  • 83699阅读
  • 366回复
玩转TS-590 [复制链接]
离线BG0APD
只看该作者 240楼 发表于: 2013-02-04
590功率提升到200W,见
http://www.mods.dk/view.php?ArticleId=4948
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 241楼 发表于: 2013-02-04
Why do the modification?
[list=disc]
  • up to 200 watts.
  • less spike effect.
  • no splatter.
  • no "pup effect" in voice modulatin.
  • warm normal.
  • power adjust normal.
  • roe protection normal.
  • AT works normal.
  • very easy to do and you can revert it.
  • Disclaimer Notice:
    The following modification should be done by qualified personnel at the owners risk. I am not responsible for any damage to, or illegal operations of the equipment as a result of mod errors or possible mod misinformation via this page.
    REMOVE BOTTOM COVER
    1. Find C810 smd condenser near Ic802 ( N 4 in TX-RX unit component side view, front radio side). C810 is a large smd 10mF unit.
    2. Solder a 1K resistor across C810 terminals WITH "PIGGY-BACK" METHOD (DO NOT remove the original C810), take care….
    3. Close the radio.
    4. Service menu : 23 at 185 and 24 at 255 firmware V.06 or 23 at 170 and 24 at 255 firmware V.07. I don't know why yet……you need experience something like this to your radio to menu 23 with wattmeter.
    Enjoy and let me know.
    If you don't like, you can revert it.
    Schematic to the article (10 Mb)
    PU3DXX
    José Leoni Janczak
    [ 此帖被BG0APD在2013-02-04 13:38重新编辑 ]
    邮箱:BG0APD@163.com
    电话:15309910960
    离线BG0APD
    只看该作者 242楼 发表于: 2013-02-04
    C810两端并联1K电阻。
    09-10-2012 20;15;45.PDF (3898 K) 下载次数:25 09-10-2012 20;20;34.PDF (2035 K) 下载次数:24
    仅供参考,后果自负。
    邮箱:BG0APD@163.com
    电话:15309910960
    离线bd8uk
    只看该作者 243楼 发表于: 2013-02-04
    扩功率不感兴趣,扩到1-54兆都可以发射才感兴趣!
    离线bg7smp
    只看该作者 244楼 发表于: 2013-02-07
    BG0APD 你扩频成功了吗?你的动圈咪还用着没?
    相聚是缘分,相识是缘分,通联拉近我们的距离
    山东人在防城港,使用设备:FT-DX3000,IC-7000,IC-756PROⅢ;使用天线:A3DX++
    QQ:178718,HAM无限群号:100571
    离线BG0APD
    只看该作者 245楼 发表于: 2013-02-08
    回 bg7smp 的帖子
    bg7smp:BG0APD 你扩频成功了吗?你的动圈咪还用着没? (2013-02-07 21:18)
    不是扩频,是扩功率,我没有功率表,没有扩功率。
    动圈咪还在用。
    邮箱:BG0APD@163.com
    电话:15309910960
    离线bg7smp
    只看该作者 246楼 发表于: 2013-02-13
    是接在ACC2上的?能帮我做条线吗?
    离线BG0APD
    只看该作者 247楼 发表于: 2013-02-13
    回 bg7smp 的帖子
    bg7smp:是接在ACC2上的?能帮我做条线吗? (2013-02-13 19:58)
    每部TS-590只配一个ACC2插头。这种插头太专用了,买不到。
    邮箱:BG0APD@163.com
    电话:15309910960
    离线bg7smp
    只看该作者 248楼 发表于: 2013-02-15
    哦,在广东应该不难买,BH7NJQ给我发过来一个,但是接线可能不一样
    离线bd8uk
    只看该作者 249楼 发表于: 2013-02-16
    仔细思考了一下,第二台TS-590S即将到手
    离线BD7YA
    只看该作者 250楼 发表于: 2013-02-16
    有钱淫啊!
    E-MAIL: hellocq 安特 126.com
    离线bd8uk
    只看该作者 251楼 发表于: 2013-02-24
    第二台TS-590S垃圾到货,折腾中……。
    离线BG8CDC
    只看该作者 252楼 发表于: 2013-02-24
    回 bd8uk 的帖子
    bd8uk:第二台TS-590S垃圾到货,折腾中……。 (2013-02-24 12:49)
    8UK买两台590S,准备怎么折腾呀?
    呼号:BG7CDC  曾用呼号  BG8CDC
    姓名:王坚
    地址:湖南省长沙市雨花区时代阳光大道216号全州大厦817室
    邮编:410117
    电话:18008446644 :115:
    离线bd8uk
    只看该作者 253楼 发表于: 2013-02-24
    回 BG8CDC 的帖子
    BG8CDC:8UK买两台590S,准备怎么折腾呀? (2013-02-24 13:52)
    争取多买几台,架设在电磁环境不同的地点,就可以通过网络进行控制和QSO啦!
    离线BG0APD
    只看该作者 254楼 发表于: 2013-02-24
    哈哈,恭喜,可以做分集了,590×2大于IC7800.
    邮箱:BG0APD@163.com
    电话:15309910960
    离线weed
    只看该作者 255楼 发表于: 2013-02-24
    590怎样才能玩PSK31?
    机器已经能通过USB线用电脑遥控了,就是不知用什么软件玩。
    姓名: 方启旸 (旸:Yang)
    联系电话:13798809718
    E-mail: fangqy112@sina.com
    E-mail: fangqy112@qq.com
    离线bg8dp
    只看该作者 256楼 发表于: 2013-02-24
    回 BG0APD 的帖子
    [ 此帖被bg8dp在2016-12-02 22:44重新编辑 ]
    朱和平,BG8DP
    手机:136~~016188 ( 不欢迎无重要事情的电话骚扰! )
    北新大道大丰华美东街?????号一栋三单元五楼二号
    机器设备:TS-440,FT-757,FT-817ND,FT-857D, IC-7000,~~
    现在在成都荷花池附近打工上班赚钱,赚够了回老家(四川省乐至县劳动镇)去~~
    离线BG0APD
    只看该作者 257楼 发表于: 2013-02-24
    回 weed 的帖子
    weed:590怎样才能玩PSK31?
    机器已经能通过USB线用电脑遥控了,就是不知用什么软件玩。 (2013-02-24 16:53)
    很简单啊。L32内嵌MMVARI,我玩的很好,前面帖子有介绍。
    邮箱:BG0APD@163.com
    电话:15309910960
    离线BG0APD
    只看该作者 258楼 发表于: 2013-02-24
    回 bg8dp 的帖子
    bg8dp:这个春节期间,在 7050  7053  7057  14270 玩实战 QSO~~~~~~
    我用 IC-7000 通联了不少使用 590s和7410 机器的HAM,感觉7410出来的SSB声音好听一些!!
    ....... (2013-02-24 20:19)
    啥叫好听,啥叫难听,有没有量化标准?拿出来看看,也许我耳朵很木,跟590通联从来没有听出有什么差别。
    [ 此帖被BG0APD在2013-02-25 00:24重新编辑 ]
    邮箱:BG0APD@163.com
    电话:15309910960
    离线bd8uk
    只看该作者 259楼 发表于: 2013-02-25
    呵呵,其实都是凭感觉猜测而已,真正盲听的话,说不准好多人都会把FT-857D的声音听成IC-7800的也不一定呢!
