  • 2545阅读
  • 9回复
告诉我, 这周有什么比赛可以玩? [复制链接]
离线BA7IO
只看楼主 倒序阅读 0楼 发表于: 2015-03-21
— 本帖被 BA7IO 执行加亮操作(2015-03-21) —
告诉你,这周可以玩玩这两个比赛:
+ BARTG HF RTTY Contest0200Z, Mar 21 to 0200Z, Mar 23
+ Russian DX Contest1200Z, Mar 21 to 1200Z, Mar 22
联系方式: 站内短信
离线BA7IO
只看该作者 1楼 发表于: 2015-03-21
     Status:    Active
     Mode:    RTTY
     Bands:    80, 40, 20, 15, 10m
     Classes:    Single Op Expert All Band
Single Op All Band
Single Op All Band 6 Hours
Single Op Single Band
Multi-Single
Multi-Multi
     Max operating hours:    Single Op: 30 hours with at least 3 hour rest period
Single Op 6 Hours: 6 hours
Multi-Op: 48 hours
     Exchange:    RST + Serial No. + 4-digit time (UTC)
     Work stations:    Once per band
     QSO Points:    1 point per QSO
     Multipliers:    DXCC countries once per band
JA, W, VE and VK areas once per band
Continents once regardless of band
     Score Calculation:    Total score = total QSO points x total country/area mults x continents
     E-mail logs to:    (none)
     Upload log at:    http://bartg.rsgbcc.org/cgi-bin/hfenter.pl
     Mail logs to:    (none)
     Find rules at:    http://s3.spanglefish.com/s/7850/documents/contests/hf/rules/current/bartg%20hf%20rules.pdf
联系方式: 站内短信
离线BA7IO
只看该作者 2楼 发表于: 2015-03-21
Russian DX Contest
     Status:    Active
     Mode:    CW, SSB
     Bands:    160, 80, 40, 20, 15, 10m
     Classes:    Single Op All Band Mixed (QRP/Low/High)
Single Op All Band CW (Low/High)
Single Op All Band SSB (Low/High)
Single Op Single Band Mixed
Multi-Single
Multi-Two
SWL
     Max power:    HP: >100 watts
LP: 100 watts
QRP: 5 watts
     Exchange:    Ru: RS(T) + 2-character oblast
non-Ru: RS(T) + Serial No.
     Work stations:    Once per band per mode
     QSO Points:    Ru Stations: 2 points per QSO with same country same continent
Ru Stations: 5 points per QSO with same country different continent
Ru Stations: 3 points per QSO with different country same continent
Ru Stations: 5 points per QSO with different continent
non-Ru Stations: 10 points per QSO with Ru station
non-Ru Stations: 2 points per QSO with same country
non-Ru Stations: 3 points per QSO with different country same continent
non-Ru Stations: 5 points per QSO with different continent
5 points per QSO with /MM
     Multipliers:    Each oblast once per band
Each country once per band
     Score Calculation:    Total score = total QSO points x total mults
     E-mail logs to:    logs[at]rdxc[dot]org
     Upload log at:    http://www.rdxc.org/asp/pages/wwwlog.asp
     Find rules at:    http://www.rdxc.org/asp/pages/rulesg.asp
联系方式: 站内短信
只看该作者 3楼 发表于: 2015-03-21
早点睡,明天早起干活
离线我是伍亿
只看该作者 4楼 发表于: 2015-03-21
比前几天的传播好多了
泪流满面
哈尔滨体育学院
BG2CTX QSL卡管理人:BH2RO  来卡不回
离线BH7PFH
只看该作者 5楼 发表于: 2015-03-21
有传播、没传播都干嚎,得到一个算一个。
BH7PFH
在线BA7CK
只看该作者 6楼 发表于: 2015-03-21
回 我是伍亿 的帖子
我是伍亿:[图片]
比前几天的传播好多了
泪流满面 (2015-03-21 00:36)
看这个比赛,没啥意思。
在线永远的FM
只看该作者 7楼 发表于: 2015-03-21
果断下周深度发呆
在线BA7CK
只看该作者 8楼 发表于: 2015-03-21
永远的FM:果断下周深度发呆 (2015-03-21 10:52)
下周大碗喝酒大口吃肉,想想都口水中。。。。。爽!!
在线永远的FM
只看该作者 9楼 发表于: 2015-03-22
回 BA7CK 的帖子
BA7CK:[表情]
 (2015-03-21 12:49)
记得不要趴下,XX9在所有band等着你
