这图片咋搞的就这么小一点,真是别扭!
BA9BF
:这图片咋搞的就这么小一点,真是别扭!
(2012-09-11 08:59)
单击图片看大图
有这个电台的HAM请跟帖子交流一下使用感受,和心得体会!交流那些功能还需改进。
用户被禁言,该主题自动屏蔽!
古野FS-1562短波电台,声音好听,皮实耐用不错
问下:这机器如何退出自动调谐状态?先谢谢了!!!!!!!!!
按rcl开机
旋转旋钮到9999
输入密码#1562 ENT
然后选择项目
9909 为0 是 LSB 发射接收许可
9915 为 1 是 不预调谐
9902 9903 为 0 是 全段收发
BG2TT
:按rcl开机
旋转旋钮到9999
输入密码#1562 ENT
然后选择项目
(2013-01-19 16:30)
谢谢啊!!!!!!!!刚才看了下,我的机器是FS-1502的,也不知道可以参考这个调不。再次谢谢啊!!!!!!!!!
求古野FS-1501单边带收发机中文说操作书
求古野FS-1562-25单边带收发机中文说操作书 ,谢谢,只知道是250W的机器。
GENERAL CHARACTERISTICS
1. Frequency Range
TX: 1.6 to 27.5 MHz, 100 Hz steps
RX: 0.1 to 29.99999 MHz, 10 Hz steps
2. Frequency Accuracy 10 Hz (after warm-up)
3. Communication System Simplex of semi-duplex
4. Class of Emission
J3E, H3E and J2B
When 2182 kHz is recalled by the [2182] key,
H3E is automatically selected.
5. Power Supply
24 VDC +30/-10 %, 15 A (150 W),
35 A (250 W) for TX, 2 A for RX
115/230 VAC with extra rectifier
TRANSMITTER CHARACTERISTICS
1. RF Output Power
150W (FS-1562-15), 250 W (FS-1562-25) at 50-ohm load
Reducible to 60 Wpep
2. Two-tone Alarm Generator
Built in as standard. Complies with SOLAS requirements.
ANTENNA COUPLER CHARACTERISTICS
1. Input Impedance 50 ohms
2. Antenna 7-30 m whip or wire
3. Tuning Speed 0.2 to 2 sec, typical
RECEIVER CHARACTERISTICS
1. Receiving System
Double-conversion super heterodyne
IF: 54.455 MHz and 455 kHz
2. Selectivity
J3E: 350 to 2700 Hz, H3E: ± 3 kHz, F1B: ± 150 Hz
3. Sensitivity (Input level to produce SINAD 20 dB)
J3E H3E F1B
0.3 -1.6 MHz (10Ω + 250PF) 25 dBμV 39 dBμV -
1.6 - 4 MHz (10Ω + 250PF) 16 dBμV 30 dBμV 6 dBμV
4 - 27.5 MHz (50 Ω) 3 dBμV - -7 dBμV
4. Scan Dwell time 1-99 sec where traffic is present
5. Audio Output 1 W (8 Ω built-in speaker)
5 W (4 Ω external speaker)
EQUIPMENT LIST
Standard
1. Transceiver unit
2. Telephone handset
3. Antenna coupler AT-1560 (FS-1562-15),
AT-1562-25 (FS-1562-25)
4. Power Amplifier Unit PA-2500 for FS-1562-25
Optional
1. Rectifier with changeover facility PR-300 for FS-1562-15
PR-850A for FS-1562-25
2. Distributor DB-120
介绍
古野电气公司感谢您选择了FS-1562 MF/HF 单边带无线电话设备。我们相信您会发现古野品牌于“质优和可靠”是同义的。为了充分发挥你的设备的最佳性能,请仔细阅读并遵照操作的维护所推荐的步骤去做。
FS-1562是全功能的无线电话系统,特别适用于海事通信频段1.6到27.5MHz。所有的按国际电信联盟所要求的频段都预设其中了。此外,TX/RX 频率可以有200对容量的E2PROM中了。
有两种型号的FS-1562:分别为FS-1562-15(150Wpep)和FS-1562-25(250Wpep)(pep表示最大峰值包络功率),整个单元的在单边带发射机中采用加重输出功率。
-设备安装信息请参阅设备安装手册。
-系统安装后的初始化可以在业务手册中找到。
性能
-GMDSS操作:数字选呼和窄带直接印字电报连接
-2182键控提供立即选择2182(在全功率自动功能中)使用
-扫描、扫频接收机
-PROM存储所有的国际电信联盟单边带和电传频率
-人工负载(在天线匹配器中)可用来检查发射机
-有效的静噪声控制装置消除了脉冲噪声
-高级“语音”探测用何种消噪滤波器滤除噪声
-遥控站(RB-500)功能可选
-系统诊断程序
-交流故障板(可选择)功能,在交流功率有故障时,自动消除TX功率(仅FS-1562-25机型有此功能)
注意
1. 使用电池的容量一定要充分(150W机型大于120安培小时,250W机型大于200安培小时),否则电池不能提供充分的发射功率。
2. 用麦克风时一定要仔细。热量、湿度、和震击将影响其性能。
3. 不要调整设备内部的电位器,因为不正确的调整会导致机器的严重损坏。
FS-1562型号的中频、高频无线电话的性能指标
FS-1562-15/25符合下列规范:
-IMOA.421(XI), A610(15), A613(15), A694(17)
-国际电信联盟的无线电规则
-ETS 300 373
-IEC 1097-9草案,国际电工协会945通则
-EC EMC对CE制造的指导
-相关的其他规则
通则
通信系统:单工或半双工
频率范围:1.6到27.5MHz(发射),0.1到30MHz(接收)
发射种类:J3E 单边带,抑制载波、信号信道包括模拟信息、电话:当2182kHz首先选择时,J3E被设定。
H3E 单边带、全载波、信号信道包括模拟信息
J2B 用于数字选呼、窄带直接印字电报,单边带、抑制载波、信号信道包含量化信息或数字信道用于调制副载波、自动接收电话
F3C 仅仅用来接收气象传真
频率误差:+ 10Hz(对发射机和接收机都如此)
信道号码:常用信道:最多200可以预设,单必须由古野的业务代表完成。
国际电信联盟的单边带/电传信道(如附录中的所示)
2182 kHz(单一功能)
2187.5 kHz(数字选呼设备中自动选择)
环境要求:按国际电工协会要求:-15°C-+70°C ACU:在40°C时93%
电源要求:24伏直流电+30%,-10%,对交流电要求有整流单元。
接收: 2A
发射(最大):FS-1562-15…20A
FS-1562-25…40A
无线电话信号发生器:双音信号2200Hz和1300Hz交替发射。
发射机
输出阻抗:50欧姆
输出功率:J3E/H3E:FS-1562-15…150 W pep, FS-1562-25…250 W pep
J2B: FS-1562-15…150 W pep, FS-1562-25…250W pep
(前向纠错模式:减低到60W)
5
调谐:大约10 到 20 W
减低功率:60W
控制:输出功率:高、低测试
天线偶合器
最大功率 AT-1560-15…150 W pep
AT-1560-25…250 W pep
调谐系统:CPU全自动调谐控制系统
频段范围:1.6到27.5 MHz
天线要求:7米到30米的线状或鞭状天线
调谐功率:10到20W pep
VSWR:小于1.5
调谐时间:小于2到15秒,每次调谐频率时小于0.5秒
假负载:10欧姆+250pF并检查2191kHz的报警产生器
功率要求:15伏直流电,1A(从收发机提供)
结构:防水塑料机壳、不锈钢安装。
接收机
接收机系统:双转换超外差
输入频率:54.455 MHZ和455 kHz
灵敏度: 输入电平产生了SINAD 20 分贝,或BER 10 -2
J3E J2B
1.6-4 MHz < +16分贝微伏 < +6分贝微伏,流过10欧姆+250pF
4-27.5 MHz < + 3分贝微伏 < -7分贝微伏,流过50欧姆
带通:350-2700Hz -6分贝
交调:从60分贝微伏有用信号中的无用信号+90分贝微伏+20kHz
音频输出:2W(8欧姆内置扬声器),5 W(4欧姆可选外置扬声器)
0 dBm/600欧姆线性输出(话机始终处于触发状态)
自动增益控制:开/关
噪声抑制装置:常开
电源放大单元(型号PA-2500用于FS-1562-25)
最大功率:输入功率:60 W pep,输出功率:250 W pep
输入、输出阻抗:50欧姆
电源供电:24 伏直流电,30 安培
6
尺寸
收发单元:108 mm(宽)× 258mm(高)× 300mm(深),6.5公斤
天线偶合单元 297mm(宽)× 390 mm(高)× 90 mm(深),约3.1公斤
罗经安全距离
单元
标准
操纵
注意
收发机
天线偶合器AT-1560-15
天线偶合器AT-1560-25
话机
PA-2500
PR-300
PR-850
1.2m
1.0m
1.0m
0.6m
0.9m
0.9m
1.0m
0.9m
0.7m
0.7m
0.4m
0.7m
0.7m
0.7m
按国际标准化组织R 694决议,古野推荐,A种测试方法适用于各种型号的设备,并加上古野考虑到的其他纠正因素。
7
第一章:操作
1.1 系统的建立
基本的24 伏直流电FS-1562包括收发单元、功率放大单元(用于150W)、天线偶合器和话机。下图显示的是系统用150W或250W建立和数字选呼终端和其他附加设备流程图:
1.2 收发单元前板展示
上图中的英文含义:Loudspeaker:扬声器、Operation Display:操作显示、Keyboard:键盘、Microphone Handset Jack:麦克风插孔、Volume control w/Power ON/OFF: 音量控制和电压开关,通(断)、RF Gain: 射频增益、FREQ/CHANNEL selector:信道选择器、Xtal oven light (LED):指示灯。
旋动钮
Volume(音量):打开或关闭电源开关并可调整扬声器的音量。当FS-1562连到DB-500和RB-500时,FS-1562可以通过RB-500打开。如此,RB-500就可能是1.04以后的版本。
RF GAIN(射频增益):调整接收机的灵敏度。
FREQ/CH(频段、频道):配合TX或RX键,改变频率,也可以通过RCL键改变频道的号码。
按键
(1)MODE(模式):选择发射种类并控制AGC(自动增益控制)开与关,重复按(1)键进行直到出现所需的模式。
(2)CURSor (光标):移动光标(下划线符号),按下(2)键移动光标。
(3)CLARIFY(细调):如果设定了频道号码时调整接收频率,不要直接进入频率中,该功能每10Hz一步调整幅度为+150Hz。
TX(发射):选择一个发射频率。
(4)speaker(扬声器):打开或关闭内部或外部扬声器。如果扬声器关闭,扬声器标志将出现显示。
(5)Squelch(消噪):消噪功能打开或关闭。如果消噪功能打开,“SQ”将出现显示。
10
