  • 3863阅读
  • 18回复
这周末CQWW VHF 2017 [复制链接]
离线BG5TOX
只看楼主 倒序阅读 0楼 发表于: 2017-07-10
CQ World Wide VHF Contest
Begins: 1800 UTC Saturday, July 15, 2017
Ends: 2100 UTC Sunday, July 16, 2017
北京时间:7月16日凌晨2:00——7月17日早晨5:00
喜欢 6米 / 2米 波段的朋友搞起吧……
NEW: Use of APRS by Rovers is now permitted for the purpose of announcing their location.
新规则:车载移动台允许使用APRS来公布其当前的网格。
I. Contest Period
27 hours for all stations, all categories. Operate any portion of the contest period you wish. (Note: Exception for QRP Hilltopper.)
比赛时间27小时,QRP登山者组别除外。
II. Objectives
The objectives of this contest are for amateurs around the world to contact as many amateurs as possible in the contest period, to promote VHF, to allow VHF operators the opportunity to experience the enhanced propagation available at this time of year, and for interested amateurs to collect VHF Maidenhead grid locators for award credits.
III. Bands
All amateur radio frequencies on 50 MHz (6 meters) and 144 MHz (2 meters) may be used as authorized by local law and license class. Note exceptions in Rule XI for common repeater frequencies and 146.52 MHz.
IV. QSO Alerting Assistance
The use of any technology or other source that provides callsign or multiplier identification along with frequency information about a signal to the operator. This includes, but is not limited to, use of DX Cluster, packet, local or remote callsign and frequency decoding technology (e.g., CW Skimmer or Reverse Beacon Network), or operating arrangements involving other individuals.
  1. All stations are allowed to use QSO Alerting Assistance. No self-spotting or asking to be spotted is allowed. 所有组别允许辅助,不能发自己的spot。
  2. Stations attempting digital EME or digital meteor-scatter QSOs are allowed to spot the callsign, frequency, and sequence only. Caution: To ensure strict compliance with these rules, the adjudication process will include review of realtime and archived transcripts from websites used to coordinate alerting data during the contest period.  尝试EME 、流星余迹通联的时候允许公布呼号、频率、时序。
  3. The use of non-amateur means to effect a QSO is not allowed. This includes use of the telephone, and website posts providing information beyond that of callsign, frequency, and sequence.
  4. Rovers may use APRS to announce their location. 车载移动台允许使用APRS来公布其当前的网格。
V. Categories of Competition
For all categories: Transmitters and receivers must be located within a 500-meter diameter circle or within the property limits of the station licensee's address, whichever is greater.
  1. Single Operator - All Band. 单人全波段Only one signal allowed at any one time; the operator may change bands at any time.
  2. Single Operator - Single Band. 单人单波段Only one signal allowed at any one time.
  3. Single-Operator - All-Band QRP. 单人全波段QRPThere are no location restrictions - home or portable - for stations running 10 watts output or less.
  4. Hilltopper. 登山者This is a single-op QRP portable category for an all-band entry limited in time to a maximum of 6 continuous hours. Backpackers and portables who do not want to devote resources and time to the full contest period are encouraged to participate, especially to activate rare grids. Any power source is acceptable. 使用QRP移动台进行最长6小时的操作,允许使用任意电源。
  5. Rover. 车载移动台A Rover station is one manned by no more than two operators, travels to more than one grid location, and signs "Rover" or "/R" with no more than one callsign. 呼号加/R
  6. Multi-Op. 多人全波段A multi-op station is one with two or more operators and may operate 6 and 2 meters simultaneously with only one signal per band. 6米 & 2米允许设两个台同时开工,每个波段只允许一个信号出现在空中。
Stations in any category, except Rover and QRP Hilltopper, may operate from any single location, home or portable.
VI. Exchange
Callsign and Maidenhead grid locator (4 characters, e.g., EM15). Signal reports are not required and should not be included in the log entry.
交换4位网格号,例如EM15。
VII. Multipliers
每通一个网格算一个系数。
The multiplier is the number of different grid locators worked per band. A grid locator is counted once per band. Exception: The rover who moves into a new grid locator may count the same grid locator more than once per band as long as the rover is himself or herself in a new grid locator location. Such change in location must be clearly indicated in the rover's log.
  1. A rover station becomes a new QSO to the stations working him or her when that rover changes grid locator.通到车载移动台,每个网格都算系数。
  2. The grid locator is the four-character Maidenhead grid (e.g. EM15).网格号为4位,例如EM15。
VIII. Scoring
One (1) point per QSO on 50 MHz and two (2) points per QSO on 144 MHz. Work stations once per band, regardless of mode. Multiply total QSO points times total number of grid locators (GL) worked. 6米波段每个QSO=1分,2米波段每个QSO=2分。
Rovers: For each new grid locator visited, contacts and grid locators count as new. Final Rover score is the sum of contact points made from each grid locator times the sum of all grid locators worked from all grids visited.
Example 1. K1GX works stations as follows:
50 QSOs (50 x 1 = 50) and 25 GLs (25 multipliers) on 50 MHz
35 QSOs (35 x 2 = 70) and 8 GLs (8 multipliers) on 144 MHz
K1GX has 120 QSO points (50 + 70 = 120) x 33 multipliers
(25 + 8 = 33) = 3,960 total points.
Example 2. W9FS/R works stations as follows:
From EN52: 50 QSOs (50 x 1 = 50) and 25 GLs (25 multipliers) on 50 MHz
From EN52: 40 QSOs (40 x 2 = 80) and 10 GLs (10 multipliers) on 144 MHz
From EN51: 60 QSOs (60 x 1 = 60) and 30 GLs (30 multipliers) on 50 MHz
From EN51: 20 QSOs (20 x 2 = 40) and 5 GLs (5 multipliers) on 144 MHz
W9FS/R has 230 QSO points (50 + 80 + 60 + 40) x 70 multipliers
(25 + 10 + 30 + 5) = 16,100 total points
IX. Awards
Certificates will be awarded to the topscoring stations in each category in each country. Certificates may also be awarded to other top-scoring stations that show outstanding contest effort. Certificates will be awarded to top-scoring stations in each category in geographic areas where warranted.
Geographic areas include states (U.S.), provinces (Canada), and countries, and may also be extended to include other subdivisions as justified by competitive entries. U.S. Rover certificates are issued on a regional basis.
Plaques again will be awarded to the highest scoring stations. They are offered in various categories on a sponsored basis. Clubs and individual plaque donors are sought and may find information on how to sponsor a CQWW VHF Contest plaque at < http://www.cqww-vhf.com/plaques.htm >.
X. Club Competition
Credit your club for aggregate club score. See < http://www.cqww.com/clubnames.htm > for a list of registered clubs. Follow directions for registering your club if not already registered.
XI. Miscellaneous
An operator may sign only one callsign during the contest. This means that an operator cannot generate QSOs by first signing his callsign, then signing his daughter's callsign, even though both callsigns are assigned to the same location.
A station located exactly on a dividing line of a grid locator must choose only one grid locator from which to operate for exchange purposes.
夹在网格(4位)分界线上的参赛台,只能选一侧的网格作为比赛中的交换信息。
A different multiplier cannot be given out without moving the complete station at least 100 meters.
Making or soliciting QSOs on the national simplex frequency, 146.52 MHz, or your country's designated national simplex frequency, or immediately adjacent guard frequencies, is prohibited. Use of commonly recognized repeater frequencies is prohibited. Recognized FM simplex frequencies such as 146.49, .55, and .58, and local-option simplex channels may be used for contest purposes.
Aeronautical mobile contacts do not count.
Contestants should respect use of the DX window, 50.100-50.125 MHz, for intercontinental QSOs only.
UTC is the required logging time.
XII. Declaration
Your submission of a log entry affirms that: (1) you have abided by all the rules of the contest as well as those of your country's licensing authority; (2) you accept any decisions made regarding your entry by the contest's adjudication process which are official and final.
XIII. Log Submissions
Log entries must be submitted by August 1, 2017 to be eligible for awards. Submit your electronic log in the Cabrillo format created by all major logging programs. Send via e-mail attachment to < cqvhf@cqww-vhf.com >. Subject line: Callsign [the call used in the contest] only.
八月一日前提交日志到上述邮箱,邮件标题为(比赛中使用的)呼号即可。
Entrants are reminded to be sure your log indicates your operating location. 日志中必须有包含你自己的网格。For USA/VE stations, be sure to indicate the state or province of your operation. If you have a problem submitting your log, please contact < help@cqww-vhf.com > for assistance.
It is strongly recommended that paper logs be entered online for automatic Cabrillo submission. Click on the "Web Form for Typing in Paper Logs" link on the contest website at < http://www.cqww-vhf.com >.
Computer-generated logs must be e-submitted. Callsigns of electronic logs received are posted and updated daily on the website.
For those without web access, paper logs may be mailed to: Paper Logs, P.O. Box 481, New Carlisle, OH 45344.
Questions may be sent to < help@cqww-vhf.com >.
[ 此帖被BG5TOX在2017-07-11 13:18重新编辑 ]
Callsign:BG5TOX
QQ:327586364
离线BG0ATE
只看该作者 1楼 发表于: 2017-07-10
直接翻过来吧,咋打不开。
离线BG5TOX
只看该作者 2楼 发表于: 2017-07-10
回 BG0ATE 的帖子
BG0ATE:直接翻过来吧,咋打不开。 (2017-07-10 12:49)
贴上来了
Callsign:BG5TOX
QQ:327586364
离线BH4rrg
只看该作者 3楼 发表于: 2017-07-10
这个只能围观了
BH4RRG       CSKC#219
常用DX信息网站:
http://new.dxsummit.fi/
http://www.425dxn.org/
http://dx-world.net/
离线bg3upa
只看该作者 4楼 发表于: 2017-07-10
强势围观。楼主做回雷锋,蝌蚪文看不懂。
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
离线BG5TOX
只看该作者 5楼 发表于: 2017-07-10
回 bg3upa 的帖子
bg3upa:强势围观。楼主做回雷锋,蝌蚪文看不懂。 (2017-07-10 22:17)
关键信息标注上了,凑合看吧……
Callsign:BG5TOX
QQ:327586364
离线BA7QT
只看该作者 6楼 发表于: 2017-07-11
强势围观。
BEST 73!   DE BA7QT/LIAO
QSL MGR:W3HNK
qq:48892357  广西短波群:47730720
离线BH4IGO
只看该作者 7楼 发表于: 2017-07-11
别围观 搞搞嘛
呼号:BH4IGO
电话:18653388265
离线m6sig
只看该作者 8楼 发表于: 2017-07-11
可以用跨度转发的业余卫星么?V上U下那种?
CS: M6SIG   LOC: JO01
新浪微博:@熊猫阿B0
不再更新的旧数据: http://t.cn/RhrIAYe
离线BD5XX
只看该作者 9楼 发表于: 2017-07-11
周末上山去喽
EX:BD5SO、BG5RSO
Email:bd5xx@foxmail.com
离线BG5TOX
只看该作者 10楼 发表于: 2017-07-11
回 m6sig 的帖子
m6sig:可以用跨度转发的业余卫星么?V上U下那种? (2017-07-11 21:52)
可以用meteor scatter & EME
我这边EME暂时是没办法咯。。MS倒是可尝试,2000KM以内的范围,不知道国内有没有友台可以配合测试一下。
[ 此帖被BG5TOX在2017-07-11 23:07重新编辑 ]
Callsign:BG5TOX
QQ:327586364
离线m6sig
只看该作者 11楼 发表于: 2017-07-11
回 BG5TOX 的帖子
BG5TOX:可以用meteor scatter & EME [表情] (2017-07-11 23:01)
要是EME算独立一个段、流星又算独立一个段、卫星又算独立一个段,还跟 ARRL FD 比赛 似的数字话音模式的卫星还另外加一分基本分!
这还差不多!!!!!!!!!!
CS: M6SIG   LOC: JO01
新浪微博:@熊猫阿B0
离线BG5TOX
只看该作者 12楼 发表于: 2017-07-11
不知道有没有BY的友台愿意周末晚上一起尝试做6米 MS (流星余迹散射);
对此一直比较好奇,MS仅在业余无线电的玩法介绍中看到过。
频率:50280
主流模式:MSK144 / FSK411 / JT6M / ISCAT
软件:WSJT-X 或 MSHV
[ 此帖被BG5TOX在2017-07-11 23:19重新编辑 ]
Callsign:BG5TOX
QQ:327586364
离线BD5XX
只看该作者 13楼 发表于: 2017-07-12
回 BA7QT 的帖子
BA7QT:强势围观。 (2017-07-11 17:08)
别围观 搞搞嘛
EX:BD5SO、BG5RSO
离线BD5XX
只看该作者 14楼 发表于: 2017-07-12
回 bg3upa 的帖子
四爷疯起来
EX:BD5SO、BG5RSO
离线BD7TBP
只看该作者 15楼 发表于: 2017-07-13
7月16日搞一天6米段...........
人不可有傲气,但不可无傲骨...........
离线BD7IS
只看该作者 16楼 发表于: 2017-07-13
回  12楼(BG5TOX)的帖子
第12楼BG5TOX于2017-07-11 23:16发表的:
频率:50280
主 ..
有流星吗?还不如约妹子到野外看流星更实在。
离线BG5TOX
只看该作者 17楼 发表于: 2017-07-13
回 BD7IS 的帖子
BD7IS:有流星吗?还不如约妹子到野外看流星更实在。 (2017-07-13 12:39)
http://space.iggcas.ac.cn/WHMeteoradar.html
国内流星雷达的数据很详细,可以看一下。
24小时都有流星,肉眼看不见不代表没有;
天亮前的那段时间最多,这个跟地球的自转、公转方向有关系。
Callsign:BG5TOX
QQ:327586364
离线bg3upa
只看该作者 18楼 发表于: 2017-07-13
回 BD5XX 的帖子
BD5XX:四爷疯起来[表情] (2017-07-12 23:46)
金爷:回来就没闲着,要到16号后才能喘口气。
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
