  • 6431阅读
  • 17回复
2000人民币买个MFJ-936B值不值呀? [复制链接]
离线曹玉龙
只看楼主 倒序阅读 0楼 发表于: 2012-04-22
Drape a wire around a bookcase or window and attach both ends to this new MFJ Small Loop Tuner�. It instantly turns into a small, high efficiency multi-band transmitting loop antenna! You can operate 5.3 to 30 MHz with a full 150 Watts. No ground, radials or counterpoises needed.
The excellent performance of a high-efficiency small loop antenna is legendary and well proven by users all over the world. You抣l radiate a low angle DX signal that literally rivals full size dipoles and work incredible DX!
It a very quiet receiving antenna; you抣l hardly notice static crashes. Its high-Q reduces QRM, overloading, harmonics. It抯 perfect for apartments, antenna restricted areas and portable operation.
A 13 foot wire formed into a loop operates 30-20 Meters (4 foot for 17-10 M; 7 foot for 20-15 M; 28 foot for 60-40 M). You can tune any shape loop; circle, square, rectangle, any odd shape. A quarter wavelength wire shaped as a circle is the most efficient.
A given wire length covers about 1.5 to 1 frequency range (i.e. 7-10 / 18-28 MHz, etc.). Exact frequency coverage depends on wire length, loop shape, surroundings and height above ground. Has MFJ low loss Butterfly loop tuning capacitor, no rotating contacts. Easy-Carry handle. Mount for PVC Cross on cover.
See June, 1986, QST or recent ARRL Antenna Handbook for more details on small, high efficiency loops
只看该作者 1楼 发表于: 2012-04-22
明显发骚
离线bd2fw
只看该作者 2楼 发表于: 2012-04-22
用过就知道了 欢迎你吃螃蟹。
张东辉
bd2fw@126.com
离线曹玉龙
只看该作者 3楼 发表于: 2012-04-22
论坛里谁搞过没呀?2000多买3个电容 感觉不值呀
离线关则勇
只看该作者 4楼 发表于: 2012-04-23
一个大华功率表就要1000元啊
BG7JAA
电邮:bg7jaa@126.com
网站:www.amp.co.nf
也是他们愿意用一生去专注做一件事的信念和情怀。
手艺人往往意味着固执,缓慢,少量,劳作。
手把青秧插满田,
低头便见水中天。
心底清净方为道,
退步原来是向前。
只看该作者 5楼 发表于: 2012-04-23
查了一下,外面卖260美刀~值得一试
离线BH1LHS
只看该作者 6楼 发表于: 2012-04-23
贴一个MFJ的标就值这个钱了...
BH1LHS
北京市通州区
FT857D + 3波段倒V+PAC-12
离线bh7peu
只看该作者 7楼 发表于: 2012-04-23
等待测试报告。
离线迷思
只看该作者 8楼 发表于: 2012-04-23
回 BH1LHS 的帖子
BH1LHS:贴一个MFJ的标就值这个钱了... (2012-04-23 09:13)
其实在美国,MFJ是低质量的代名词(指品管差,用料不算差),但是谁也没有办法完全不用它,因为MFJ的产品线实在太全了!
曾用呼号:BG7KFZ
离线神秘色彩
只看该作者 9楼 发表于: 2014-01-05
顶顶楼主!
BD4ITM
我的微博: https://weibo.com/u/2243489255
拥有一颗平常心·健康快乐每一天
离线haog131
只看该作者 10楼 发表于: 2014-01-06
可以先试试8ABM刘老师的M2
Callsign:BH4我爱撸  省协会号:92163
Moblie:①3八五二久伍酒Oo捌
Grid:OM92wf
离线bd2bh
只看该作者 11楼 发表于: 2014-01-08
呵呵,相对与大型天线的性价比,如果你觉得这个天线小巧、效率高、便携方便,且能大功率发射,随时随地沟通无限,那么就值。尤其是对于那些有了高级设备、高等级操作证书,住着公寓去不能有效通联的爱好者来说,再多点也值得。
不喜欢的话ic-7700也就是个破收音机,还不如买台汽车,里面收音机音响效果比这更好,因为想法不同,需求不同。
更关键的是品牌、技术含量和工艺水准。你没见国内爱好者DIY原来买一百多的某-12天线,现在都可以卖1k5以上了吗。当然这里面有关税和经销尚的营销手段问题;还有物以稀为贵,比如ic-7000原来8千多没人买嫌贵,买了八年多,原产国停产,降价清库存了,国内逆天买到1200,即便这样还有人抢着买。
BD2BH_SHE@163.COM
离线BG6IWV
只看该作者 12楼 发表于: 2014-01-28
峰登至极我为峰!13569007373
离线bg9gxm
只看该作者 13楼 发表于: 2014-01-28
回 bd2bh 的帖子
bd2bh:呵呵,相对与大型天线的性价比,如果你觉得这个天线小巧、效率高、便携方便,且能大功率发射,随时随地沟通无限,那么就值。尤其是对于那些有了高级设备、高等级操作证书,住着公寓去不 .. (2014-01-08 21:40)
我是实在没有搞懂 一个山寨的加感天线居然有那么多的人来追捧。。。。
忘记说MFJ了。。。。关于这玩意是否值得买 我觉得你可以试一试 当然 如果你闲钱不多就别烧了。。。。我倒觉得这玩意是个好东西 毕竟国内自己做的小环 我还没见过有多好的 基本高功率就是打火 而且自己做的外观差的一塌糊涂 电容我身边也有 但一直懒得动手 原因就在于此次 我记得类似这样的天线还有其他品牌的 具体叫什么忘记了 你可以查一查 当然 如果有人给你从国外带回来 或者走转运公司 奸商就赚不到钱了 哈哈哈哈哈哈
说了这么多 我就再扯两句 我和德国人做qso 每次我都非常饶有兴趣的去他们的QRZ主页去看看 原因就在于我想看看德国佬都用的什么天线= = 综合发现 他们用optibeam的比较多 每次做QSO 这个天线基本一次就能抄下我的呼号 基本不用报第二遍(当然完美的qso都是在有良好的传播之下才能did的) 而且和他们聊天中得知 他们对此天线也非常满意 当然价格也是非常的昂贵 随便一个加空运就是1万+ 自己选择吧。。。。。。。。。。
[ 此帖被bg9gxm在2014-01-28 18:35重新编辑 ]
近期文章:探访国内顶尖的业余无线电比赛台——BY5EA
印刷通联卡片随缘接单。主攻出版物和油标印刷:)
我个人为了支持BY VR2 XX9 BV Ham走出去
点我进入中国卡片局转卡系统
离线bd2fw
只看该作者 14楼 发表于: 2014-01-30
回 bg9gxm 的帖子
bg9gxm:
OB9-5         9 Element, 5 Band
Bands         20 / 17 / 15 / 12 / 10
Gain (dBd) *         4,3 / 4,5 / 4,7 / 4,5 / 4,5
Gain (dBi) **         11,7 / 12,0 / 12,3 / 12,3 / 12,3
F/B (dB)         18 / 20 / 25 / 25 / 25
VSWR
14,00 - 14,19 - 14,35         1,3 - 1,0 - 1,2
18,07 - 18,13 - 18,17         1,4 - 1,1 - 1,3
21,00 - 21,25 - 21,45         1,6 - 1,1 - 1,6
24,89 - 24,94 - 24,99         1,4 - 1,2 - 1,3
28,00 - 28,50 - 29,00         1,6 - 1,2 - 1,5
Elements (number)         9
Active Elements je Band         2 - 3
Max. Elementlength (m)         10.94
Boomlength (m)         5.1
Turning Radius (m)         6.03
Feedlines (number)         1 Coax 50 Ohm
Weight (kg)         30
Windload at 130 km/h         578 N / 0,72 m² / 7,8 feet²
[ 此帖被bd2fw在2014-01-30 09:49重新编辑 ]
张东辉
bd2fw@126.com
只看该作者 15楼 发表于: 2014-01-30
建议935B,能便宜二百多元
BG2ALB   电波
离线BD4CB
只看该作者 16楼 发表于: 2014-01-30
不值得!绝对不值得!
离线陈建强
只看该作者 17楼 发表于: 2014-02-01
值你买就值
