  • 11209阅读
  • 16回复
【LOGGER32】V3.41-汉化包更新-20120825 [复制链接]
离线BD4EP
只看楼主 倒序阅读 0楼 发表于: 2012-08-15
如题,今天发布的。大家可以升级了。
V3.41完整安装包:
http://www.logger32.net/files/lgr32full3410.zip
V3.40到V3.1升级包:
http://www.logger32.net/files/lgr32upgrade3410.zip
2012/08/25注:因发现问题,请暂勿使用官方网站的汉化包!!!
简体中文汉化包(官方网站尚待更新)
BY341A.ZIP: http://vdisk.weibo.com/s/bbdOB
繁体中文汉化包(台湾-官方网站尚待更新)
BV341A.ZIP:http://vdisk.weibo.com/s/bbdO8
[ 此帖被BD4EP在2012-08-25 18:44重新编辑 ]
呼号:BD4EPV
绰号:BD4EP
CSKC-404
Email:bd4epv(a)chinaham.org
离线BD4EP
只看该作者 1楼 发表于: 2012-08-15
新版更新说明:
Release change notes for Ver 3.41.0 as of....... 7 Aug 2012
Changed the code so that importing QSOs of the same time now increments the time
by one second.  Previously the time was incremented by one clock tick, so exporting
the records gave duplicate times again (the granularity of ADIF time is one second)
Bug fix:  Clusters that do not terminate the login prompt with a line feed (the
blinking cursor remains on the login prompt line) will now work.
New option:  DX Spot Window | SETUP | APPEARANCE | CREDITED/CONFIRMED/WORKED COLORS
Bug fix: Prevent incorrect beam headings and tooltips when clicking on a DX Spot.
Change made to address a potential problem on the Internet lookup window looping.
Changes made to tighten up the Internet Lookup (HamQTH) code.  It should be a little
faster now.
Changes made to the way the Local Host and Telnet tabs on the Cluster/Telnet Window
are captioned (when connected/not connected). The Cluster Window the caption of the
Local Host tab now shows the shortcut name the user has set.
Change to the Sound Card: There is an enhancement to the Default Audio frequency.
This allows the user to select a new default frequency to adjust the signal point
to compensate for different filter bandpass when changing filters in the transceiver.
When running MMTTY AFSK the default Tx audio frequency is ignored.  The tx frequency
is either set to the HAM default, or if net is on, it follows the Rx frequency.  So,
as default Tx audio has no meaning/function in MMTTY, all reference has been removed.
Added new functions antenna rotor operation.: Home position and preset headings are
now configurable.
Added function -- On the Logbook Entry Window, with a STATE, County or IOTA entered,
a right click on the ? will open a generic QSO window showing all QSO's with that
entity.
Change made to the HamQTH lookup: ignore the QTH, and County when the callsign
includes a modifier?
Change made to the DX Spot callsign filters. More Callsign highlight and user
options added to Audio Alert setup window.
Bug fix: cannot export a partiallog to a csv file for input into excel.
Bug fix: Changes made to the accuracy of the database filecreation timestamp.
Bug fix: Corrupt data being placed in the ADIF Audit Trail file Data/Time fields.
Bug fix:  DXCC worked/confirmed highlights on the DX Activity window to show
incorrectly as worked instead of confirmed.
The on-line-submission ADIF is now output in alphabetical call order.
Logger 32 Version 3.41.000
2012 Aug 10
Countries / Prefixes Database Updates
**  Changed Primary Prefix for these DXCC Entities:
ZK2     to    E6    (Niue.  Effective 2012 Aug 3, per ARRL Letter.)
**  Added prefix blocks ZQ2 & ZQ3 to ZB (Gibraltar)
**  Added specific callsigns:
<9M4SLL>    to     1S    (Spratly)
<TO2D>        FJ     (Saint Barthelemy)
<TO5U>        FM    (Martinique)
<TX0HF>        FO\A    (Austral Islands)
<TX5VT>        FO\M    (Marquesas Islands)
<TO2U>        FP    (St. Pierre & Miquelon Islands)
<R200BB>    R    (European Russia)
<R200BS>    R    (European Russia)
<R200V>        R    (European Russia)
**  Deleted specific callsigns:
<ZQ3M>         ZB    (Gibraltar)
<ZQ2ER>        ZB    (Gibraltar)
**  Thanks to Constantin, UA1AKE
Bud, W2RU
Keeper of the C/P Databa
IOtA changes, thanks to G3NPA
Withdrawal of EU-155 from IOTA List
In a previous news item (28 October 2011) we reported that, following information received from a local operator in Italy that the only two islands listed as qualifying for EU-155, Baron and Scanno di Piallazza, no longer existed, we would not be accepting for credit any new operations claiming to take place from EU-155 pending a final check. This has now been carried out and it confirms the report. Under IOTA rules we have no option but to withdraw EU-155 from the list of valid IOTA groups and to amend scores down. However we have noted that the Po Delta is a remarkably fragile natural environment with a varying sedimentation rate influenced by river flow, tide and storm and have not ruled out the possibility of one of the islands reforming in time. In the circumstances, we have decided to remove EU-155 credit from all scores on 1 September 2012 but to retain the QSO information on the database in a non-counting format in case the situation should change. We will review the position periodically. In the meantime, while credit will not be given for new operations, we will allow credit for pre-October 2011 operations for certificate purposes only in applications received before 1 September 2012.
Malyy Vysotskiy Island and EU-117
Following the decision by the ARRL to delete Malyy Vysotskiy Island (MVI) from the current DXCC list as of 17 February 2012 the IOTA Committee has considered action to be taken with regard to the future of EU-117. The presence of MVI in the IOTA list as a separate group was originally justified by its separate DXCC Entity status under Rule E.5.5, so the island's deletion now calls for action from IOTA. The programme does not maintain a Deleted Groups List to record contacts by participants with deleted IOTA groups in a form similar to the DXCC Deleted Entities List. Faced with the prospect of a straight deletion of EU-117 and incorporation of the island into the EU-133 list, the Committee formulated an alternative course of action involving the transfer of a section of the EU-133 慴ox?to EU-117, so avoiding deletion. It put the alternatives to an enlarged IOTA management group involving for the first time the 22 checkpoints. The consultation produced a clear majority in favour of splitting EU-133 to form two groups within the Gulf of Finland, North and South. The dividing line has been set at 60 degrees, 15 minutes north. The islands now constituting the two groups can be seen via the Search facility on this page. This change, which has an effective date backdated to 17 February 2012, means that past credits for MVI will continue to stand and new opportunities are created for contacting EU-117. Record-holders need take no action regarding existing credits as they will not be deleted as a consequence of this change, nor in the case of EU-133 credits need they be transferred unless requested. The Committee believes this to be an imaginative solution in the best interests of the programme.
G3KMA, 16 Jun 2012
EU-117
Group Name: Gulf of Finland North Group
Claimed by: 77.0% of participants.
Main prefix: R1A;R1B;R1C;R1M
DXCC: EUROPEAN RUSSIA
Group Contains:
Bereznik
Bol'shoy Berezovyy
Chernovoy
Dymnyy
Gustoy/Kotelny
Khallikarti [ AKA Halli ]
Kiuskari [ AKA Bol'shoy Fiskar Isls ]
Krepysh
Kuurinsaari [ AKA Naparnik ]
Lisiy
Malyy Vysotskiy
Novik
Peredovik
Peschanyy
Rondo [ AKA Ruonti ]
Severnyy Berezovyy
Vasikkasaari
Zaovrazhenskiy
Zapadnyy Berezovyy
Group Excludes:
Klest
Mayskiy
Vysotskiy
EU-133
Group Name: Gulf of Finland South group
Claimed by: 65.8% of participants.
Group Contains:
Bol'shoy Tyuters
Gogland [ AKA Sur Sari ]
Khangeloda
Khitamatala
Kokor
Kotlin
Malyy
Malyy Tyuters
Mayak
Mayak Tolbukhin
Moshchnyy
Narvi [ AKA Nerva ]
Remisar
Reymosar
Rodsher
Seskar [ AKA Lesnoy ]
Sommers
Verperluda
Virginyy
Sankt Peterburg / Leningradskaya Oblast. Not Sankt-Peterburg City islands or Lake Ladoga islands.
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BD4EP
只看该作者 2楼 发表于: 2012-08-15
faster now.
now configurable.
entity.
Bug fix: Changes made to the accuracy of the database filecreation timest a m p.
2012 Aug 10
Bud, W2RU
G3KMA, 16 Jun 2012
EU-117
Group Contains:
Bereznik
Bol'shoy Berezovyy
Chernovoy
Dymnyy
Gustoy/Kotelny
Krepysh
Lisiy
Malyy Vysotskiy
Novik
Peredovik
Peschanyy
Severnyy Berezovyy
Vasikkasaari
Zaovrazhenskiy
Zapadnyy Berezovyy
Group Excludes:
Klest
Mayskiy
Vysotskiy
EU-133
Group Contains:
Bol'shoy Tyuters
Khangeloda
Khit a matala
Kokor
Kotlin
Malyy
Malyy Tyuters
Mayak
Mayak Tolbukhin
Moshchnyy
Narvi [ AKA Nerva ]
Remisar
Reymosar
Rodsher
Sommers
Verperluda
Virginyy
呼号:BD4EPV
绰号:BD4EP
CSKC-404
只看该作者 3楼 发表于: 2012-08-15
温妻完整兼容吗?
离线bd4ij
只看该作者 4楼 发表于: 2012-08-16
下载速度真的很慢
QQ:75094437
地址:山东淄博
手机:棕橙绿紫橙橙黑蓝白白灰
离线BD6AHP
只看该作者 5楼 发表于: 2012-08-16
唉。。。
de BD6AHP
安徽滁州
离线BG9TX
只看该作者 6楼 发表于: 2012-08-22
升级包升级~~~~波段图没有反应了  求解!!!!!
青海 西宁
☎:13909791632
离线BD4EP
只看该作者 7楼 发表于: 2012-08-25
重要通知:
上一次提交的汉化包似乎有问题,我已经把更新包发给官网的网管了,但官网更新可能要一点时间。现在请大家先在这里下载:
简体中文汉化文件:http://vdisk.weibo.com/s/bbdOB
繁体中文汉化文件(台湾):http://vdisk.weibo.com/s/bbdO8
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BD4EP
只看该作者 8楼 发表于: 2012-08-25
回 BD6AHP 的帖子
BD6AHP:**  Added specific callsigns:
唉。。。 (2012-08-16 12:06)
没办法,我也只是跟老美们声明了我们的立场。但是这件事我们说了不算……
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BD4EP
只看该作者 9楼 发表于: 2012-08-25
回 BG9TX 的帖子
BG9TX:升级包升级~~~~波段图没有反应了  求解!!!!! (2012-08-22 14:55)
奇怪,我这里是好的……
重新装一遍试试呢?
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BD4EP
只看该作者 10楼 发表于: 2012-08-25
回 BG8SZG 的帖子
BG8SZG:温妻完整兼容吗? (2012-08-15 16:00)
完整兼容。
呼号:BD4EPV
绰号:BD4EP
CSKC-404
离线BD4EP
只看该作者 11楼 发表于: 2012-08-26
汉化包重要更新,顶上去!
呼号:BD4EPV
绰号:BD4EP
CSKC-404
在线BA7QT
只看该作者 12楼 发表于: 2012-08-31
已经下载,感谢BD4EP辛苦劳动!
BEST 73!   DE BA7QT/LIAO
QSL MGR:W3HNK
qq:48892357  广西短波群:47730720
离线BD5XX
只看该作者 13楼 发表于: 2012-09-05
不搞围脖下载不了的飘过。。。。。。。。。。。
EX:BD5SO、BG5RSO
Email:bd5xx@foxmail.com
离线BG7DCU
只看该作者 14楼 发表于: 2014-10-15
Re:【LOGGER32】V3.41-更新-20120825
汉化包没有资源了?
活到老,学到老。玩到老,乐到老!qq:451160422
离线bg3hfm
只看该作者 15楼 发表于: 2015-04-14
记号,记号,,,,
新浪微博:刘得意BG3HFM
离线bg7dod
只看该作者 16楼 发表于: 2016-01-16
这个汉化包可以汉化W8.1上面的LOGGER32吗?
