  • 9742阅读
  • 10回复
MC145162的说明书分翻译 [复制链接]
离线wb4916
只看楼主 倒序阅读 0楼 发表于: 2010-04-12
帖子3的附件中,从p241开始,到最后,是别人已经翻译好的。(超星的pdg格式)
具体请参考:
锁相环频率合成器motorola集成电路应用技术丛书
由于以前没有玩过pll,ham-10m决定使用mc145162做频合。
理由:常见,参看程序多,也就是会的人,出了问题容易找到人问。
结果就找到了:bg2wah。
很热情的,帮忙校对了程序,并且给了mc145162中文说明书的扫描件。
第一页:
semiconductor
technical data
order this document
by mc145162/d
60 mhz and 85 mhz universal programmable dual pll frequency synthesizers
cmos
the mc145162 is a dual phase-locked loop (pll) frequency synthesizer especially designed for ct-1 cordless phone applications worldwide. this frequency synthesizer is also for any product with a frequency operation at 60 mhz or below.
the mc145162-1 is a high frequency derivative of the mc145162, for products with operating frequencies of 85 mhz or below.
the device features fully programmable receive, transmit, reference, and auxiliary reference counters accessed through an mcu serial interface. this feature allows this device to operate in any ct-1 cordless phone application. the device consists of two independent phase detectors for transmit and receive loops. a common reference oscillator, driving two independent reference frequency counters, provides independent reference frequencies for transmit and receive loops. the auxiliary reference counter allows the user to select an additional reference frequency for receive and transmit loops if required.
operating voltage range: 2.5 to 5.5 v
operating temperature range: – 40 to + 75°c
operating power consumption: 3.0 ma @ 2.5 v
maximum operating frequency:
  mc145162   - 60 mhz @ 200 mv p–p, vdd = 2.5 v
  mc145162-1 - 85 mhz @ 250 mv p–p, vdd = 2.5 v
three or four pins used for serial mcu interface din
built-in mcu clock output with frequency of reference oscillator ÷3/÷4
power saving mode controlled by mcu mcuclk
lock detect signal
on-chip reference oscillator supports external crystals to 16.0 mhz
reference frequency counter division range: 16 to 4095
auxiliary reference frequency counter division range: 16 to 16,383
transmit counter division range: 16 to 65,535
receive counter division range: 16 to 65,535
rev 3.1
2/98
(c) motorola, inc. 1998
半导体的技术手册
通过 mc145162/d 来订购本文
可达到60 mhz 和 85 mhz 的、通用的、可编程的双pll频率合成器
cmos(采用的工艺)
mc145162是一个双锁相环频率合成器,适用于全球范围内的ct-1制式的无绳电话。同样适用于需要60 mhz以下的频率其它产品。
mc145162-1是mc145162的高频版本,工作频率高达85 mhz。
通过mcu的串行接口,我们可以非常方便地操作它的完全可编程的接收、发射、参考、辅助参考计数器。正因为这样,所以它可使用于任何ct-1制式的无绳电话。本元件的发射环和接收环各有一个独立的相位检测器。一个共用的参考晶体,驱动两个独立的参考频率计数器,为发射环和接收环提供了独立的参考频率。如果有需要的话,辅助参考计数器可以让我们为发射环和接收环选择一个额外的参考频率。
工作电压范围:2.5 到 5.5 v。
工作温度范围:–40 到 +75℃
功耗:3.0 ma @ 2.5 v最大工作频率:
可选3线或者4线的串行接口。
内置mcu时钟输出,值为参考晶体的频率÷3/÷4可选。
可由mcu的mcuclk脚控制省电模式
锁定检测信号。
内置的参考晶体,支持外置的晶体可达16.0 mhz
参考频率计数器的分频范围:16-4095
辅助参考频率计数器的分频范围:16-16,383
发射计数器的分频范围:16-65,535
接收计数器的分频范围:16-65,535
rev 3.1
2/98
第六页
pin descriptions
input pins
oscin/oscout
reference oscillator input/output (pins 7, 8)
these pins form a reference oscillator when connected to an external parallel-resonant crystal. figure 6 shows the relationship of different crystal frequencies and reference frequencies for cordless phone applications in various countries. oscin may also serve as input for an externally generated reference signal which is typically ac coupled.
mcuclk
system clock (pin 5)
this output pin provides a signal of the crystal frequency (oscout) divided by 3 or 4 that is controlled by a bit in the control register.
this signal can be a clock source for the mcu or other system clocks.
adin, din, clk, enb
auxiliary data in, data in, clock, enable (pins 2, 3, 1, 4)
these four pins provide an mcu serial interface for programming the reference counter, the transmit-channel counter, and the receive-channel counter. they also provide various controls of the pll including the power saving mode and the programming format.
txps/ftx, rxps/frx
transmit power save, receive power save (pins 13, 11)
for a normal application, these output pins provide the status of the internal power saving mode operation. if the transmit-channels counter circuitry is in power down mode, txps/ftx outputs a high state. if the receive-channels counter circuitry is in power down mode, rxps/frx is set high. these outputs can be applied for controlling the external power switch for the transmitter and the receiver to save mcu control pins.
in the tx/rx channel counter test mode, the txps/ftx and rxps/frx pins output the divided value of the transmit channel counter (ftx) and the receive channel counter (frx), respectively. this test mode operation is controlled by the control register. details of the counter test mode are in the tx/rx channel counter test section of this data sheet.
fin-t/fin-r
transmit/receive counter inputs (pins 14, 9)
fin-t and fin-r are inputs to the transmit and the receive counters, respectively. these signals are typically driven from the loop vco and ac coupled. the minimum input signal level is 200 mv p-p @ 60.0 mhz.
output pins
txpdout/rxpdout
transmit/receive phase detector outputs (pins 15, 10)
these are three-state outputs of the transmit and receive phase detectors for use as loop error signals (see figure 7 for phase detector output waveforms). phase detector gain is vdd/4 π volts per radian.
frequency fv > fr or fv leading: output = negative pulse.
frequency fv < fr or fv lagging: output = positive pulse.
frequency fv = fr and phase coincidence: output = high-impedance state.
note: fr is the divided-down reference frequency at the phase detector input and fv is the divided-down vco frequency at the phase detector input.
ld
lock detect (pin 16)
the lock detect signal is associated with the transmit loop. the output at a high level indicates an out-of-lock condition (see figure 7 for the ld output waveform).
power supply
vdd
positive power supply (pin 12)
vdd is the most positive power supply potential ranging from 2.5 to 5.5 v with respect to vss.
vss
negative power supply (pin 6)
vss is the most negative supply potential and is usually connected to ground.
crystal ÷n value fr1→b fr2→c
11.150 mhz 446 6.25 khz 1.0 khz
11.150 mhz 223 12.5 khz
10.240 mhz 512 5.0 khz
12.000 mhz 600 5.0 khz
figure 6. reference frequencies for cordless phone applications of various countries
mc145162·mc145162-1
motorola
管脚定义:
输入脚
oscin/oscout
参考晶体输入/输出引脚(第7、8脚)
当连接到一个外接的并联谐振晶体的时候,这些引脚组成了一个参考振荡器。应用在各国的无绳电话时,图6显示了不同的晶体频率和参考频率的关系。作为一个外接产生的参考信号时,oscin可作为输入脚,通常是ac耦合的。
mcuclk
系统时钟脚(第5脚)
这个输出脚提供了一个3分频或者4分频的晶体频率信号(oscout),由控制寄存器中的专用位来配置。
本信号可以作为mcu或者其他系统的时钟源。
adin, din, clk, enb
辅助数据输入脚、数据输入脚、时钟脚、使能脚(第2、3、1、4脚)
这4个脚提供了一个mcu的串行接口,为参考计数器、发射通道计数器、接受通道计数器编程。他们还提供pll的各种控制功能,包括省电模式与编程格式。
txps/ftx, rxps/frx
发射省电模式、接收省电模式(第13、11脚)
正常情况下,这些输出引脚提供了内置节能模式工作的状态信息。假如发射通道计数器电路处于关机模式,txps/ftx脚被置高。假如接收通道计数器电路处于关机模式,rxps/frx脚被置高。这些输出脚被用来控制发射机和接收机的外置电源开关,以节省mcu的控制引脚。
在tx/rx通道计数器处于测试模式时, txps/ftx 与 rxps/frx引脚分别输出发射通道计数器(ftx)和接收通道计数器(frx)的分频值。控制寄存器控制这个测试模式。计数器的测试模式的详细资料,在本数据手册的 tx/rx 通道计数器测试部分。
fin-t/fin-r
发射/接收计数器输入引脚(第14、9脚)
fin-t 和 fin-r 被分别输入到发射与接收计数器。这些信号通常由vco环路驱动,且为ac耦合。最小的输入信号电平为 200 mv p-p @ 60.0 mhz。
输出引脚
txpdout/rxpdout
发射/接收相位检测器输出引脚(第15、10脚)
这些发射与接收相位检测器三态输出脚,被用作环路错误信号(参见图7:相位检测器的输出波形)。鉴相器增益为vdd/4 π v/弧度。
频率:fv > fr 或 fv 超前:输出 = 负脉冲
频率:fv < fr 或 fv 滞后:输出 = 正脉冲
频率:fv = fr 且同相:   输出 = 高阻抗状态
注意:fr为鉴相器输入脚经分压后的参考频率,而fv为鉴相器输入脚经分频后的vco频率。
ld
锁定检测脚(第16脚)
锁定检测信号与发射环相关联。输出脚为高电平表示失锁(参见图7:ld输出脚的波形)。
电源部分
vdd
电源正极(第12脚)
vdd对vss的范围为2.5-5.5 v。
vss
电源负极(第6脚)。
vss为电源负极,通常接地。
图6。各国无绳电话锁使用的参考频率。
mc145162·mc145162-1
motorola
附件: MC145162 整理好 20100412 2323.zip (0 K) 下载次数:251
附件: MC145162 Moto.pdf (0 K) 下载次数:157
附件: MC145162-01-07.zip (0 K) 下载次数:254
附件: MC145162-08-13.zip (0 K) 下载次数:230
离线wb4916
只看该作者 1楼 发表于: 2010-04-12
第7页
vh = high voltage level.
vl = low voltage level.
*at this point, when both fr and fv are in phase, the output is forced to near mid supply.
note: the txpdout and rxpdout generate error pulses during out-of-lock conditions. when locked in phase and frequency, the output is high impedance and the voltage at that pin is determined by the low-pass filter capacitor.
figure 7. phase detector/lock detector output waveforms
mcu programming scheme
the mcu programming scheme is defined in two formats controlled by the enb input. if the enable signal is high during the serial data transfer, control register/reference frequency programming is selected. if the enb is low, programming of the transmit and receive counters is selected. during programming of the transmit and receive counters, both adin and din pins can input the data to the transmit and receive counters. both counters' data is clocked into the pll internal shift register at the leading edge of the clk signal. it is not necessary to reprogram the reference frequency counter/control register when using the enable signal to program the transmit/receive channels.
in programming the control register/reference frequency scheme, the most significant bit (msb) of the programming word identifies whether the input data is the control word or the reference frequency data word. if the msb is 1, the input data is the control word (figure 8). also see figure 8 and table 1 for control register and bit function. if the msb is 0, the input data is the reference frequency (figure 9).
the reference frequency data word is a 32-bit word containing the 12-bit reference frequency data, the 14-bit auxiliary reference frequency counter information, the reference frequency selection plus, the auxiliary reference frequency counter enable bit (figure 9).
if the aux ref enb bit is high, the 14–bit auxiliary reference frequency counter provides an additional phase reference frequency output for the loops. if aux ref enb bit is low, the auxiliary reference frequency counter is forced into power-down mode for current saving. (other power down modes are also provided through the control register per table 2 and figure 8.) at the falling edge of the enb signal, the data is stored in the registers.
there are two interfacing schemes for the universal channel mode: the three-pin and the four-pin interfacing schemes. the three-pin interfacing scheme is suited for use with the mcu spi (serial peripheral interface) (figure 10), while the four-pin interfacing scheme is commonly used for general i/o port connection (figure 11).
for the three-pin interfacing scheme, the auxiliary data select bit is set to 0. all 32 bits of data, which define both the 16-bit transmit counter and the 16-bit receive counter, latch into the pll internal register through the data in pins at the leading edge of clk. see figures 12 and 13.
for the four-pin interfacing scheme, the auxiliary data select bit is set to 1. in this scheme, the 16-bit transmit counter's data enters into the adin pin at the same time as the 16-bit receive counter's data enters into the din pin. this simultaneous entry of the transmit and receive counters causes the programming period of the four-pin scheme to be half that of the three-pin scheme (see figures 14 and 15).
while programming tx/rx channel counter, the enb pin must be pulsed to provide falling edge to latch the shifted data after the rising edge of the last clock. maximum data transfer rate is 500 kbps.
note
10 ms should be allowed for initial start-up time for the oscillator to allow all registers to clear and enable programming of new register values.
motorola
mc145162·mc145162-1
vh = 高电平
vl = 低电平
*在这一点上,当fr和fv同相时,输出脚被拉到电源电压的一半。
注意:当失锁的时候,txpdout 和 rxpdout引脚产生错误的脉冲。当相位和频率锁定时,输出端为高阻态、那个脚的电压取决于低通滤波电容。
图7.鉴相器/锁定检测器的输出波形。
mcu的编程方法
mcu的编程方法有两种格式,由enb输入引脚所控制。在串行数据传输的时候,假如使能信号为高,控制寄存器/参考频率编程被选中。假如enb为低时,发射计数器与接收计数器的被选中编程。在发射计数器与接收计数器编程期间,adin 和 din脚都能输入数据到发射与接收计数器。在clk信号的上升沿,两个计数器的数据时序移入pll的内置移位寄存器。当用使能信号来编程发射/接收通道时,不必重新编程参考频率计数器/控制寄存器。
在编程控制寄存器/参考频率时,编程字的最高位(msb)指示输入数据是控制字,或者是参考频率数据字。假如msb为1,输入数据为控制字(图8)。同样参考图8与表1,控制寄存器与位定义。假如msb为0,输入数据是参考频率(图9)。
参考频率字有32位,包括了12位的参考频率数据、14位辅助参考频率计数器信息、额外的参考频率选项和辅助参考频率计数器得使能位(图9)。
假如aux、ref、enb位都为高,14位辅助参考频率计数器将为各个环路提供了一个额外的相位参考频率输出。假如aux、ref、enb位都为低,为省电起见,辅助参考频率计数器进入关机模式。(其它关机模式将由控制寄存器按表2和图8执行)。在enb信号的下降沿,数据被存入寄存器。
通用通道模式有两种接口:3线或者4线接口模式。3线接口模式适用于mcu的spi模式(图10),4线接口模式适用于通用i/o口连接(图11)。
在3线接口模式里,辅助数据选择位被置0。由16位的发射计数器和16位的接收计数器组成的32位数据,在clk信号的上升沿,将通过引脚的数据锁存到pll的内置寄存器。参见图12和13。
对于4线接口模式,辅助数据选择位被置1。在这种模式里,16位的发射寄存器数据和16位的接收寄存器数据同时分别输入adin脚和din脚。这种发射寄存器与接收寄存器同时输入数据的方法,使得4线接口模式的编程周期只有3线接口模式的一半。(参见图14和15)
当编程tx/rx通道计数器,enb脚必须动作,以便在上次时钟的上升沿之后提供下降沿来锁存移位数据。最大数据传输速率为500 kbps。
注意:
最初的晶体启动时间要10ms,以使得所有的寄存器被清空,允许编程新的数据值。
motorola
mc145162·mc145162-1
第八页
control register identifier = 1
control register data
note: enb must be high during the serial transfer.
figure 8. programming format of the control register
table 1. control register function bits description
test bit
set to 1 for tx/rx channel counter test mode
set to 0 for normal application
aux data select
set to 1 for both adin and din pins inputting the transmit 16–bits data and receive 16-bits data respectively.
set to 0 for normal application interfacing with mcu serial peripheral interface. does not use adin pin; tie adin to vss.
refout÷3/÷4
if set to 1, refout output frequency is equal to oscout ÷3.
if set to 0, refout output is oscout ÷4.
txpd enable
if set to 1, the transmit counter, transmit phase detector, and the associated circuitry is in power-down mode.
tx ps/ftx is set "high".
rxpd enable
if set to 1, the receive counter, receive phase detector, and the associated circuitry is in power-down mode.
rx ps/frx is set "high".
ref pd enable
if set to 1, both 12-bit and 14-bit reference frequency counters are in power-down mode.
table 2. control register power down bits function
txpd enable rxpd enable ref pd enable tx-channel counter rx-channel counter reference frequency counter
0         0         0           -             -             -
0         0         1           -             -             power down
0         1         0           -             power down       -
0         1         1           -             power down       power down
1         0         0           power down       -             -
1         0         1           power down       -             power down
1         1         0           power down       power down       -
1         1         1           power down       power down       power down
mc145162·mc145162-1
motorola
注意:在串行数据传输时,enb脚置高有效。
图8。控制寄存器的编程格式。
表1。控制寄存器功能位的描述
测试位
置1:tx/rx通道计数器处于测试模式。
置0:正常使用
辅助数据选项
置1:adin 和 din脚分别输入16位发射数据和16位接收数据。
置0:正常使用mcu的spi接口。不用adin引脚,将adin引脚拉低。
refout÷3/÷4
置1:refout输出频率 = oscout ÷ 3。
置0:refout输出频率 = oscout ÷ 4。
txpd 启用
置1:发射寄存器、发射鉴相器及相关电路处于关机模式。
tx ps/ftx 被置高。
rxpd 启用
置1:接收寄存器、接收鉴相器及相关电路处于关机模式。
rx ps/frx 被置高。
ref pd 启用
置1:12位和14位的参考频率计数器都处于关机模式。
表2。控制寄存器关机模式位功能
0         0         0           -             -             -
mc145162·mc145162-1
motorola
离线wb4916
只看该作者 2楼 发表于: 2010-04-12
第十一页
note: enb must be low during the serial transfer.
figure 15. programming format for transmit and receive counters
(4-pin interfacing scheme)
table 3. global ct-1 reference frequency setting vs channel frequencies
country   channels frequency         fr1           fr2
u.s.a.     46/49 mhz (10, 15, 25 channels) 5.0 khz       —
france     26/41 mhz               6.25 khz/12.5 khz —
spain     31/41 mhz               5.0 khz       —
australia   30/39 mhz               5.0 khz       —
u.k.     1.7/47 mhz               6.25 khz       1.0 khz
new zealand 1.7/34/40 mhz             6.25 khz       1.0 khz
and programming
figure 16 shows the bit function of the reference frequency programming word. the user can either select the "fixed" reference frequency for all channels accordingly or provide a specific reference frequency for a particular channel by using two reference frequency counters (e.g., for an application in france, the base set transmit channel common fixed reference frequency is 6.25 khz or 12.5 khz). (see table 3 and
figure 6 for reference frequencies for various countries.) however, transmit channels 6, 8, and 14 can be set to 25 khz, and channel 8 reference frequency can be set to 50 khz. but this reference frequency may not be applied to the receiving side; therefore, the receiving side reference frequency must be generated by another reference frequency counter. the higher the reference frequency, the better the phase noise performance and faster the lock time, but the pll consumes more current if both reference frequency counters are in operation.
in general, the 12-bit reference frequency counter plus the ÷4 and ÷25 module can offer all the reference frequencies for global ct-1 transmit and receive channel requirements. users can select their own reference frequency by introducing the additional 14-bit auxiliary reference frequency counter.
again, the 14-bit auxiliary reference frequency counter can be shut down by the auxiliary reference enable bit in the reference counter programming word by setting the bit to 0. at this state, the fr2 is automatically connected to point c (the ÷25 block output), and fr1 can be connected to point a or b by setting the fr1-s1 and fr1-s2 bits in the reference counter program word. the 14-bit auxiliary reference frequency counter data will be in "don't care" state.
if the 14-bit auxiliary reference frequency counter is enabled (auxiliary reference enable = 1), then fr2 is automatically connected to point d (14-bit counter output), and fr1 can be selected to connect to point a, b, or c, depending on the bit setting of fr1-s1 and fr1-s2.
table 4 and figure 16 describe the functions of the auxiliary reference enable bit and the fr1-s1 and fr1-s2 bits selection.
motorola
mc145162·mc145162-1
注意:串行数据传输的时候,enb脚置低有效。
图15。发射计数器与接收计数器的编程格式。
(4脚接口)
表3。全球的ct-1制式的参考频率设置与通道频率
参考频率选项与编程
图16显示了参考频率编程字的位功能。用户可以为所有的通道选择“固定”参考频率,或者通过使用2个参考频率计数器,为一个特定的通道提供一个特定参考频率,(例如,法国的参考频率固定为6.25 khz 或 12.5 khz)。(参见表3和表6,各国的参考频率)但是发射通道6、8和14可设成25 khz,通道8的参考频率可设为50 khz。但是这个参考频率可能不能被用在接收端;此外,接收端的参考频率必须由另外一个参考频率计数器产生。参考频率越高,相位噪声性能越好,锁定所需要的时间越短。但是两个参考频率计数器都在工作的话,pll将消耗更多电流。
通常情况下,12位的参考频率计数器加上÷4 和 ÷25模块,可以提供所有的参考频率,以满足全球的ct-1制式发射通道和接收通道的需要。用户可以选择他们自己的参考频率,通过引入额外的14位辅助参考频率计数器。
同样地,通过在参考计数器编程字中,设置辅助参考使能位为0,14位辅助参考频率计数器就会被关闭。在这种情况下,fr2被自动连到c点(÷25块输出)。通过设置参考计数器编程字里面的fr1-s1 与 fr1-s2位,fr1可连接到a或b点。此时,14位辅助参考频率计数器数据处于“无效”状态。
假如14位辅助参考频率计数器启用(辅助参考位=1),fr2将自动连接到d点(14位计数器输出),fr1可选为连接到a、b或c点,取决于fr1-s1 与 fr1-s2位的设置。
表4和图16描述了:辅助参考使能位、fr1-s1 与 fr1-s2 位设置的功能。
motorola
mc145162·mc145162-1
附件: MotoPLL.part1.rar (0 K) 下载次数:159
附件: MotoPLL.part2.rar (0 K) 下载次数:111
附件: MotoPLL.part3.rar (0 K) 下载次数:118
离线BH7KQK
只看该作者 3楼 发表于: 2010-04-13
哈哈,不错。经过半年的应用,mc145162在hf波段效果还是非常不错的。用在十米fm上更是方便。
而且,便宜。。。
可惜,俺只玩cw。vxo足矣。
离线BA6QH/QRP
只看该作者 4楼 发表于: 2010-04-13
[quote=][/quote]
bu cou
离线a00183
只看该作者 5楼 发表于: 2010-04-18
有本motorola 集成电路应用技术丛书〈锁相环频率合成〉,是中文的。在241页有较详细的介绍。这本书可以在网上找到电子版的。
离线bg4uan
只看该作者 6楼 发表于: 2010-05-23
离线bh8cso
只看该作者 7楼 发表于: 2013-01-16
MC145162数字可编程锁相环如果要翻译出来一大部分都是可以不用翻译,下面的是以前的移动电话频率分频设置,没什么关系,主要搞懂时序图和锁相原理。这个是数字可编程锁相环,里面是两个锁相环,除了分频部分一点点不一样,其他都不难。
离线bg7doz
只看该作者 8楼 发表于: 2018-07-26
收藏了,谢谢!
离线田鼠
只看该作者 9楼 发表于: 2021-12-06
辛苦!
山西晋中市榆次区
kqj1972@163.com
收听者
离线马超2020
只看该作者 10楼 发表于: 2023-11-09
感谢楼主分享!手里一台FT808船台,就用到了这个IC
