[ 0.530000] 0x000000020000-0x0000003f0000 : "firmware"
[ 0.560000] ag71xx_mdio: probed
[ 0.560000] eth0: Atheros AG71xx at 0xb9000000, irq 4
[ 1.110000] ag71xx ag71xx.0: eth0: connected to PHY at ag71xx-mdio.1:04 [uid=
004dd041, driver=Generic PHY]
[ 1.120000] TCP cubic registered
[ 1.130000] NET: Registered protocol family 17
[ 1.130000] 8021q: 802.1Q VLAN Support v1.8
[ 2.150000] jffs2_scan_eraseblock(): End of filesystem marker found at 0x2c00
00
[ 2.150000] jffs2_build_filesystem(): unlocking the mtd device... done.
[ 2.160000] jffs2_build_filesystem(): erasing all blocks after the end marker
... done.
[ 2.860000] JFFS2 notice: (1) jffs2_build_xattr_subsystem: complete building
xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 or
phan) found.
[ 2.880000] VFS: Mounted root (jffs2 filesystem) readonly on device 31:2.
[ 2.880000] Freeing unused kernel memory: 208k freed
- preinit -
Press the [f] key and hit [enter] to enter failsafe mode
[ 7.110000] eth0: link up (100Mbps/Full duplex)
- regular preinit -
- init -
[ 8.230000] eth0: link down
[ 9.000000] Compat-wireless backport release: compat-wireless-2012-07-13
[ 9.000000] Backport based on wireless-testing.git master-2012-07-16
[ 9.010000] compat.git: wireless-testing.git
[ 9.150000] cfg80211: Calling CRDA to update world regulatory domain
[ 9.160000] cfg80211: World regulatory domain updated:
[ 9.160000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gai
n, max_eirp)
[ 9.170000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 9.180000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 20
00 mBm)
[ 9.190000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 20
00 mBm)
[ 9.190000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 9.200000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 9.400000] usbcore: registered new interface driver usbfs
[ 9.410000] usbcore: registered new interface driver hub
[ 9.410000] usbcore: registered new device driver usb
[ 10.030000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[ 10.030000] cfg80211: Calling CRDA for country: US
[ 10.040000] cfg80211: Regulatory domain changed to country: US
[ 10.040000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gai
n, max_eirp)
[ 10.050000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 27
00 mBm)
[ 10.060000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 17
00 mBm)
[ 10.070000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 10.070000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 10.080000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 10.090000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 30
00 mBm)
[ 10.180000] PPP generic driver version 2.4.2
[ 10.250000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.390000] NET: Registered protocol family 24
[ 10.440000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 10.440000] ehci-platform ehci-platform: Generic Platform EHCI Controller
[ 10.450000] ehci-platform ehci-platform: new USB bus registered, assigned bus
number 1
[ 10.490000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 10.510000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 10.510000] hub 1-0:1.0: USB hub found
[ 10.510000] hub 1-0:1.0: 1 port detected
[ 10.570000] nf_conntrack version 0.5.0 (458 buckets, 1832 max)
[ 10.870000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ü
U-Boot 1.1.4 (Jun 6 2012 - 22:48:28)
AP121 (ar9330) U-boot
DRAM: 32 MB
led turning on for 1s...
id read 0x100000ff
flash size 4194304, sector count = 64
Flash: 4 MB
Using default environment
In: serial
Out: serial
Err: serial
Net: ag7240_enet_initialize...
No valid address in Flash. Using fixed address
: cfg1 0x5 cfg2 0x7114
eth0: 00:03:7f:09:0b:ad
ag7240_phy_setup
eth0 up
: cfg1 0xf cfg2 0x7214
eth1: 00:03:7f:09:0b:ad
athrs26_reg_init_lan
ATHRS26: resetting s26
ATHRS26: s26 reset done
ag7240_phy_setup
eth1 up
eth0, eth1
Autobooting in 3 seconds
## Booting image at 9f020000 ...
Uncompressing Kernel Image ... OK
Starting kernel ...
[ 0.000000] Linux version 3.3.8 (blogic@Debian-60-squeeze-64-minimal) (gcc ve
rsion 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #2 Mon Sep 3 17:51:
18 UTC 2012
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.00
0MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 02000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00002000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00002000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag
es: 8128
[ 0.000000] Kernel command line: board=TL-WR703N console=ttyATH0,115200 root
fstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32
bytes
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 29136k/32768k available (2198k kernel code, 3632k reserve
d, 412k data, 208k init, 0k highmem)
[ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, No
des=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.090000] NET: Registered protocol family 16
[ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
[ 0.100000] MIPS: machine is TP-LINK TL-WR703N v1
[ 0.340000] bio: create slab <bio-0> at 0
[ 0.350000] Switching to clocksource MIPS
[ 0.350000] NET: Registered protocol family 2
[ 0.360000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.360000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.360000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.370000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.380000] TCP reno registered
[ 0.380000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.390000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.390000] NET: Registered protocol family 1
[ 0.420000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.420000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY
) (c) 2001-2006 Red Hat, Inc.
[ 0.430000] msgmni has been set to 56
[ 0.430000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
54)
[ 0.440000] io scheduler noop registered
[ 0.440000] io scheduler deadline registered (default)
[ 0.450000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.460000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UA
RT
[ 0.470000] console [ttyATH0] enabled, bootconsole disabled
[ 0.480000] m25p80 spi0.0: found en25q32b, expected m25p80
[ 0.480000] m25p80 spi0.0: en25q32b (4096 Kbytes)
[ 0.490000] 5 tp-link partitions found on MTD device spi0.0
[ 0.490000] Creating 5 MTD partitions on "spi0.0":
[ 0.500000] 0x000000000000-0x000000020000 : "u-boot"
[ 0.510000] 0x000000020000-0x000000110000 : "kernel"
[ 0.510000] 0x000000110000-0x0000003f0000 : "rootfs"
[ 0.520000] mtd: partition "rootfs" set to be root filesystem
[ 0.520000] split_squashfs: no squashfs found in "spi0.0"
[ 0.530000] 0x0000003f0000-0x000000400000 : "art"
[ 2.150000] JFFS2 notice: (1) jffs2_build_xattr_subsystem: complete building
phan) found.
[ 2.170000] VFS: Mounted root (jffs2 filesystem) readonly on device 31:2.
[ 2.170000] Freeing unused kernel memory: 208k freed
- preinit -
- regular preinit -
- init -
[ 7.560000] eth0: link down
[ 8.330000] Compat-wireless backport release: compat-wireless-2012-07-13
[ 8.330000] Backport based on wireless-testing.git master-2012-07-16
[ 8.340000] compat.git: wireless-testing.git
[ 8.490000] cfg80211: Calling CRDA to update world regulatory domain
[ 8.490000] cfg80211: World regulatory domain updated:
[ 8.500000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gai
n, max_eirp)
[ 8.500000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 8.510000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 20
00 mBm)
[ 8.520000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 20
00 mBm)
[ 8.530000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 8.540000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 8.730000] usbcore: registered new interface driver usbfs
[ 8.740000] usbcore: registered new interface driver hub
[ 8.740000] usbcore: registered new device driver usb
[ 9.360000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[ 9.370000] cfg80211: Calling CRDA for country: US
[ 9.370000] cfg80211: Regulatory domain changed to country: US
[ 9.370000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gai
n, max_eirp)
[ 9.380000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 27
00 mBm)
[ 9.390000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 17
00 mBm)
[ 9.400000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 9.410000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 9.410000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 9.420000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 30
00 mBm)
[ 9.510000] PPP generic driver version 2.4.2
[ 9.590000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 9.720000] NET: Registered protocol family 24
[ 9.770000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 9.770000] ehci-platform ehci-platform: Generic Platform EHCI Controller
[ 9.780000] ehci-platform ehci-platform: new USB bus registered, assigned bus
number 1
[ 9.820000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 9.840000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 9.840000] hub 1-0:1.0: USB hub found
[ 9.840000] hub 1-0:1.0: 1 port detected
[ 9.900000] nf_conntrack version 0.5.0 (458 buckets, 1832 max)
[ 10.200000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ü
DRAM: 32 MB
id read 0x100000ff
Flash: 4 MB
In: serial
Out: serial
Err: serial
ag7240_phy_setup
eth0 up
ag7240_phy_setup
eth1 up
eth0, eth1
Starting kernel ...
18 UTC 2012
0MHz
es: 8128
bytes
des=1
54)
RT
phan) found.
- preinit -
- regular preinit -
- init -
[ 7.540000] eth0: link down
[ 8.300000] Compat-wireless backport release: compat-wireless-2012-07-13
[ 8.310000] Backport based on wireless-testing.git master-2012-07-16
[ 8.310000] compat.git: wireless-testing.git
[ 8.460000] cfg80211: Calling CRDA to update world regulatory domain
[ 8.460000] cfg80211: World regulatory domain updated:
[ 8.470000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gai
n, max_eirp)
[ 8.480000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 8.480000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 20
00 mBm)
[ 8.490000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 20
00 mBm)
[ 8.500000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 8.510000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 8.710000] usbcore: registered new interface driver usbfs
[ 8.710000] usbcore: registered new interface driver hub
[ 8.720000] usbcore: registered new device driver usb
[ 9.330000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[ 9.340000] cfg80211: Calling CRDA for country: US
[ 9.340000] cfg80211: Regulatory domain changed to country: US
[ 9.350000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gai
n, max_eirp)
[ 9.360000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 27
00 mBm)
[ 9.360000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 17
00 mBm)
[ 9.370000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 9.380000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 9.390000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 20
00 mBm)
[ 9.400000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 30
00 mBm)
[ 9.480000] PPP generic driver version 2.4.2
[ 9.560000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 9.700000] NET: Registered protocol family 24
[ 9.740000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 9.750000] ehci-platform ehci-platform: Generic Platform EHCI Controller
[ 9.760000] ehci-platform ehci-platform: new USB bus registered, assigned bus
number 1
[ 9.790000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 9.810000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 9.810000] hub 1-0:1.0: USB hub found
[ 9.810000] hub 1-0:1.0: 1 port detected
[ 9.870000] nf_conntrack version 0.5.0 (458 buckets, 1832 max)
ü
DRAM: 32 MB
id read 0x100000ff
Flash: 4 MB
In: serial
Out: serial
Err: serial
ag7240_phy_setup
eth0 up
ag7240_phy_setup
eth1 up
eth0, eth1
You push the button,starting httpd to update firmware ...
dup 1 speed 100
starting httpd server from server 192.168.1.1
http start
request for file /
request for file /favicon.ico
couldn't open file
expecting 3932409 bytes
received data will be stored at 80060000
ü
DRAM: 32 MB
id read 0x100000ff
Flash: 4 MB
In: serial
Out: serial
Err: serial
ag7240_phy_setup
eth0 up
ag7240_phy_setup
eth1 up
eth0, eth1
hornet> help
? - alias for 'help'
bootm - boot application image from memory
cp - memory copy
erase - erase FLASH memory
help - print online help
httpd - start webserver
md - memory display
mm - memory modify (auto-incrementing)
mtest - simple RAM test
mw - memory write (fill)
nm - memory modify (constant address)
printenv- print environment variables
progmac - Set ethernet MAC addresses
reset - Perform RESET of the CPU
setenv - set environment variables
tftpboot- boot image via network using TFTP protocol
version - print monitor version
hornet>
