  • 10368阅读
  • 86回复
如何成为一个优秀的QRPer [复制链接]
离线bd4ij
只看该作者 40楼 发表于: 2018-01-02
玩个极限运动,用五瓦呼叫 ,CQ   QRP  ,哈哈哈
QQ:75094437
地址:山东淄博
手机:棕橙绿紫橙橙黑蓝白白灰
离线bg3upa
只看该作者 41楼 发表于: 2018-01-02
回 bg8srq 的帖子
bg8srq:我错了,上次折磨四爷20多遍。 (2017-12-28 18:09)
没把我折腾死,算你幸运。
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
离线bg3upa
只看该作者 42楼 发表于: 2018-01-02
都是没台可追,闲的蛋疼。
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
离线BA2Bi
只看该作者 43楼 发表于: 2018-01-02
回 BD7IHN 的帖子
BD7IHN:回2Bi。
已经又一次注意到你再次发出的那个“极其不负责任”的谴责。那能否解释一下,所言的责任是谁对谁的什么责任? (2018-01-02 10:42)
给你个文章希望你能读懂!你所要的问题和疑问里边基本都有解释!
我也很期待你与大家分享你的QRP操作体会...
http://home.windstream.net/johnshan/dx_ss_working.html
K3WWP 知名的QRPer
Some QRP stations like to sign /QRP at the end of their call in a pile-up. I don't think it's necessary, and I don't do it for the following reasons:
1. I don't feel my QRP should be pointed out as a special situation. I'm just another station in the pile, not someone special because I'm only using 5 watts or less.
2. I am sure some QRO stations cheat and sign /QRP, and I certainly don't want to be accused of that by those who don't know that I am a 100% QRPer.
3. It does take an appreciable amount of time to send /QRP when you are dealing with running hundreds of stations per hour, especially if it has to be repeated. If I make a contact, there's a chance I'll have to repeat my info since my sigs are weak, and repeating /QRP along with the other info may annoy not only the DX station, but others waiting in the pile. I hate slowing down DXpeditions or contesters like that.
4. To back up what I say in item 3 above, famous DXpeditioner G3SXW in his book "Up Two" urges operators calling him not to use /QRP. Then there is this quote from the 3B9C DXpedition web site to further denounce using /QRP: "We have received a few e-mails demanding that we amend logs to show /QRP. We are aware that some operators at 3B9C have been logging /QRP but it is DXpedition policy that we do not do so. /QRP does not form part of the legal callsign in any country and, as far as we are aware, no QRP awards require the callsign to be suffixed with /QRP. Therefore the /QRP suffix has no place in the 3B9C DXpedition log. You know whether you worked us on QRP or not and that should be all that is needed."
[ 此帖被BA2Bi在2018-01-02 11:49重新编辑 ]
离线BD7IHN
只看该作者 44楼 发表于: 2018-01-02
回6QH。
你用QRP追逐远征台了?2Bi知不知道有这样的事情?24楼他文中第三点,你一定是还没看了。不然,你怎么同意他所有的回答?你是在挖苦2Bi吗?
你极少主叫,我没有意见。问题是,我是不是就不能在海岛上用QRP呼号主叫?
你也提到“极端不负责”,那好吧,请解释一下所言的责任是谁对谁的什么责任?
你所说的DX圣经是哪一篇?
BD7INH到黄岩岛搞QRP远征?这是真的吗?好提议,看我会不会被吐沫淹死。为了这个就该让我去。
你在通联中是否加/QRP,那是你的权力。同样的,我也有这样的权力。你可以嗤之以鼻,我可以甘之若饴。
念想难道不是应该存在于心里的吗?干嘛说出来?我觉得你最后一句话像是在炫耀喔。不怕2Bi来写红字?
[ 此帖被BD7IHN在2018-01-02 11:56重新编辑 ]
73!
DE BD7IHN/赵向东
离线BA9BF
只看该作者 45楼 发表于: 2018-01-02
楼好像有点歪了!都是《神聊板块》惹的祸!
我不远征,也没精力远征,我只能偶尔扫个地,拣个漏!给远征台添点乱,乱了我就跑!哈哈哈哈!
Email: ba9bf@163.com
离线BD7IHN
只看该作者 46楼 发表于: 2018-01-02
回 BA2Bi 的帖子
BA2Bi:
根据之前的经验,我更担心你读懂了没有。
73!
DE BD7IHN/赵向东
离线BA2Bi
只看该作者 47楼 发表于: 2018-01-02
以前我刻意 /QRP 方式去工作,我辛苦的追到一个New DX 我已/QRP 明明/QRP 的CFM QSO 但在他的log里 /QRP 没有了 我很愤怒 我发去电子邮件请求更正加上/QRP....
我喜欢QRP 所以我就要学习和探索,目前也在学习中...
我的体会与大家分享,希望这些能给那些QRP爱好者一个启示,当然你可以无视,@BD7IHN   你坚持你的海岛的 '远征' 使用B7/BD7IHN/QRP 没有任何法律阻止你。
QRP业余无线电中的小众,这个小圈子有很多优秀的QRPer 来分享他们的观点,这些观点如果得到共鸣,这就是一个没有约束力的规则,但很多爱好者去认可这个常识,这些就是“QRP之道”!
“QRP之道 ”中文一词,来源于 BY QRPer BA6QH 也是BY首位申请ARRL DXCC(QRP)奖状证书。
未来的日子我会在“QRP之道 ”与各位共勉
本帖提到的人: @BD7IHN
离线BA2Bi
只看该作者 48楼 发表于: 2018-01-02
回 BD7IHN 的帖子
BD7IHN:
根据之前的经验,我更担心你读懂了没有。
你看看你的问题是不是都在里边呢? 关于/QRP 加不加 ?加/QRP浪费时间吗?
部分翻译如下(可能表达有误)
一些QRP电台喜欢呼号/ QRP。我不认为这是必要的,我不这样做,原因如下:
1.我不觉得我的QRP应该被指出为特殊情况。我只是另外一个电台,而不是一个特殊的人,
2.我确信一些QRO站作弊用呼号/ QRP,我当然不想被那些不知道我是100%QRPer的人指责。
3.当您每小时处理数百个电台时,发送/ QRP需要相当长的时间,特别是如果需要重复的话。如果我联系了,有一个机会,我不得不重复我的信息,因为我的信号是弱的,重复/ QRP和其他信息可能会惹恼DX站,但其他人在等待。我讨厌制造放慢DXpeditions的追逐者。
4.为了支持我在上面第3项中所说的,著名名DXPditioner G3SXW在他的文章“Up Two”中敦促操作员叫他不要使用/ QRP。那么这个引用来自3B9C DXpedition网站的进一步谴责使用/ QRP:“我们收到了一些电子邮件,要求我们修改日志以显示/ QRP。我们知道一些3B9C的操作员已经记录/ QRP但是我们不这样做是DXPdition政策/ QRP不构成任何国家的合法呼号的一部分,并且据我们所知,没有QRP奖项要求呼号加后缀/ QRP,因此/ QRP后缀在3B9C DXpedition日志中没有....。
离线BD7IHN
只看该作者 49楼 发表于: 2018-01-02
回 BA2Bi 的帖子
BA2Bi:你看看你的问题是不是都在里边呢? 关于/QRP 加不加 ?加/QRP浪费时间吗?
....... (2018-01-02 13:04)
看来我的担心不是多余的,你真没读懂。你用的是百度翻译吗?还是别的软件翻译的?不要以为转换成汉字就读懂了。
你需要时间,不要那么快交卷。
73!
DE BD7IHN/赵向东
离线BH4XDZ
只看该作者 50楼 发表于: 2018-01-02
我建议你把DX远征的含义搞清楚 什么是DX远征?  你觉得弄个电台不远千里到北京某个山头架设电台CQ...就是DX-pedition?
答非所问,歪楼了,我什么时候说过“弄个电台不远千里到北京某个山头架设电台CQ...就是DX-pedition”了?因为提到能不能用“**/bh4xdz/p”呼号才这样认为的?这个qrp远征用/P,也是以前查询看到一个国外qrp爱好者主页,介绍其经常骑行到国外不常见字头dx远征用过的呼号,这位qrper远征也是用/qrp的。当然是否用/p也看远征时工作场所是否符合户外定义。至于dx远征和普通的跨区野外架台区别无需讨论,这里说的远征自然是默认指dx远征。
重看一遍帖,寻找想知道的答案,楼主的意思应该是:远程台可以qrp,但不要使用/QRP方式cq,否则就“ 是极其不负责任的 也不值得赞赏。  说明OP 不是一个合格的 DXpeditioner !更不是一个QRPer!
可能楼主是远程的角度谈qrp,我是从qrp角度看远征,所以借这贴学习讨论下qrp远征用什么呼号妥当
SSB基本靠吼,CW基本靠抖
野外基本靠走,电池基本靠凑
天线超级简陋,F层基本穿透
守听背躁 S9,只好hellocq
离线BH4XDZ
只看该作者 51楼 发表于: 2018-01-02
打字错误:可能楼主是远征的角度谈qrp
SSB基本靠吼,CW基本靠抖
野外基本靠走,电池基本靠凑
天线超级简陋,F层基本穿透
守听背躁 S9,只好hellocq
离线bg8srq
只看该作者 52楼 发表于: 2018-01-02
回 bg3upa 的帖子
bg3upa:没把我折腾死,算你幸运。[表情] (2018-01-02 11:39)
来云南我敬你三大盆,我自罚三杯。
RIG:K3 ANT:K4GP
离线BA2Bi
只看该作者 53楼 发表于: 2018-01-02
回 BD7IHN 的帖子
BD7IHN:看来我的担心不是多余的,你真没读懂。你用的是百度翻译吗?还是别的软件翻译的?不要以为转换成汉字就读懂了。
你需要时间,不要那么快交卷。 (2018-01-02 14:46)
我写出来了 和大家分享了   看来你发现我的错误 没关系你可以指出来哪里有描述错误,
我期待你指正出来,我和大家期待你的翻译正确的描述 。
[ 此帖被BA2Bi在2018-01-02 16:27重新编辑 ]
离线BH6JFR
只看该作者 54楼 发表于: 2018-01-02
老外的参考参考就行拉,不必太认真。  有的玩就行,我只要在台上呼叫,低于5W都是用BH6JFR/QRP的,这样别人也知道我是小功率。大于5W就不加了。发卡片的时候国内有的很在意这个/qrp,有的不在意,无所谓了,玩嘛。加了更好。他那个文章也是他“认为”  只是他的观点而已
河南郑州BH6JFR  QQ:1036278928
离线BH4XDZ
只看该作者 55楼 发表于: 2018-01-02
9494,如果都按K3WWP和 G3SXW的意见,以后就我们再也听不到喜闻乐见的BA6QH/QRP呼号通联和追台了
不过我还是想知道:qrp远征主叫时,能不能加/QRP?加了会不会被骂?
SSB基本靠吼,CW基本靠抖
野外基本靠走,电池基本靠凑
天线超级简陋,F层基本穿透
守听背躁 S9,只好hellocq
离线BG1TRP
只看该作者 56楼 发表于: 2018-01-02
ARRL推荐的《业余无线电守则与操作规范》中提到 呼号/QRP 在一些国家中是不合法的写法。
离线BA6QH/QRP
只看该作者 57楼 发表于: 2018-01-02
回 BH4XDZ 的帖子
BH4XDZ:9494,如果都按K3WWP和 G3SXW的意见,以后就我们再也听不到喜闻乐见的BA6QH/QRP呼号通联和追台了
不过我还是想知道:qrp远征主叫时,能不能加/QRP?加了会不会被骂? (2018-01-02 16:53)
能带给大家喜闻乐见的通联,是对七公莫大的鼓励,谢谢
这个帖子要好好捋一捋,工作太忙了,等有空的时候再仔细回吧!
离线BA9BF
只看该作者 58楼 发表于: 2018-01-02
麻烦一下BG1TRP老师,给QRP爱好者们,上传一份ARRL推荐的《业余无线电守则与操作规范》这本书。最好是PDF版本,让各位好友们也心知肚明,以便于今后用QRP功率操作呼叫CQ  CQ  CQ .............................时,规范QRP通联,规范QRP回答,免得让洋蛤蟆偷笑我们BY操作员!
离线BA2Bi
只看该作者 59楼 发表于: 2018-01-02
回 BH4XDZ 的帖子
BH4XDZ:
我的建议:
你作为远征台 不建议你用QRP 和呼号加不加/QRP 没有关联。 条件所限另当别论,一个远征台的消息公布,世界上有很多的渴望者,我希望你优化你的设备功率天线来满足需求,这就是一种DXpeditioner 要懂得的责任
如果那你是在追一个远征台,我希望你能对传播情况有一个判断,如果你认为有机会,我鼓励你去用QRP去尝试一下。从而验证你的判断能力。
对于日常的QSO 如果是主叫CQ 我推荐你去QRP的频率去工作 或者在其他频率追台 对方不是很忙,我仍然鼓励你去用QRP尝试一下  当然可以加上/QRP
[ 此帖被BA2Bi在2018-01-02 17:30重新编辑 ]
