included in the FT-818
Radio Features:
  • Increased power output 6W(SSB, CW, FM) 2.0W(AM Carrier) *NEW!
  • Improved frequency stability ±0.5 ppm : Built-in TCXO-9 *NEW!
  • Larger battery capacity : 9.6V/1,900mAh (SBR-32) *NEW!
  • 208 Memory Channels / 10 Memory Groups
  • Operates on 160-10m , HF, 6m, 2m and 70 cm Bands
  • Ultra Compact and Portable
  • Two Antenna Connectors
  • IF Shift, IF Noise Blanker, IPO, ATT
  • CW "Semi-Break-in", CW Reverse, CW Pitch Control
  • Built-in Electronic Keyer
  • Multi-Color Easy to see LCD
  • Internal Battery Operation Capability
  • ARS Automatic Repeater Shift
  • APO Automatic Power Off
  • Front Panel Key Lock Mode
Supplied Accessories:
  • Hand Microphone(MH-31A8J)
  • Battery (SBR-32 9.6V 1900mAh Ni-MH )
  • Battery Case (FBA-28) (Requires 8 "AA: batteries)
  • Whip Antenna for 50/144/430 MHz (YHA-63)
  • DC Cable (E-DC-6)
  • Shoulder Strap, Ferrite Core, Rubber Foot
  • Operating Manual
  • Battery Charger (PA-48)
Specifications:
Frequency Ranges:
  • RX 100 kHz - 33 MHz
  • RX 33 MHz - 56 MHz
  • RX 76 MHz - 108 MHz
  • RX 108 MHz - 154 MHz
  • RX 420 MHz - 470 MHz
  • TX 1.8 MHz - 29.7 MHz
  • TX (5.3320 MHz/ 5.3480 MHz/ 5.3585 MHz/ 5.3730 MHz/ 5.4050MHz)
  • TX 50 MHz - 54 MHz
  • TX 144 MHz - 148 MHz
  • TX 430 MHz - 450 MHz (Amateur Bands only)
Circuit Type:
  • Double-Conversion Superheterodyne (SSB/CW/AM/FM)
  • Single-Conversion Superheterodyne (WFM)
Modulation Type: A1A(CW), A3E(AM), J3E(LSB,USB), F3E(FM), F1D(PACKET), F2D(PACKET)
RF Power Output: 6 W (SSB/CW/FM), 2 W (AM Carrier)  @13.8 V
Memory Channels: 208
Case Size (W x H x D): 135 x 38 x 165 mm (5.31" x 1.5" x 6.50") w/o knob and connector
Weight: 900 g (1.98 lbs) (w/o Battery, Antenna and Microphone)
主要功能:
- 增强的6W功率输出(SSB, CW, FM) 2.0W(AM载波) *!
- 改进的频率稳定度 ±0.5 ppm : 内置TCXO-9 *!
- 更大的电池容量 : 9.6V/1,900mAh (SBR-32) *!
- 208个存储信道/10个存储组群
- 工作波段 160-10mHF,6m2m70cm
- 超紧凑结构
- 双天线接口
- 中频偏移、中频噪声抑制, IPO, 衰减器
- CW "Semi-Break-in", CW 标准/反转, CW Pitch Control
- 内置电键
- 多彩易识别LCD
- 内部电池供电
- ARS自动中继异频
- APO自动关机
- 面板按键锁定模式
一般规格:
频率范围
接收  100 kHz - 33 MHz
33 MHz - 56 MHz
76 MHz - 154 MHz
420 - 470 MHz (保证性能仅业余频段)
发射  1.8 MHz - 54 MHz
140 MHz - 154 MHz
420 - 470 MHz (业余频段)
电路类型  双变频超外差(SSB/CW/AM/FM)
单变频超外差(WFM)
调制方式  A1A(CW), A3E(AM), J3E(LSB,USB), F3E(FM), F1D(PACKET), F2D(PACKET)
功率输出  6 W (SSB/CW/FM), 2 W (AM 载波) @13.8 V
信道      208
外观尺寸  135 x 38 x 165 mm(W x H x D) 不包含旋钮与连接器
重量      900 g (不含电池,天线以及麦克风)
附件:
手持麦克风(MH-31A8J)
电池 (SBR-32 9.6V 1900mAh镍氢 )
电池盒 (FBA-28) (支持 8 "AA: 电池)
伸缩天线 50/144/430 MHz (YHA-63)
直流电缆 (E-DC-6)
肩带, Ferrite Core铁氧体磁芯,橡胶脚垫
操作手册
[ 此帖被BD4WM在2018-03-05 23:17重新编辑 ]
B G 4 - 3 - 9 8 5 5 (since 1995)
离线BA5DX
只看该作者 1楼 发表于: 2018-03-06
毫无新意
离线BD6RJ
只看该作者 2楼 发表于: 2018-03-06
离线conjuring
只看该作者 3楼 发表于: 2018-03-06
毫无感觉
QQ:2795 022三6
只看该作者 4楼 发表于: 2018-03-06
还用模拟方案?估计没人感性趣
在线bg2kaj
只看该作者 5楼 发表于: 2018-03-06
八重洲挤牙膏了,若是817不停止出货,这机器谁会相中
WAPC&WAJA达成了!奔向JCC和JA FM DX……
我写过的关于业余无线电的文章汇总:bg2kaj.cn
离线林序帅
只看该作者 6楼 发表于: 2018-03-06
没有欲望
离线李铁柱79
只看该作者 7楼 发表于: 2018-03-06
还不如买817ND呢
便宜实惠
现工作地址:
郑州市金水区纬五路-东明路 手机1823718382九
离线IGY
只看该作者 8楼 发表于: 2018-03-06
为什么不用锂电池?
BG4IGY/张晖
bg4igy(a)163.com
QQ:75850640
山东 日照
离线BG4IGX
只看该作者 9楼 发表于: 2018-03-07
本以为会是中频DSP,支持C4FM,有USB接口
IC-705 FT-818ND 50W功放
IC-705 FT-818ND KX3 100W功放
离线bg8ah
只看该作者 10楼 发表于: 2018-03-07
毫无新意
E-mail: 379798120@qq.com
* 电话:135-5853-6856
* BG8AH :179:
* 邮编:635200
离线net2000
只看该作者 11楼 发表于: 2018-03-08
无线电台大变革前夜,不想再投入人力物力财力开发新的模拟电台,而是把旧设计包装一下投入市场,表明公司没有完全放弃模拟机市场。
未来电台是什么样子?肯定是大屏带频谱,触控操作,高频直入DSP,数字降噪,多线程(一个电台同时接收N个信号)。
离线bg6lmw
只看该作者 12楼 发表于: 2018-03-08
白期望了!
FT-897D基地台,FT-857D车台。
离线BD4NU
只看该作者 13楼 发表于: 2018-03-11
看来,FT-818是YAESU 现今唯一在产的模拟短波电台。
FT-818就如同业余无线电手册一样经典。
比爱疯X 便宜一半。 买吧。
信息污染  是指媒介信息中混入了有害性、欺骗性、误导性信息元素,或者媒介信息中含有的有毒、有害的信息元素超过传播标准或道德底线,对传播生态、信息资源以及人类身心健康造成破坏、损害或其他不良影响。
离线老干部
只看该作者 14楼 发表于: 2018-03-17
我的妈呀,接着要出ft101的纪念版了吧?
BD4AQR KF5GSV
离线BG2BHZ
只看该作者 15楼 发表于: 2018-06-05
YAESU FT-818
价格约人民币4500
BG2BHZ@qq.com
4大QQ群:
CQ语音交流HAM群:297149662
HAM国际技术群:26923662
中国业余无线电官方群:286067296
健伍TK -80,TRC-80交流群:72033389
离线bm3iub
只看该作者 16楼 发表于: 2018-06-05
沒有中文說明書看不大懂~
只看该作者 17楼 发表于: 2018-06-07
回 BG2BHZ 的帖子
BG2BHZ:YAESU FT-818
价格约人民币4500
 (2018-06-05 10:43)
里面电路做了那些改进》????????
